查看: 2496|回复: 0
单片机串口调试助手怎么用?printf()函数输出乱码!
ID:640600 发表于 2019-11-12 18:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
串口调试助手的printf()函数输出乱码!
//part2.42.c    串口通信在硬件调试的应用
#include <reg52.h>
#include <intrins.h>
#include <stdio.h>
#define  uchar unsigned char
sbit dula=P2^6;
sbit wela=P2^7;
sbit adwr=P3^6;
sbit adrd=P3^7;
uchar flag,a;
unsigned char flag_uart,flag_time,flag_on,a,i,t0_num,ad_val;
float ad_vo;
uchar code table[]= {
    0x3f,0x06,0x5b,0x4f,
    0x66,0x6d,0x7d,0x07,
    0x7f,0x6f,0x77,0x7c,
    0x39,0x5e,0x79,0x71
void delayms(uint xms)
    uint i,j;
    for(i=xms; i>0; i--)
        for(j=110; j>0; j--);
void init()     //串口的初始化
    TMOD=0x21;
    //SCON=0x50;
    TH0=(65536-50000)/256;
    TL0=(65536-50000)%256;
    TH1=0xfd;
    TL1=0xfd;
    TR1=1;
    ET0=1;
    SM0=0;
    SM1=1;
    REN=1;
    EA=1;
    ES=1;
void display(uchar value)
    uchar bai,shi,ge;
    bai=value/100;
    shi=value%100/10;
    ge=value%10;
    dula=1;
    P0=table[bai];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0x7e;
    wela=0;
    delayms(5);
    dula=1;
    P0=0xff;
    wela=1;
    P0=0x7d;
    wela=0;
    delayms(5);
    dula=1;
    P0=table[ge];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0x7d;
    wela=0;
    delayms(5);
uchar get_ad()
    uchar adval;
    adwr=1;
    _nop_();
    adwr=0;
    _nop_();
    adwr=1;
    P1=0xff;
    adrd=1;
    _nop_();
    adrd=0;
    _nop_();
    adval=P1;
    adrd=1;
    return adval;
    init();
    wela=1;
    P0=0x7f;
    wela=0;
                puts("TURN ON AD!\n");
                 P0=0xf0;
        if(flag_uart==1)
            flag_uart=0;
            ES=0;
            TI=1;
            switch(1)
            case 0:
                TR0=1;
                break;
            case 1:
                printf("TURN OFF AD!\n");
                TR0=0;
                break;
            case 2:
                puts("ERROR!\n");
                break;
            while(!TI);
            TI=0;
            ES=1;
        if(flag_time==1)
            flag_time=0;
            ad_val=get_ad;
            ad_vo=(float)ad_val*5.0/256.0;
            ES=0;
            TI=1;
            printf("The voltage is %fV\n",ad_vo);
            while(!TI);
            TI=0;
            ES=1;
        display(ad_val);
void timer0() interrupt 1
    t0_num++;
    if(t0_num==20)
        t0_num=0;
        flag_time=1;
void ser() interrupt 4
    RI=0;
    a=SBUF;
    flag_uart=1;
    if(a==1)
        flag_on=0;
    else if(a==2)
        flag_on=1;
        flag_on=2;
