查看: 2998|回复: 2
STM32G030K6T6单片机ADC DMA多通道采样数据不正确
ID:955654 发表于 2022-1-13 10:06 | 显示全部楼层 |阅读模式
ADC DMA多通道  进行采样时,获取到得数据与实际不一致,单通道时是对的
void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig = {0};
  /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.LowPowerAutoPowerOff = DISABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.NbrOfConversion = 12;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = ENABLE;
  hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_39CYCLES_5;
  hadc1.Init.SamplingTimeCommon2 = ADC_SAMPLETIME_39CYCLES_5;
  hadc1.Init.OversamplingMode = DISABLE;
  hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = 0;
  sConfig.SamplingTime = ADC_SAMPLETIME_39CYCLES_5;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = 1;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_2;
sConfig.Rank = 2;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_3;
  sConfig.Rank = 3;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_4;
  sConfig.Rank = 4;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_5;
  sConfig.Rank = 5;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_6;
  sConfig.Rank = 6;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_7;
  sConfig.Rank = 7;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_8;
  sConfig.Rank = 8;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_9;
  sConfig.Rank = 9;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_10;
  sConfig.Rank = 10;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_11;
  sConfig.Rank = 11;
    Error_Handler();
void adc_Dma_start(void)
        HAL_ADCEx_Calibration_Start(&hadc1);
        HAL_ADC_Start_DMA(&hadc1,(uint32_t *)&adcBuff,12);
ID:607298 发表于 2022-1-13 14:21 | 显示全部楼层
这边扫描模式应该要使能吧,hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
另外adcBuff感觉有点小,才能存一次结果。一般我都设置至少存个10次的结果。
ID:955654 发表于 2022-1-13 14:35 | 显示全部楼层
另外adcBuff感觉有点小,才能存 ...
问题 已经解决了,adc 通道配置成 不完全配置序列模式 既 ScanConvMode = ADC_SCAN_SEQ_FIXED
还有个  Rank = ADC_RANK_CHANNEL_NUMBER
