查看: 1840|回复: 0
STM32 USB串口有数据,但PA9没数据发出
ID:885597 发表于 2021-3-30 16:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
代码就是正点板子的实验,我加了个串口发送两句,但是把PA9和USB连起来,电脑读取数据正常,但从PA9脚读数据,读出的都是00,是什么原因
int main(void)
        u16 lun =16;
    u16 adcx;
        float temp;
        delay_init();                     //延时函数初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
        uart_init(115200);                 //串口初始化为115200
         LED_Init();                             //LED端口初始化
        LCD_Init();
         Adc_Init();                                  //ADC初始化
        POINT_COLOR=RED;//设置字体为红色
        LCD_ShowString(60,50,200,16,16,"Elite STM32");
        LCD_ShowString(60,70,200,16,16,"ADC TEST");
        LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(60,110,200,16,16,"2015/1/14");
        //显示提示信息
        POINT_COLOR=BLUE;//设置字体为蓝色
        LCD_ShowString(60,130,200,16,16,"ADC_CH0_VAL:");
        LCD_ShowString(60,150,200,16,16,"ADC_CH0_VOL:0.000V");
                adcx=Get_Adc_Average(ADC_Channel_1,1);
                LCD_ShowxNum(156,130,adcx,4,16,0);//显示ADC的值
                //temp=(float)adcx*(3.3/4096);
                temp=((float)adcx/670)*2;
                adcx=temp;
                LCD_ShowxNum(156,150,adcx,1,16,0);//显示电压值
                //temp-=adcx;
                //temp*=1000;
                LCD_ShowxNum(172,150,temp,3,16,0X80);
                LED0=!LED0;
                //GPIO_Write(GPIOA,temp);
            //printf("%f",temp);
                USART_SendData(USART1,temp);
                while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);
                delay_ms(250);
void uart_init(u32 bound){
  //GPIO端口设置
        USART_InitTypeDef USART_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE);        //使能USART1,GPIOA时钟
        //USART1_TX   GPIOA.9
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //复用推挽输出
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
  //USART1_RX          GPIOA.10初始化
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
  //Usart1 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子优先级3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
   //USART 初始化设置
        USART_InitStructure.USART_BaudRate = bound;//串口波特率
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
        USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
        USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收发模式
  USART_Init(USART1, &USART_InitStructure); //初始化串口1
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断
  USART_Cmd(USART1, ENABLE);                    //使能串口1
