查看: 3065|回复: 0
单片机LCD1602字符液晶垂直滚动可以但是水平滚动程序不行 求指导
一、电路设计此电路由AT89C51最小系统、LCD1602显示模块和独立按键组成。
可实现文字的上下左右滚动
二、运行效果
三、部分单片机代码
  1. /***************   writer:shopping.w   ******************/
  2. #include <reg52.h>
  3. #include <string.h>
  5. #define uint unsigned int
  6. void Initialize_LCD();
  7. void ShowString(uchar,uchar,uchar *);
  8. sbit K1 = P3^0;
  9. sbit K2 = P3^1;
  10. sbit K3 = P3^2;
  11. uchar code Prompt[]="PRESS K1--K4 TO START DEMO PROG";
  12. uchar const Line_Count = 6;
  13. uchar code Msg[][80]=
  14. {
  15.      "Many CAD users dismiss",
  16.     "process of creating PCB",
  17.     "of view.with PCB layout",
  18.     "placement and track routing,",
  19.     "can often be the most time",
  20.     "And if you use circuit simulation",
  21.     "you are going to spend even more"
  22. };
  23. uchar Disp_Buffer[32];
  24. void Delayxms(uint ms)
  25. {
  26.      uchar i;
  27.     while(ms--)
  28.     {
  29.          for(i=0;i<120;i++);
  30.     }
  31. }
  32. void V_Scroll_Display()
  33. {
  34.      uchar i,j,k = 0;
  35.     uchar *p = Msg[0];
  36.     uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  37.     while(p<q)
  38.     {
  39.          for(i=0;(i<16)&&(p<q);i++)
  40.         {
  41.              if(((i==0)||(i==15))&& *p == ' ')
  42.                 p++;
  43.             if(*p != '\0')
  44.             {
  45.                  Disp_Buffer[i] = *p++;
  46.             }
  47.             else
  48.             {
  49.                  if(++k>Line_Count)
  50.                     break;
  51.                 p = Msg[k];
  52.                 Disp_Buffer[i] = *p++;
  53.             }
  54.         }
  55.         for(j=i;j<16;j++)
  56.             Disp_Buffer[j]=' ';
  57.         while(F0)
  58.             Delayxms(5);
  59.         ShowString(0,0,"      ");
  60.         Delayxms(150);
  61.         while(F0)
  62.             Delayxms(5);
  63.         ShowString(0,1,Disp_Buffer);
  64.         Delayxms(150);
  65.         while(F0)
  66.             Delayxms(5);
  67.         ShowString(0,0,Disp_Buffer);
  68.         ShowString(0,1,"      ");
  69.         Delayxms(150);
  70.     }
  71.     ShowString(0,0,"         ");
  72.     ShowString(0,1,"         ");
  73. }
  74. void H_Scroll_Display()
  75. {
  76.     uchar m,n,t = 0,L=0;
  77.     uchar *p = Msg[0];
  78.     uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  79.     for(m=0;m<16;m++)
  80.             Disp_Buffer[m]=' ';
  81.     while(p<q)
  82.     {
  83.          if((m=16||m==31)&& *p == ' ')
  84.             p++;
  85.         for(m=16;m<32&&p<q;m++)
  86.         {
  87.              if(*p != '\0')
  88.             {
  89.                 Disp_Buffer[m] = *p++;
  90.             }
  91.             else
  92.             {
  93.                  if(++t>Line_Count)
  94.                     break;
  95.                 p = Msg[t];
  96.                 Disp_Buffer[m] = *p++;
  97.             }
  98.         }
  99.         for(n=m;n<32;n++)
  100.             Disp_Buffer[n]=' ';
  101.         for(m=0;m<=16;m++)
  102.         {
  103.              while(F0)
  104.                  Delayxms(5);
  105.                ShowString(0,L,Disp_Buffer+1);
  106.                while(F0)
  107.                  Delayxms(5);
  108.             Delayxms(20);
  109.         }
  110.         L = (L==0)? 1:0;
  111.         Delayxms(200);
  112.     }
  113.     if(L==1)
  114.         ShowString(0,1,"      ");
  115. }
  116. void EX_INT0() interrupt 0
  117. {
  118.      F0 = !F0;
  119. }
  120. void main()
  121. {
  122.      uint Count = 0;
  123.     IE = 0x81;
  124.     IT0 = 1;
  125. ……………………
  126. …………限于本文篇幅 余下代码请从51黑下载附件…………
全部资料51hei下载地址:
1602字符液晶滚动演示程序.zip (88.69 KB, 下载次数: 35)
收藏收藏1 分享淘帖 顶 踩
