查看: 2566|回复: 3
stc89c51单片机怎么通过串口将数据发送到电脑端显示,printf函数有什么需要增添的...
ID:837970 发表于 2021-4-20 17:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
sbit Awei = P1^0;
sbit Bwei = P1^1;
sbit Cwei = P1^2;
sbit Dwei = P1^3;
void jisuan();
void delay(int x);
int change(int x);
#define SHU_0 0X3F;
#define SHU_1 0X06;
#define SHU_2 0X5B;
#define SHU_3 0X4F;
#define SHU_4 0X66;
#define SHU_5 0X6D;
#define SHU_6 0X7D;
#define SHU_7 0X07;
#define SHU_8 0X7F;
#define SHU_9 0X6F;
int ge=0, shi=0, bai=0, qian=0;
int count = 0, i = 0;
int freq = 0;
int main()
        ge = 0; shi = 0; bai = 0; qian = 0;
        TMOD        = 0X15;
        TH0 = 0;
        TL0 = 0;
        TH1 = (65535 - 50000)/256;
        TL1 = (65535 - 50000)%256;
        IT0 = 1;
        EX0 = 1;
        EA = 1;
        ET0 = 1;
        ET1 = 1;
        TR0 = 1;
        TR1 = 1;
        jisuan();
                Awei = 1; Bwei = 1; Cwei = 1; Dwei = 0;
                P2 =  change(ge);
                delay(10);
                P2 = 0X00;
                Awei = 1; Bwei = 1; Cwei = 0; Dwei = 1;
                P2 =  change(shi);
                delay(10);
                P2 = 0X00;
                Awei = 1; Bwei = 0; Cwei = 1; Dwei = 1;
                P2 =  change(bai);
                delay(10);
                P2 = 0X00;
                Awei = 0; Bwei = 1; Cwei = 1; Dwei = 1;
                P2 =  change(qian);
                delay(10);
                P2 = 0X00;
void service_timer0() interrupt 1 using 1
    TH0 = 0;
    TL0 = 0;
void service_timer1() interrupt 3 using 3
        i++;
        if (i == 20)
                freq =TL0 + TH0*256;
                i = 0;
                TH0 = 0;
                    TL0 = 0;
void jisuan()
        qian = freq /1000;
        bai = (freq%1000)/100;
        shi = (freq%100)/10;
        ge = freq%10;
void delay(int x)
        int i, j;
        for(i = 0; i < x; i++)
                for(j = 0; j < 100; j++);
int change(int x)
        int shu;
        switch(x)
                case 0: shu = SHU_0; break;
                case 1: shu = SHU_1; break;
                case 2: shu = SHU_2; break;
                case 3: shu = SHU_3; break;
                case 4: shu = SHU_4; break;
                case 5: shu = SHU_5; break;
                case 6: shu = SHU_6; break;
                case 7: shu = SHU_7; break;
                case 8: shu = SHU_8; break;
                case 9: shu = SHU_9; break;
        return shu;
ID:390416 发表于 2021-4-20 22:51 | 只看该作者
串口1打印程序 可以打印3个十六位的变量 波特率9600 http://www.51hei.com/bbs/dpj-201660-1.html
串口发送 不需要while死等 串口接收执行软件复位 http://www.51hei.com/bbs/dpj-200927-1.html
ID:889094 发表于 2021-4-21 07:54 来自触屏版 | 只看该作者
没看到串口中断函数
ID:837970 发表于 2021-4-26 23:21 | 只看该作者
串口 ...
不好意思,最近一直有事未能及时回复您的消息,感谢您的帮助,同时我也需要先学习了解一下,如有问题可能还需打扰了
