查看: 1665|回复: 0
求大佬帮忙改一下这个单片机程序,通过P3.3口的中断输入控制触发的角度
回帖奖励 50 黑币 回复本帖可获得 50 黑币奖励! 每人限 1 次
ID:614734 发表于 2021-4-30 13:46 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
求大佬帮忙改一下这个程序,通过P3.3口的中断输入控制触发的角度,然后通过内部定时器控制触发信号做相应的移相然后输出波形
#include "reg52.h"
#include"ADC0808.h"
#include "lcd.h"
sbit VT1=P2^0;
sbit VT2=P2^1;
sbit VT3=P2^2;
sbit VT4=P2^3;
sbit VT5=P2^4;
sbit VT6=P2^5;
uchar count;
uchar AD_num,angle_num;//采样AD的值和导通的角度
uchar AD_signal,achieve_signal;
uint delay_num=0;//延时的时间
void Delay10ms()                //@121MHz
        unsigned char i, j, k;
        _nop_();
        _nop_();
        i = 5;
        j = 154;
        k = 1;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void SCRTrg(uchar Num)     //  脉冲宽度30°
                switch(Num)            // 触发相位
                case 1:
                         VT1 = 1;        // 开通
                    VT6 = 0;
                        break;
                case 2:
                        VT1 = 1;            // 关断
                    VT6 = 0;
                        break;
                case 3:
                        VT2 = 0;
                    VT1 = 1;
                        break;
                case 4:
                    VT1 = 1;
                    VT2 = 0;
                        break;
                case 5:
                    VT3 = 0;
            VT2 = 0;
                        break;
          case 6:
                        VT3 = 0;
                    VT2 = 0;
                        break;
                case 7:
                        VT3 = 0;
                    VT4 = 0;
                        break;
                case 8:
                        VT3 = 0;
                    VT4 = 0;
                        break;
                case 9:
                        VT5 = 1;
                    VT4 = 1;
                        break;
                case 10:
                    VT5 = 0;
                        VT4 = 0;
                        break;
                case 11:
                        VT5 = 0;
                    VT6 = 0;
                        break;
          case 12:
                        VT5 = 0;
                    VT6 = 0;
                        break;
                default:
                        break;
//定时器和外部中断初始化
void Timer_Init(void)
        TMOD=0x11;
        TH1=0xF9;
        TL1= 0x7F;
        ET0=1;
        ET1=1;
        IT0 = 1;        // 下降沿触发
        PX0=1;//外部中断0定义为高优先级
        EX0=1;
void main(void)
    Timer_Init();
        VT1=0;
        /*VT2=0;
        VT3=0;
        VT4=0;
        VT5=0;
        VT6=0;*/
    LcdInit();
        AD_num=ADCInit();
        angle_num=(uint)((255-AD_num)/255.0*180);
        delay_num=(uint)(angle_num*10000/180.0);
        LcdPrintf(0,"angle:");
        LcdDisplayI(6,angle_num);
        EA=1;
                if(AD_signal==1)
                        AD_signal=0;
                    if(AD_num!=ADCInit())
                                TR0=0;
                                TR1=0;
                                AD_num=ADCInit();
                                achieve_signal=1;
                                EX0=1;
void exint0() interrupt 0
        Delay10ms();
        count=1;
if(angle_num<60)
count=1;
else if(angle_num<120)
                count=11;
                count=9;
        TH0=(65536-delay_num)/256;
        TL0=(65536-delay_num)%256;
        TR0=1;
        EX0=0;//关外部中断
void Time0Int()  interrupt 1
        TH1=0xF9;
        TL1= 0x82;
        TR0=0;
        TR1=1;
void Time1Int()  interrupt 3
        TH1=0xF9;
        TL1= 0x82;
        SCRTrg(count++);
        if(count==6)
                AD_signal=1;
        if(count>12)
                count=1;
