查看: 3072|回复: 2
为什么仿真出来阻值一直是0000.00k,单片机程序哪里有问题啊?
*********STC89C51**********
**********12MHz晶振********/
#include "reg51.h"
#include<stdio.h>
#include<intrins.h>
#define uint8 unsigned char
#define uint16 unsigned int
uint16 cnt2ms;        //10ms计数器
uint8 cnt1s;        //1秒计数器
//电阻--------------------------------
#define        Z1 13700053.00
#define        Z2 3685279.00
float RZ=0;
unsigned long   RX=0;
unsigned long   RX2=0;
unsigned long   RX3=0;
unsigned long   RX4=0;
unsigned long   RX5=0;
unsigned long   RX6=0;
unsigned long   RX7=0;
unsigned long   RX8=0;
unsigned long   RX9=0;
//电感--------------------------------
float LZ=0;
#define        C1 0.0261
//电容--------------------------------
float CZ=0;
float CX=0;
#define        R1 22274
uint8 KL=0;        //
unsigned int Pulsecnt=0;        //脉冲个数
unsigned int Pulsenum;        //脉冲个数
uint8 start=0;        //
uint16 PulseTime;        //10ms计数器
uint16 Pulse;        //10ms计数器
bit flag=0;
uint8 CH=0;        //
unsigned long x;
void Init_Extint(void);
void TimerInitProc();
void Init_System(void);
void Display(uint8 chose_dat, uint8 dat);
void ShowDisp(uint8 tPulsenum, uint8 tPulsecnt, uint8 tcnt1s);
void DelayMs(uint8 Ms);
uint8 Pulse_FLAG=0;
uint8 Pulse_5=0;
/********************************按键*****************************************/
sbit    K1=P1^3;
sbit    K2=P1^4;
sbit    K3=P1^5;
sbit    A0=P2^1;
sbit    A1=P2^0;
sbit    RED=P3^6;
sbit    YEW=P3^4;
sbit    GRE=P3^3;
/********************************LCD液晶**************************************/
#define LCD_Data P0           //LCD的数据口
sbit    LCD_BF=LCD_Data^7;    //LCD忙信号位
sbit    LCD_RS=P1^0;
sbit    LCD_RW=P1^1;
sbit    LCD_EN=P1^2;
#define LCD_GO_HOME               0x02         //AC=0,光标、画面回HOME位
//输入方式设置
#define LCD_AC_AUTO_INCREMENT     0x06         //数据读、写操作后,AC自动增一
#define LCD_AC_AUTO_DECREASE      0x04         //数据读、写操作后,AC自动减一
#define LCD_MOVE_ENABLE           0x05         //数据读、写操作,画面平移
#define LCD_MOVE_DISENABLE        0x04         //数据读、写操作,画面不动
//设置显示、光标及闪烁开、关
#define LCD_DISPLAY_ON            0x0C         //显示开
#define LCD_DISPLAY_OFF           0x08         //显示关
#define LCD_CURSOR_ON             0x0A         //光标显示
#define LCD_CURSOR_OFF            0x08         //光标不显示
#define LCD_CURSOR_BLINK_ON       0x09         //光标闪烁
#define LCD_CURSOR_BLINK_OFF      0x08         //光标不闪烁
//工作方式设置
#define LCD_DISPLAY_DOUBLE_LINE   0x38         //两行显示
#define LCD_DISPLAY_SINGLE_LINE   0x30         //单行显示
/*定义子程序*/
void LCD_ClrAll(void);              //清屏
void Judge_LCD_busy(void);           //检测是否忙碌
void LCD_Write(uchar WriteData);     //写控制字
void LCD_write_data(uchar LCD_data); //写数据显示
void LCD_cursor(uchar x);    //光标起始地址
void LCD_printc(unsigned char lcd_data) ;  //输出一个字符
void LCD_prints(unsigned char *lcd_string);//输出字符串
/*LCD1602忙碌判断子程序*/
void Judge_LCD_busy(void)   //判断LCD1602是否忙状态
   LCD_EN=0;
   LCD_RS=0;
   LCD_RW=1;
   LCD_Data=0xff;
   LCD_EN=1;   //EN 是 1—0 使能
   if(!LCD_BF)break; //LCD_BF=1表示忙碌,需要等待。
   LCD_EN=0;
/******LCD清屏***************/
Judge_LCD_busy();   //判断是否忙碌
LCD_RS=0;
LCD_RW=0;
LCD_Data=0x01;
LCD_EN=1;
LCD_EN=0;
/*******LCD写数据定义各种模式*********/
void LCD_Write(uchar WriteData)   //写指令到LCD
Judge_LCD_busy();
LCD_RS=0;
LCD_RW=0;
P0=WriteData; //把WriteData的数据送到数据口
LCD_EN=1;
LCD_EN=0;
/********LCD显示数据***********/
void LCD_write_data(uchar LCD_data)      //输出一个字节数据到LCD
Judge_LCD_busy();
LCD_RS=1;
LCD_RW=0;
P0=LCD_data;
LCD_EN=1;
LCD_EN=0;
/****光标位置的确定***/
void LCD_cursor(uchar x)            //LCD光标定位到x处
LCD_Write(0x80+x);                       //第一行地址是0x80
/*输出一个字符*/
LCD_write_data(lcd_data);
/*输出字符串*/
unsigned char i=0;
while(lcd_string[ i]!=0x00)
   LCD_write_data(lcd_string[ i]);
   i++;
/*初始化程序*/
void LCD_initial(void)                        //初始化LCD
LCD_Write(LCD_AC_AUTO_INCREMENT|LCD_MOVE_DISENABLE);
LCD_Write(LCD_DISPLAY_ON|LCD_CURSOR_OFF);
LCD_Write(LCD_DISPLAY_DOUBLE_LINE);
LCD_ClrAll();
/****延时******/
void delay_1ms(uint x)
uint j;
uchar i;
for(j=0;j<x;j++)
for(i=0;i<120;i++);
void Key_SM(void){
        if(K3==0){
             delay_1ms(5);
            if(K3==0){
                YEW=1;RED=0;
                GRE=1;
                LCD_cursor(0x00);
                LCD_prints("   MEASURE Lx   ");
                //----电感档-------
                A0=0;
                A1=1;
                CH=2;//电感档
                while(K3==0){}
        if(K2==0){
             delay_1ms(5);
            if(K2==0){
                GRE=1;YEW=0;
                RED=1;
                LCD_cursor(0x00);
                LCD_prints("   MEASURE Rx   ");
               //----电阻档-------
                A0=1;
                A1=0;
                CH=1;//电阻档
                while(K2==0){}
       if(K1==0){
             delay_1ms(5);
            if(K1==0){
               YEW=1;GRE=0;RED=1;
               LCD_cursor(0x00);
               LCD_prints("   MEASURE Cx   ");
               //----电容档-------
                A0=0;
                A1=0;
                CH=3;//电容挡
               while(K1==0){}
void  Value_to_ASCII(unsigned long value,uchar add)
    unsigned char temp[] = "0000.000K ";
    temp[0] = value/1000000 + 0x30;//数值改成字符,液晶显示需要ASCII码
    value = value%1000000;
    temp[1] = value/100000 + 0x30;
    value = value%100000;
    temp[2] = value/10000 + 0x30;
    value = value%10000;
    temp[3] = value/1000 + 0x30;
    value = value%1000;
    temp[5] = value/100 + 0x30;
    value = value%100;
    temp[6] = value/10 + 0x30;
    value = value%10;
    temp[7] = value + 0x30;
    LCD_cursor(add);   //光标起始地址 ,第一行地址是0x00~0x0F,第二行地址是0x40~0x4f
    LCD_prints(temp);
void  Value_to_ASCIIL(unsigned long value,uchar add)
    unsigned char temp[] = "000000uH ";
    temp[0] = value/100000 + 0x30;
    temp[1] = value/10000 + 0x30;
    temp[2] = value/1000 + 0x30;
    value = value%1000;
    temp[3] = value/100 + 0x30;
    value = value%100;
    temp[4] = value/10 + 0x30;
    value = value%10;
    temp[5] = value + 0x30;
    LCD_prints(temp);
void  Value_to_ASCIIC(unsigned long value,uchar add)
    unsigned char temp[] = "00000.0pF ";
    value = value%1000;
    value = value%100;
    value = value%10;
    temp[6] = value + 0x30;
    LCD_prints(temp);
//--------------------主程序--------------------------------
      TMOD=0x51;                 //设置定时器0,方式1:16位定时器
      TH1=0;
      TL1=0;
      TH0=(65536-2000)/256; //设定定时周期
      TL0=(65536-2000)%256;
      TR0=1;
      TR1=1;
      ET1=1;
      ET0=1;
      EA=1;
//----电阻档-------
      A0=1;
      A1=0;
    LCD_initial();
          delay_1ms(50);
    LCD_initial();
          delay_1ms(50);
    LCD_cursor(0x00);
    GRE=1;
        YEW=0;
          RED=1;
    LCD_cursor(0x45);
    CH=1;
     Key_SM();
    if(flag==1){
        flag=0;
        x=Pulsenum*65536+TH1*256+TL1;//计算1s内的脉冲个数,频率=脉冲个数
if(CH==1){
        RZ=(Z1/x);//测量100到1000
        RX=RZ-1000;
        RX=RX>>1;
if(RX>=1005){
        RX=RX-1005;
    }else{RX=0;}
    if(x==0){RX=0;RX2=0;RX3=0;RX4=0;RX5=0;RX6=0;RX7=0;RX8=0;RX9=0;}
  if(RX>1000000){RX=1000000; }
              RX2=(RX+RX3+RX4+RX5+RX6+RX7+RX8+RX9)>>3;//求平均提高精度
RX9=RX8;RX8=RX7;RX7=RX6;RX6=RX5;RX5=RX4;RX4=RX3;RX3=RX;
              //保存上一次的阻值
         Value_to_ASCII(RX2,0x44);//更新阻值显示
if(CH==2){
        LZ=(x*39*C1)/1000000;
        LZ=LZ*x;
        LZ=1000000/LZ;
    if(x==1)LZ=0;
  if(LZ>999999)LZ=999999; //限制最高值
         Value_to_ASCIIL(LZ,0x44);//更新电感值显示
if(CH==3){
       CZ=6600000/x;
    if(x==1||x>30500)CZ=0;
  if(CZ>999999)CZ=999999;  //限制最高值
         Value_to_ASCIIC(CZ,0x44);//更新电容值显示
         cnt2ms=0;
         Pulsenum=0;
         TH1=0;
         TL1=0;
         TR1=1;
* 函 数 名: Exti0_interrupt
* 函数功能: /T0引脚下降沿进入中断
* 入口参数: 无
* 返    回: 无
void T1_interrupt(void) interrupt 3 using 0
  Pulsenum++;        //保存测得脉搏值
函数功能:定时器/计数器1中断处理
入口参数:null
返    回:null
备    注:null
void Timer0IntProc() interrupt 1 using 0 //2ms
    cnt2ms++;
        if(cnt2ms==497)        //1s计时到
        TR1=0;
                cnt2ms = 0;
        flag=1;
#ifndef __INTRINS_H__
#define __INTRINS_H__
extern void          _nop_     (void);
extern bit           _testbit_ (bit);
extern unsigned char _cror_    (unsigned char, unsigned char);
extern unsigned int  _iror_    (unsigned int,  unsigned char);
extern unsigned long _lror_    (unsigned long, unsigned char);
extern unsigned char _crol_    (unsigned char, unsigned char);
extern unsigned int  _irol_    (unsigned int,  unsigned char);
extern unsigned long _lrol_    (unsigned long, unsigned char);
extern unsigned char _chkfloat_(float);
extern void          _push_    (unsigned char _sfr);
extern void          _pop_     (unsigned char _sfr);
#endif
#ifndef __STDIO_H__
#define __STDIO_H__
#ifndef EOF
#define EOF -1
#endif
#ifndef NULL
#define NULL ((void *) 0)
#endif
#ifndef _SIZE_T
#define _SIZE_T
typedef unsigned int size_t;
#endif
#pragma SAVE
#pragma REGPARMS
extern char _getkey (void);
extern char getchar (void);
extern char ungetchar (char);
extern char putchar (char);
extern int printf   (const char *, ...);
extern int sprintf  (char *, const char *, ...);
extern int vprintf  (const char *, char *);
extern int vsprintf (char *, const char *, char *);
extern char *gets (char *, int n);
extern int scanf (const char *, ...);
extern int sscanf (char *, const char *, ...);
extern int puts (const char *);
#pragma RESTORE
#endif
#endif
ID:123289 发表于 2021-6-11 13:21 | 只看该作者
先说说你的测量原理是什么?
ID:824490 发表于 2021-6-11 14:49 | 只看该作者
单片机程序有没有问题不知道,没有人会仔细地去看这么长篇大论的代码!
先说说你这个项目的需求?再简述一下电路的组成,分析一下工作原理,这样大家才能更好地帮到你。
如同上医院,一进门就喊:肚子疼!然后就要找医生拿药吃?
