查看: 8029|回复: 3
ccs编译错误msp4305529 error #10056: symbol "main" redefined: first def
ID:931208 发表于 2021-7-30 16:48 | 显示全部楼层 |阅读模式
下面是复制的console内容
<Linking>
error #10056: symbol "main" redefined: first defined in "./main.obj"; redefined in "./oled project/oled.obj"
remark #10372-D: (ULP 4.1) Detected uninitialized Port A in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
error #10010: errors encountered during linking; "oled.out" not built
remark #10372-D: (ULP 4.1) Detected uninitialized Port B in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
remark #10372-D: (ULP 4.1) Detected uninitialized Port C in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
remark #10372-D: (ULP 4.1) Detected uninitialized Port D in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
>> Compilation failure
makefile:188: recipe for target 'oled.out' failed
gmake[1]: *** [oled.out] Error 1
makefile:184: recipe for target 'all' failed
gmake: *** [all] Error 2
**** Build Finished ****
图片2,3是路径,我都包含进去了的,然后工程里也没有标红,但是就是有错误
网上也搜过了,试了很多办法就是不行,官网有类似的,但是也没看出来是咋解决的。
图3
图3
图2
图2
图1
图1
ID:883242 发表于 2021-7-30 18:02 | 显示全部楼层
main.c和oled.c里面都有main()
ID:585147 发表于 2021-8-2 13:54 | 显示全部楼层
这2个文件重复定义了main,提示很明确了
ID:130230 发表于 2021-8-2 14:08 | 显示全部楼层
第一句不是已经说了有2个main.c了么。。
