查看: 6550|回复: 0
stm32f030 adc的值一直为0
ID:254078 发表于 2017-11-27 11:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "batt_adc.h"
extern void Error_Handler(void);
/* Variable containing ADC conversions data */
extern uint16_t   aADCxConvertedData[ADC_CONVERTED_DATA_BUFFER_SIZE];
/* ADC handle declaration */
/* ADC channel configuration structure declaration */
ADC_ChannelConfTypeDef        sConfig;
void BATT_ADC_Init(void)
ADC_HandleTypeDef             AdcHandle;
GPIO_InitTypeDef  GPIO_InitStruct;
        __HAL_RCC_ADC1_CLK_ENABLE();
        __HAL_RCC_GPIOA_CLK_ENABLE();
        GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
        GPIO_InitStruct.Pull = GPIO_NOPULL;
        GPIO_InitStruct.Pin  = ADCx_CHANNEL_PIN;
        HAL_GPIO_Init(ADCx_CHANNEL_GPIO_PORT, &GPIO_InitStruct);
AdcHandle.Instance          = ADCx;
  if (HAL_ADC_DeInit(&AdcHandle) != HAL_OK)
    /* ADC de-initialization Error */
    Error_Handler();
  AdcHandle.Init.ClockPrescaler        = ADC_CLOCK_SYNC_PCLK_DIV4;      /* Synchronous clock mode, input ADC clock with prscaler 2 */
  AdcHandle.Init.Resolution            = ADC_RESOLUTION_12B;            /* 12-bit resolution for converted data */
  AdcHandle.Init.DataAlign             = ADC_DATAALIGN_RIGHT;           /* Right-alignment for converted data */
  AdcHandle.Init.ScanConvMode          = ADC_SCAN_DIRECTION_FORWARD;    /* Sequencer disabled (ADC conversion on only 1 channel: channel set on rank 1) */
  AdcHandle.Init.EOCSelection          = ADC_EOC_SINGLE_CONV;           /* EOC flag picked-up to indicate conversion end */
  AdcHandle.Init.LowPowerAutoPowerOff  = DISABLE;
  AdcHandle.Init.LowPowerAutoWait      = DISABLE;                       /* Auto-delayed conversion feature disabled */
  AdcHandle.Init.ContinuousConvMode    = ENABLE;                        /* Continuous mode enabled (automatic conversion restart after each conversion) */
  AdcHandle.Init.DiscontinuousConvMode = DISABLE;                       /* Parameter discarded because sequencer is disabled */
  AdcHandle.Init.ExternalTrigConv      = ADC_SOFTWARE_START;            /* Software start to trig the 1st conversion manually, without external event */
  AdcHandle.Init.ExternalTrigConvEdge  = ADC_EXTERNALTRIGCONVEDGE_NONE; /* Parameter discarded because software trigger chosen */
  AdcHandle.Init.DMAContinuousRequests = ENABLE;                        /* ADC DMA continuous request to match with DMA circular mode */
  AdcHandle.Init.Overrun               = ADC_OVR_DATA_OVERWRITTEN;      /* DR register is overwritten with the last conversion result in case of overrun */
  AdcHandle.Init.SamplingTimeCommon    = ADC_SAMPLETIME_239CYCLES_5;
  /* Initialize ADC peripheral according to the passed parameters */
  if (HAL_ADC_Init(&AdcHandle) != HAL_OK)
    Error_Handler();
  /* ### - 2 - Start calibration ############################################ */
  if (HAL_ADCEx_Calibration_Start(&AdcHandle) != HAL_OK)
    Error_Handler();
  /* ### - 3 - Channel configuration ######################################## */
  sConfig.Channel      = ADCx_CHANNEL;               /* Channel to be converted */
  sConfig.Rank         = ADC_RANK_CHANNEL_NUMBER;
  if (HAL_ADC_ConfigChannel(&AdcHandle, &sConfig) != HAL_OK)
    Error_Handler();
  /* ### - 4 - Start conversion in DMA mode ################################# */
  if (HAL_ADC_Start_DMA(&AdcHandle,
                        (uint32_t *)aADCxConvertedData,
                       ) != HAL_OK)
    Error_Handler();
根据自带的例子  运行之后aADCxConvertedData    这个adc 的值一直为0   请各位大大看看什么问题
收藏收藏1 分享淘帖 顶顶1 踩踩
