查看: 2679|回复: 8
麻烦大家帮我看下单片机程序,百思不得其解啊,哪里错了?
#include <reg52.h>
unsigned char ledbuf[] = {0xfc,0xc,0xda,0xf2,0x66,0xb6};
unsigned char ledchar[] = {     0xfc,0xc,0xda,0xf2,0x66,0xb6,0xbe,0xe0,
                                0xfe,0xf6,0xee,0x3e,0x9c,0x7a,0x9e,0x8e };
void ledscan();
void init_interrupt0(unsigned char ms);
unsigned char th0 = 0;
unsigned char tl0 = 0;
int main()
        EA = 1;
        init_interrupt0(2);
        return 0;
        unsigned long tmp ;
        tmp = 11059200 / 12;
        tmp = (ms * tmp) / 1000;
        tmp = 65536 - tmp;
        th0 = (unsigned char)(tmp>>8);
        tl0 = (unsigned char)tmp;
        TMOD &= 0xf0;
        TMOD |= 0x01;
        TH0 = th0;
        TL0 = tl0;
        TR0 = 1;
        ET0 = 1;
void ledscan()
        static unsigned char i =0;
        P0 = 0x00;
        P1 = (P1 & 0xf8) | i;
        P0 = ledbuf;
        if(i < 5)
                i++;
                i = 0;
void interrupt_0() interrupt 1
        TH0 = th0;
        TL0 = tl0;
        ledscan();
程序的目的只是为了单纯的动态刷新显示几个数,现在现象是,一开始显示六位数,显示一会后就自动跳变为只剩一位数显示了。
ID:100982 发表于 2021-9-28 11:13 | 只看该作者
#include <reg52.h>
unsigned char ledbuf[6] = {0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char key_sta[] = {1,1,1,1};
sbit key1 = P2^4;
sbit key2 = P2^5;
sbit key3 = P2^6;
sbit key4 = P2^7;
bit watch_running = 0;
void ledscan();
void init_interrupt0(unsigned int ms);
void keydriver();
void keyscan();
void count_time();
void watch_show();
void watch_close();
void watch_reset();
unsigned char t0_high = 0;
unsigned char t0_low = 0;
unsigned char decimal = 0;
unsigned int integer = 0;
int main()
        EA = 1;
        init_interrupt0(2);
        P2 = 0xfe;
                watch_show();
                keydriver();
        return 0;
        unsigned long tmp;
        tmp = 65536 - tmp;
        t0_high = (unsigned char)(tmp>>8);
        t0_low = (unsigned char)tmp;
        TMOD &= 0xf0;
        TMOD |= 0x01;
        TH0 = t0_high;
        TL0 = t0_low;
        TR0 = 1;
        ET0 = 1;
void watch_show()
          unsigned char buf[4];
          signed char i = 0;
          ledbuf[5] = ledchar[decimal % 10];
          ledbuf[4] = ledchar[decimal / 10];
          buf[0] = integer % 10;
          buf[1] = (integer / 10) % 10;
          buf[2] = (integer / 100) %10;
          buf[3] = (integer / 1000) % 10;
          for(i = 3;i >= 1;i--)
                  if(buf[i] == 0)
                        ledbuf[3 - i] = 0x00;
                        break;
          for(;i >= 0;i--)
                  ledbuf[3 - i] = ledchar[buf[i]];
          ledbuf[3] |= 0x01;
void watch_close()
        decimal = 0;
        integer = 0;
        watch_running = 0;
void watch_reset()
        if( watch_running == 1)
                 watch_running = 0;
        else if( watch_running == 0)
                 watch_running = 1;
void keydriver()
        static unsigned char backup[] = {1,1,1,1};
        unsigned char i = 0;
        for(i = 0; i < 4;i++)
                if(backup[i] != key_sta[i])
                        if(backup[i] == 0)
                                if(i == 0)
                                        watch_close();
                                else if(i == 1)
                                        watch_reset();
                        backup[i] = key_sta[i];
void ledscan()
        static unsigned char i = 0;
        P0 = 0x00;
        P0 = ledbuf[i];
        if(i < 5)
                i++;
                i = 0;
void keyscan()
        static unsigned char keybuf[] = {0xff,0xff,0xff,0xff};
        keybuf[0] = (keybuf[0] << 1) | key1;
        keybuf[1] = (keybuf[1] << 1) | key2;
        keybuf[2] = (keybuf[2] << 1) | key3;
        keybuf[3] = (keybuf[3] << 1) | key4;
        for(i = 0;i < 4;i++)
                if(keybuf[i] == 0x00)
                        key_sta[i] = 0;
                else if(keybuf[i] == 0xff)
                        key_sta[i] = 1;
void count_time()
        if(watch_running)
                decimal++;
                if(decimal >= 100)
                        decimal = 0;
                        integer++;
                        if(integer >= 10000)
                                integer = 0;
void interrupt0() interrupt 1
        static unsigned char ms10 = 0;
        TH0 = t0_high;
        TL0 = t0_low;
        ledscan();
        keyscan();
        ms10++;
        if(ms10 >= 5)
                count_time();
                ms10 = 0;
188610329 发表于 2021-9-25 19:18
当搞不清什么地方出问题的时候, 就不要搞太多虚头巴脑的东西。所有东西最简化,
TH0, TL0, 全用定值赋值 ...
这里没有问题 加了static
ID:100982 发表于 2021-9-28 11:12 | 只看该作者
谢谢大家啊,搞定了,本来是写一个秒表程序的,在这里测试数码管的时候就出错了,现在秒表改好了,我把程序发上来
ID:419909 发表于 2021-9-26 07:40 | 只看该作者
static 的变量只在第一次进入时定义。后面就会保存了的。这个变量没问题的。
ID:161164 发表于 2021-9-25 22:11 | 只看该作者
i = 0: P1 = XXXXX000
i = 1: P1 = XXXXX001
i = 2: P1 = XXXXX010
i = 3: P1 = XXXXX011
i = 4: P1 = XXXXX100
i = 5: P1 = XXXXX101
ID:213173 发表于 2021-9-25 21:22 | 只看该作者
注释掉的语句都是错误的
  1. #include <reg52.h>
  2. unsigned char ledbuf[] = {0xfc,0x60,0xda,0xf2,0x66,0xb6};
  3. //unsigned char ledbuf[] = {0xfc,0xc,0xda,0xf2,0x66,0xb6};
  4. unsigned char ledchar[] = {     0xfc,0xc,0xda,0xf2,0x66,0xb6,0xbe,0xe0,
  5.                                 0xfe,0xf6,0xee,0x3e,0x9c,0x7a,0x9e,0x8e };
  6. void ledscan();
  7. void init_interrupt0(unsigned char ms);
  8. unsigned char th0 = 0;
  9. unsigned char tl0 = 0;
  10. int main()
  11. {
  12.         EA = 1;
  13.         init_interrupt0(2);
  14.
  15.         while(1);
  16.
  17.         return 0;
  18. }
  19. void init_interrupt0(unsigned char ms)
  20. {
  21.         unsigned long tmp ;
  22.         tmp = 11059200 / 12;
  23.         tmp = (ms * tmp) / 1000;
  24.         tmp = 65536 - tmp;
  25.         th0 = (unsigned char)(tmp>>8);
  26.         tl0 = (unsigned char)tmp;
  27.         TMOD &= 0xf0;
  28.         TMOD |= 0x01;
  29.         TH0 = th0;
  30.         TL0 = tl0;
  31.         TR0 = 1;
  32.         ET0 = 1;
  33.
  34. }
  35. void ledscan()
  36. {
  37.         static unsigned char i =0;
  38.         P0 = 0x00;
  39. //        P1 = (P1 & 0xf8) | i;
  40.         P1 =        ~(1<<i);
  41.         P0 = ledbuf[i];
  42.         if(i < 5)
  43.         {
  44.                 i++;
  45.         }
  46.         else
  47.         {
  48.                 i = 0;
  49.         }
  50. }
  51. void interrupt_0() interrupt 1
  52. {
  53.         TH0 = th0;
  54.         TL0 = tl0;
  55.         ledscan();
  56. }
ID:624769 发表于 2021-9-25 19:18 | 只看该作者
TH0, TL0, 全用定值赋值后,测试一下有没有问题。
也不要搞什么函数调用,尤其自己都不知道是什么,怎么用的函数。老老实实一行行代码,自己也容易理解人家也容易理解。
void ledscan()
这个子函数, 进去 i = 0; 你后面 那些if 根本没有意义。每次进去都是 i 都会变成 0 根本不会变。
ID:451718 发表于 2021-9-25 17:32 | 只看该作者
tmp = (ms * tmp) / 1000;  你这里除以1000是什么操作?  如果要除以1000, 你那个ms的值应该取10为单位的值吧?
