查看: 6802|回复: 2
单片机控制数模转换芯片DAC0832产生正弦波、方波、三角波、梯形波和锯齿波。
Proteus的原理电路见图1。单片机P1.0~ P1.4接有5个按键,当按键按下时,分别对应产生正弦波、方波、三角波、梯形波和锯齿波。
  1. #include<reg51.h>
  2. sbit wr=P3^6;
  3. sbit rd=P3^2;
  4. sbit key0=P1^0;              //定义P1.0脚的按键为正弦波键key0
  5. sbit key1=P1^1;              //定义P1.1脚的按键为方波键key1
  6. sbit key2=P1^2;                //定义P1.2脚的按键为三角波键key2
  7. sbit key3=P1^3;             //定义P1.3脚的按键为梯形波键key3
  8. sbit key4=P1^4;             //定义P1.3脚的按键为锯齿波键key4
  9. unsigned char flag;          //flag为1、2、3、4、5时对应正弦波、方波、
  10.                                            //三角波、梯形波、锯齿波
  11. unsigned char const code  //以下为正弦波采样点数组256个数据
  12. SIN_code[256]={0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,
  13. 0xab,0xae,0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,
  14. 0xd8,0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf4,
  15. 0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
  16. 0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,
  17. 0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe3,0xe1,0xde,0xdc,0xda,0xd8,0xd6,
  18. 0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb4,0xb1,0xae,0xab,0xa8,
  19. 0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x92,0x8f,0x8c,0x89,0x86,0x83,0x80,0x7d,0x79,0x76,0x73,
  20. 0x70,0x6d,0x6a,0x67,0x64,0x61,0x5e,0x5b,0x58,0x55,0x52,0x4f,0x4c,0x49,0x46,0x43,0x41,
  21. 0x3e,0x3b,0x39,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,
  22. 0x17,0x15,0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,0x3,0x3,0x2,0x1,0x1,
  23. 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,0x7,0x8,
  24. 0x9,0xa,0xc,0xd,0xe,0x10,0x12,0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,0x25,0x27,
  25. 0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,0x3d,0x40,0x43,0x46,0x48,0x4b,0x4e,0x51,0x54,
  26. 0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x73,0x76,0x79,0x7c};
  27. unsigned char keyscan()                  //键盘扫描函数
  28. {
  29.    unsigned charkeyscan_num,temp;
  30.    P1=0xff;                     // P1口输入
  31.    temp=P1;                   //从P1口读入键值,存入temp中
  32.   if(~(temp&0xff))                //判是否有键按下,即键值不为0xff,则有键按下
  33.    {                            //~按位取反
  34.           if(key0==0)        //产生正弦波的按键按下,P1.0=0
  35.           {
  36.                      keyscan_num=1;            //得到的键值为1,表示产生正弦波
  37.            }
  38.           else if(key1==0)             //产生方波的按键按下,P1.1=0
  39.           {
  40.                      keyscan_num=2;          //得到键值为2,表示产生方波
  41.         }
  42.        elseif(key2==0)              //产生三角波的按键按下, P1.2=0
  43.        {
  44.        keyscan_num=3;          //得到的键值为3,表示产生三角波
  45.        }
  46.        elseif(key3==0)             //产生梯形波的按键按下,P1.3=0
  47.        {
  48.        keyscan_num=4;          //得到的键值为4,表示产生梯形波
  49.        }
  50.        elseif(key4==0)              //产生锯齿波的按键按下, P1.3=0
  51.        {
  52.         keyscan_num=5;         //得到的键值为5,表示产生锯齿波
  53.        }
  54.        else
  55.        {  keyscan_num=0;      //没有按键按下,键值为0
  56.        }
  57.        returnkeyscan_num;     //得到的键值返回
  58.    }
  59. }
  60. void init_DA0832()
  61. {
  62.        rd=0;
  63.        wr=0;
  64. }
  65. void SIN()
  66. {
  67.        unsignedint i;
  68.        i=0;
  69.        do{
  70.               P2=SIN_code[ i];
  71.               i=i+1;
  72.               }while(i<256);
  73. }
  74. void Square()
  75. {
  76.         EA=1;
  77.         ET0=1;
  78.         TMOD=1;
  79.         TH0=0xff;
  80.         TL0=0x83;
  81.         TR0=1;
  82. }
  83. void Triangle()
  84. {
  85.        P2=0x00;
  86.        do{
  87.               P2=P2+1;
  88.               }while(P2<0xff);
  89.               P2=0xff;
  90.        do{
  91.               P2=P2-1;
  92.               }while(P2>0x00);
  93.               P2=0x00;
  94. }
  95. void Sawtooth()
  96. {
  97.        P2=0x00;
  98.        do{
  99.               P2=P2+1;
  100.               }while(P2<0xff);
  101. }
  102. void Trapezoidal()
  103. {
  104.        unsignedchar i;
  105.        P2=0x00;
  106.        do{
  107.               P2=P2+1;
  108.        }while(P2<0xff);
  109.        P2=0xff;
  110.        for(i=255;i>0;i--)
  111.        {
  112.               P2=0xff;
  113.        }
  114.        do{
  115.               P2=P2-1;
  116.        }while(P2>0x00);
  117.        P2=0x00;
  118. }
  119. void main()
  120. {
  121.        init_DA0832();
  122.        do
  123.        {
  124.               flag=keyscan();
  125.        }while(!flag);
  126.   while(1)
  127.   {
  128.      switch(flag)
  129.        {
  130.        case 1:
  131.        do{
  132.               flag=keyscan();
  133.               SIN();
  134.        }while(flag==1);
  135.               break;
  136.        case 2:
  137.               Square();
  138.        do{
  139.               flag=keyscan();
  140.        }while(flag==2);
  141.               TR0=0;
  142.        break;
  143.        case 3:
  144.        do{
  145.               flag=keyscan();
  146.               Triangle();
  147.        }while(flag==3);
  148.               break;
  149.        case 4:
  150.        do{
  151.               flag=keyscan();
  152.               Trapezoidal();
  153.          }while(flag==4);
  154.          break;
  155.        case 5:
  156.        do{
  157.               flag=keyscan();
  158.               Sawtooth();
  159.          }while(flag==5);
  160.          break;
  161.        default:
  162.          flag=keyscan();
  163.          break;
  164.        }
  165.   }
  166. }
  167. void timer0(void) interrupt 1
  168. {
  169.        P2=~P2;
  170.        TH0=0xff;
  171.        TL0=0x83;
  172.        TR0=1;
  173. }
正弦波
方波
三角波
梯形波
锯齿波
收藏收藏4 分享淘帖 顶 踩
ID:836198 发表于 2020-11-1 16:01 | 只看该作者
请问有压缩包吗?
ID:1051324 发表于 2022-12-3 17:22 来自触屏版 | 只看该作者
请问一下这里显示着Pin‘ON1’ is not modelled,Pin'ON2' is not modelled,这该怎么改
