查看: 5577|回复: 7
单片机超声波测距仪Proteus7.5仿真程序 数码管显示
采用51单片机+超声波模块
提供了另外一种超声波测速及其程序仿真文件
超声波模块电路连接
Trig -------  P2^1;
Echo -------  P2^0;
VCC  -------- +5v
GND  -------- GND
void Conut(void)   //距离数据处理函数
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.7)/100;     //算出来是CM
         if((S>=700)||flag==1) //超出测量范围显示“-”
          flag=0;
          DisplayOneChar(0, 1, ASCII[11]);
          DisplayOneChar(1, 1, ASCII[10]);        //显示点
          DisplayOneChar(2, 1, ASCII[11]);
          DisplayOneChar(3, 1, ASCII[11]);
          DisplayOneChar(4, 1, ASCII[12]);        //显示M
          disbuff[0]=S%1000/100;
          disbuff[1]=S%1000%100/10;
          disbuff[2]=S%1000%10 %10;
          DisplayOneChar(0, 1, ASCII[disbuff[0]]);
          DisplayOneChar(2, 1, ASCII[disbuff[1]]);
          DisplayOneChar(3, 1, ASCII[disbuff[2]]);
//中断函数
void zd0() interrupt 1                  //T0中断用来计数器溢出,超过测距范围
    flag=1;                                                         //中断溢出标志
//主函数
void main(void)
         TMOD=0x01;                   //设T0为方式1,GATE=1;
         TH0=0;
         TL0=0;
         ET0=1;             //允许T0中断
         EA=1;                           //开启总中断
        InitLcd1602();
        LcdShowStr(0,0,PuZh);
                 StartModule();
             while(!Echo);                //当RX为零时等待
             TR0=1;                            //开启计数
             while(Echo);                        //当RX为1计数并等待
             TR0=0;                                //关闭计数
         Conut();                        //计算
                 delayms(80);
LCD1602显示函数
void Read_Busy()           //忙检测函数,判断bit7是0,允许执行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,释放总线
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd)     //写命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //写数据
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐标显示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置显示一个字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
        X |= 0x80; //算出指令码
        Lcd1602_Write_Cmd(X); //发命令字
        Lcd1602_Write_Data(DData); //发数据
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //显示字符串
    LcdSetCursor(x,y);      //当前字符的坐标
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打开,5*8,8位数据
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
全部资料51hei下载地址:
仿真代码.7z (156.31 KB, 下载次数: 146)
收藏收藏3 分享淘帖 顶 踩
ID:903863 发表于 2021-4-11 15:58 | 只看该作者
楼主右下角那个是什么?
ID:827454 发表于 2021-4-21 11:48 | 只看该作者
蓝精灵. 发表于 2021-4-11 15:58
楼主右下角那个是什么?
超声波模块
ID:827454 发表于 2021-4-21 11:49 | 只看该作者
楼主右下角那个是什么?
超声波模块,按键控制距离
ID:924160 发表于 2021-5-19 22:33 | 只看该作者
楼主可以给个Proteus8.0的仿真吗? 压缩包的这个dsn文件只能用7.5版本的打开,,而我只安装了8.0的软件
ID:74293 发表于 2021-5-25 19:01 | 只看该作者
楼主,超声波模块那个怎么设置起始距离?我这怎么一开机就是200多CM
ID:1053360 发表于 2022-11-22 16:21 | 只看该作者
楼主 HC-SR04.hex文件的作用是什么?
ID:987283 发表于 2022-11-28 17:12 | 只看该作者
兄弟你的解决了没有,我也是这,要是解决了的话发我一份呗
