查看: 3273|回复: 23
99分钟倒计时为什么显示00?附单片机程序
ID:72649 发表于 2023-9-21 04:36 | 显示全部楼层 |阅读模式
//99分倒计时
#include"stc8.h"
#include"intrins.h"
#define  uint unsigned int
#define  uchar unsigned char
uchar A1,A2,count,second,min;
sbit ge = P1^1;
sbit shi = P1^0;
sbit LIGHT_JDQ = P3^7;
uchar code table[]={
        0x03,/*0*/
        0x9F,/*1*/
        0x25,/*2*/
        0x0D,/*3*/
        0x99,/*4*/
        0x49,/*5*/
        0x41,/*6*/
        0x1F,/*7*/
        0x01,/*8*/
        0x09,/*9*/};
//sbit a = P2^7;
//sbit b = P2^6;
//sbit c = P2^5;
//sbit d = P2^4;
//sbit e = P2^3;
//sbit f = P2^2;
//sbit g = P2^1;
//sbit h = P2^0;
//sbit LED_com = P3^1;
void IO_init();
void delay(uchar i);
void T0_init();
void display(uchar sh_c,uchar g_c);
void IO_init()
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
void delay(uchar n)
        uchar j,k;
  for(j=n;j>0;j--)
    for(k=125;k>0;k--);
void T0_init()
                AUXR |= 0x80;                        //定时器时钟1T模式
                TMOD &= 0xF0;                        //设置定时器模式
                TL0 = 0xD7;                                //设置定时初始值50us
                TH0 = 0xFD;                                //设置定时初始值
    TR0 = 1;                                    //启动定时器
    ET0 = 1;                                    //使能定时器中断
    EA = 1;
   P2=0;
   P2=table[sh_c];
   ge = 0;
         shi = 1;
   delay(5);
   P2=0;
   P2=table[g_c];
   shi = 0;
         ge = 1;
   delay(5);
                 IO_init();
                 T0_init();
                                         if(count = 0)
                      count = 20;
                second--;
                if(second = 0)
                      second = 60;
                                        min--;
                                        if(min = 0)
                                        min=99;
         A1=min/10;
         A2=min%10;
                                 display(A1,A2);
void TM0_Isr() interrupt 1
            count--;
ID:584814 发表于 2023-9-21 09:12 | 显示全部楼层
每次进中断都会进行初始化
ID:466505 发表于 2023-9-21 09:23 | 显示全部楼层
if(count = 0)  后面还有一个  if(second = 0)
ID:1064915 发表于 2023-9-21 09:57 | 显示全部楼层
设置定时初始值50us
count = 20;
50us×20=1000us=1ms
TL0 = 0x00;                                //设置定时初始值5ms
TH0 = 0x28;                                //设置定时初始值
ID:213173 发表于 2023-9-21 11:35 | 显示全部楼层
问题比较多,给你改了。
  1. //99分倒计时
  2. #include"stc8.h"
  3. #include "intrins.h"
  4. #define  uint unsigned int
  5. #define  uchar unsigned char
  6. sbit ge = P1^1;
  7. sbit shi = P1^0;
  8. sbit LIGHT_JDQ = P3^7;
  9. uchar count;
  10. char sec,min;
  11. bit flag;
  12. uchar code table[]={
  13.         0x03,/*0*/
  14.         0x9F,/*1*/
  15.         0x25,/*2*/
  16.         0x0D,/*3*/
  17.         0x99,/*4*/
  18.         0x49,/*5*/
  19.         0x41,/*6*/
  20.         0x1F,/*7*/
  21.         0x01,/*8*/
  22.         0x09,/*9*/};
  23. //sbit a = P2^7;
  24. //sbit b = P2^6;
  25. //sbit c = P2^5;
  26. //sbit d = P2^4;
  27. //sbit e = P2^3;
  28. //sbit f = P2^2;
  29. //sbit g = P2^1;
  30. //sbit h = P2^0;
  31. //sbit LED_com = P3^1;
  32.
  33. void IO_init();
  34. //void delay(uchar i);
  35. void T0_init();
  36. void display();
  37.
  38. void IO_init()
  39. {
  40.         P0M0 = 0x00;
  41.         P0M1 = 0x00;
  42.         P1M0 = 0x00;
  43.         P1M1 = 0x00;
  44.         P2M0 = 0x00;
  45.         P2M1 = 0x00;
  46.         P3M0 = 0x00;
  47.         P3M1 = 0x00;
  48.         P4M0 = 0x00;
  49.         P4M1 = 0x00;
  50.         P5M0 = 0x00;
  51.         P5M1 = 0x00;
  52. }
  53. /*
  54. void delay(uchar n)
  55. {
  56.         uchar j,k;
  57.         for(j=n;j>0;j--)
  58.                 for(k=125;k>0;k--);
  59. }*/
  60. void T0_init()                                //5毫秒@11.0592MHz
  61. {
  62.         AUXR &= 0x7F;                        //定时器时钟12T模式
  63.         TMOD &= 0xF0;                        //设置定时器模式
  64.         TMOD |= 0x01;                        //设置定时器模式
  65.         TL0 = 0x00;                                //设置定时初始值
  66.         TH0 = 0xEE;                                //设置定时初始值
  67.         TF0 = 0;                                //清除TF0标志
  68.         TR0 = 1;                                //定时器0开始计时
  69.         ET0 = 1;                                //使能定时器0中断
  70.         EA = 1;
  71. }
  72. void display()
  73. {
  74.         static bit i=0;
  75.         static uchar temp=0;
  76.         P2=0xff;
  77.         i=~i;
  78.         if(++temp>=200)temp=0;
  79.         if(i==1)
  80.         {
  81.                 ge  = 0;
  82.                 shi = 1;
  83.                 P2=table[min/10];
  84.         }
  85.         else
  86.         {
  87.                 ge  = 1;
  88.                 shi = 0;
  89.                 if(temp<100)
  90.                         P2=table[min%10]&0xfe;//闪秒
  91.                 else P2=table[min%10];
  92.         }
  93.
  94. }
  95. void main()
  96. {
  97.         IO_init();
  98.         T0_init();
  99.
  100.         while(1)
  101.         {
  102.                 if(flag)
  103.                 {
  104.                         flag=0;
  105.                         if(++count >= 200)
  106.                         {
  107.                                 count = 0;
  108.                                 sec--;
  109.                                 if(sec < 0)
  110.                                 {
  111.                                         sec = 59;
  112.                                         min--;
  113.                                         if(min < 0)
  114.                                                 min=99;
  115.                                 }
  116.                         }
  117.                         display();
  118.                 }
  119.         }
  120. }
  121.
  122. void TM0_Isr() interrupt 1 //5毫秒
  123. {
  124.         TL0 = 0x00;                                //设置定时初始值
  125.         TH0 = 0xEE;                                //设置定时初始值
  126.         flag=1;
  127. }
ID:72649 发表于 2023-9-21 12:31 | 显示全部楼层
joyb 发表于 2023-9-21 09:57
设置定时初始值50us
count = 20;
50us×20=1000us=1ms
    TL0 = 0x66;                                 //65536-11.0592M/12/1000
    TH0 = 0xfc;
这样设置也不行啊
man1234567 发表于 2023-9-21 09:12
每次进中断都会进行初始化
应该怎样修改
ID:72649 发表于 2023-9-21 12:33 | 显示全部楼层
中断计数到了一秒,秒继续计数到一分钟啊。怎样修改?
ID:72649 发表于 2023-9-21 12:47 | 显示全部楼层
每次进中断都会进行初始化
//    TL0 = 0x66;                                 //65536-11.0592M/12/1000
//    TH0 = 0xfc;                               //设置定时初始值
            count--;
}  屏蔽了也不行
ID:466505 发表于 2023-9-21 14:35 | 显示全部楼层
你if后面括号里是赋值不是比较啊,,相当每个循环执行一次,定时器压根没用
ID:72649 发表于 2023-9-25 06:32 来自触屏版 | 显示全部楼层
wulin 发表于 2023-9-21 11:35
问题比较多,给你改了。
测试了你的代码,应该是9分钟倒计时,怎么改为99分钟倒计时。
ID:72649 发表于 2023-11-23 22:09 | 显示全部楼层
问题比较多,给你改了。
参考你的代码修改为四位倒计时(99:59倒计时),哪里不对?下面是代码:
//99:59分倒计时
#include"stc8H.h"
uchar count;
char sec,min;
bit flag,flag1,flag2,flag3;
sbit time_ge  = P1^3;
sbit time_shi  = P1^2;
sbit time_bai  = P1^1;
sbit time_qian  = P1^0;
sbit temp_ge  = P3^3;
sbit temp_shi  = P1^5;
sbit temp_bai  = P1^4;
        0x03,/*0*/
        0x9F,/*1*/
        0x25,/*2*/
        0x0D,/*3*/
        0x99,/*4*/
        0x49,/*5*/
        0x41,/*6*/
        0x1F,/*7*/
        0x01,/*8*/
        0x09,/*9*/};
void GPIO_init();
void T0_init() ;
void time_display();
void time_daojishi();
void GPIO_init()
    P0M0 = 0x00; P0M1 = 0x00;
    P1M0 = 0x00; P1M1 = 0x00;
    P2M0 = 0x00; P2M1 = 0x00;
    P3M0 = 0x00; P3M1 = 0x00;
    P5M0 = 0x00; P5M1 = 0x00;
        TF0 = 0;                                //清除TF0标志
        TR0 = 1;                                //定时器0开始计时
        ET0 = 1;                                //使能定时器0中断
void time_display()
        static bit i=0;
        P2=0xff;
        i=~i;
        if(i==1)
                time_ge  = 0;
                time_shi = 1;
                                              time_bai  = 1;
                time_qian  = 1;
                P2=table[min/10];
         else if(i==2)
                time_ge  = 1;
                time_shi = 0;
                                              time_bai  = 1;
                time_qian  = 1;
                if(temp<100)
//                else P2=table[min%10];
                                else if(i==3)
                time_ge  = 1;
                time_shi = 1;
                                              time_bai  = 0;
                time_qian  = 1;
                if(temp<60)
                P2=table[sec/10];
                                else if(i==4)
                time_ge  = 1;
                time_shi = 1;
                                              time_bai  = 0;
                time_qian  = 1;
                if(temp<60)
                P2=table[sec%10]&0xfe;//闪秒
                GPIO_init();
                T0_init();
                P2=table[8];
                temp_ge  = 0;
                temp_shi  = 0;
                //temp_bai  = 0;
        if(flag)
        flag=0;
        if(++count >= 200)
        count = 0;
        sec--;
        if(sec < 0)
        sec = 59;
        min--;
        if(min < 0)
        min=99;
        display();
void TM0_Isr() interrupt 1 //5毫秒定时器0
        flag=1;
ID:161164 发表于 2023-11-24 09:12 | 显示全部楼层
//99:59分倒计时
#include"stc ...
为啥把显示函数名改了?
STC8的定时器模式0是16位自动重装的
中断函数里那两句设置定时初始值可以不要
ID:213173 发表于 2023-11-24 09:28 | 显示全部楼层
//99:59分倒计时
#include"stc ...
  1. #include"stc8H.h"
  2. #include "intrins.h"
  3. #define  uint unsigned int
  4. #define  uchar unsigned char
  5. uchar count;
  6. char sec,min;
  7. bit flag;
  8. uchar code table[]={
  9. 0x03,/*0*/
  10. 0x9F,/*1*/
  11. 0x25,/*2*/
  12. 0x0D,/*3*/
  13. 0x99,/*4*/
  14. 0x49,/*5*/
  15. 0x41,/*6*/
  16. 0x1F,/*7*/
  17. 0x01,/*8*/
  18. 0x09,/*9*/};
  19. void GPIO_init();
  20. void T0_init() ;
  21. void time_display();
  22. void GPIO_init()
  23. {
  24.         P0M0 = 0x00; P0M1 = 0x00;
  25.         P1M0 = 0x00; P1M1 = 0x00;
  26.         P2M0 = 0x00; P2M1 = 0x00;
  27.         P3M0 = 0x00; P3M1 = 0x00;
  28.         P5M0 = 0x00; P5M1 = 0x00;
  29. }
  30. void T0_init(void)                //5毫秒@11.0592MHz
  31. {
  32.         AUXR &= 0x7F;                        //定时器时钟12T模式
  33.         TMOD &= 0xF0;                        //设置定时器模式
  34.         TMOD |= 0x01;                        //设置定时器模式
  35.         TL0 = 0x00;                                //设置定时初始值
  36.         TH0 = 0xEE;                                //设置定时初始值
  37.         TF0 = 0;                                //清除TF0标志
  38.         TR0 = 1;                                //定时器0开始计时
  39.         ET0 = 1;                                //使能定时器0中断
  40.         EA  = 1;                                //使能总中断
  41. }
  42. void time_display()
  43. {
  44.         static uchar i=0;
  45.         P1&=0xf0;
  46.         switch(i)
  47.         {
  48.                 case 0: P2=table[min/10]; break;
  49.                 case 1: P2=table[min%10]&0xfe; break;
  50.                 case 2: P2=table[sec/10]; break;
  51.                 case 3: P2=table[sec%10]; break;
  52.         }
  53.         P1|=0x01<<i;
  54.         i=++i%4;
  55. }
  56. void main()
  57. {
  58.         GPIO_init();
  59.         T0_init();
  60.         while(1)
  61.         {
  62.                 if(flag)
  63.                 {
  64.                         flag=0;
  65.                         time_display();
  66.                         if(++count >= 200)
  67.                         {
  68.                                 count = 0;
  69.                                 if(--sec < 0)
  70.                                 {
  71.                                         sec = 59;
  72.                                         if(--min < 0)
  73.                                                 min=99;
  74.                                 }
  75.                         }
  76.                 }
  77.         }
  78. }
  79. void TM0_Isr() interrupt 1 //5毫秒定时器0
  80. {
  81.         TL0 = 0x00;  //设置定时初始值
  82.         TH0 = 0xEE;  //设置定时初始值
  83.         flag=1;
  84. }
ID:72649 发表于 2023-11-24 11:52 | 显示全部楼层
lkc8210 发表于 2023-11-24 09:12
为啥把显示函数名改了?
中断函数里那两句设置定时初始值可以不要
//99:59分倒计时
#include"stc8H.h"
uchar count;
char sec,min;
        0x03,/*0*/
        0x9F,/*1*/
        0x25,/*2*/
        0x0D,/*3*/
        0x99,/*4*/
        0x49,/*5*/
        0x41,/*6*/
        0x1F,/*7*/
        0x01,/*8*/
        0x09,/*9*/};
void GPIO_init();
void T0_init() ;
void GPIO_init()
        TF0 = 0;                                //清除TF0标志
        TR0 = 1;                                //定时器0开始计时
        ET0 = 1;                                //使能定时器0中断
void time_display()
        static bit i=0;
        P2=0xff;
        i=~i;
        if(i==1)
                time_ge  = 0;
                time_shi = 1;
                time_bai  = 1;
                time_qian  = 1;
                P2=table[min/10];
         else if(i==2)
                time_ge  = 1;
                time_shi = 0;
                 time_bai  = 1;
                time_qian  = 1;
                if(temp<100)
         else if(i==3)
                time_ge  = 1;
                time_shi = 1;
                time_bai  = 0;
                time_qian  = 1;
                if(temp<60)
                P2=table[sec/10];
         else if(i==4)
                time_ge  = 1;
                time_shi = 1;
                 time_bai  = 0;
                time_qian  = 1;
                if(temp<60)
            EA = 1;
      GPIO_init();
      T0_init();
          if(flag)
                                                         flag=0;
                                                         if(++count >= 200)
        {count = 0;
        sec--;
        if(sec < 0)
        sec = 59;
        min--;
        if(min < 0)
        min=99;
        time_display();
        flag=1;
ID:72649 发表于 2023-11-24 12:24 | 显示全部楼层
这个代码9999和8888交替显示
ID:72649 发表于 2023-11-24 12:33 | 显示全部楼层
       这里这样修改对吗?
        P1|=0xfe<<i;
        i=++i%4;
P1|=0xfe<<i; i=++i%4;
ID:72649 发表于 2023-11-24 12:36 | 显示全部楼层
hjx5548 发表于 2023-11-24 12:24
这个代码9999和8888交替显示
应该这样的
ID:72649 发表于 2023-11-24 13:02 | 显示全部楼层
数码管显示乱码
ID:213173 发表于 2023-11-24 13:11 | 显示全部楼层
这样改
void time_display()
        static uchar i=0;
        P1|=0xff;
        switch(i)
        P1&=~(0x01<<i);
        i=++i%4;
ID:72649 发表于 2023-11-24 21:26 | 显示全部楼层
wulin 发表于 2023-11-24 13:11
这样改
void time_display()
分钟十位数不能显示
ID:213173 发表于 2023-11-25 06:49 | 显示全部楼层
hjx5548 发表于 2023-11-24 21:26
分钟十位数不能显示
检查软件端口定义与实际电路是否相符
ID:213173 发表于 2023-11-25 08:11 | 显示全部楼层
hjx5548 发表于 2023-11-24 12:33
这里这样修改对吗?
        P1|=0xfe
你提供的两个图不一样。如果按这个图的接线,数码管程序应该这样写
void time_display()
        static uchar i=0;
        P1|=0xff;
        switch(i)
                case 0: P2=table[min/10];     P1&=0xfe; break;
                case 1: P2=table[min%10]&0xfe;P1&=0xfd; break;
                case 2: P2=table[sec/10];     P1&=0xf7; break;
                case 3: P2=table[sec%10];     P1&=0xfb; break;
        i=++i%4;
ID:72649 发表于 2023-11-25 10:24 | 显示全部楼层
void time_display()
显示正常了
