查看: 639|回复: 0
uart
ID:1166158 发表于 2025-12-31 15:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
int count = 0;
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
                if(HAL_GetTick() - count > 400)
                        count = HAL_GetTick();
                        HAL_UART_Transmit(&huart1, "ABCDE\r\n", sizeof("ABCDE\r\n") - 1, 1000);
  /* USER CODE END 3 */
