查看: 6726|回复: 12
基于STC89C52RC单片机制作的频率及占空比均可调程序
ID:280979 发表于 2019-11-5 22:37 | 显示全部楼层 |阅读模式
注意  单片机必须是52rc不能用60s2
#include"main.h"
#include"peizhi.h"
#include"smg.h"
#include"eeprom.h"
sfr WDT_CONTR=0XE1;
unsigned char HighRH = 0;  //高电平重载值的高字节
unsigned char HighRL = 0;  //高电平重载值的低字节
unsigned char LowRH  = 0;  //低电平重载值的高字节
unsigned char LowRL  = 0;  //低电平重载值的低字节
/***********************按键定义**********************************/
bit d1 = 1;
bit d2 = 1;
bit d3 = 1;
uint8 ci;
uint8 ca = 0;
uint8 ca1 = 0;
uint16 cb = 0;
void key();                 //按键函数声明
void ConfigPWM(unsigned int fr, unsigned char dc);  //频率和占空比调节函数
   bit q1 = 1;
   bit q2 = 1;
   bit q3 = 1;
   ca = EEPROMReadByte(0);
   cb = EEPROMReadByte(1)*255+EEPROMReadByte(2);
   EA = 1;       //开总中断
   peizhit1(1);  //配置T0定时2ms
                  ConfigPWM(cb, ca);    //频率100Hz,占空比10%
                  if(d1 != q1)
                          q1 = d1;
                        if(d1 == 0)
                                ca1++;
                                if(ca1 >= 2)
                                          ca1 = 0;
           if(ca1 == 1)
                  if(d2 != q2)
                                  q2 = d2;
                                if(d2 == 0)
                                        ca++;
                                        EEPROMSectorErase(0);
                                        EEPROMWriteByte(0,ca);
                                        EEPROMWriteByte(2,cb);
                                        EEPROMWriteByte(1,cb>>8);
                                        if(ca >= 99)
                                                ca = 99;
                          if(d3 != q3)
                                  q3 = d3;
                                if(d3 == 0)
                                        if(ca>0)
                                                ca--;
                if(ca1 == 0)
                          if(d2 == 0)
                                  cb++;
                                  if(cb >= 200)
                                                cb = 200;
                          if(d3 == 0)
                                        if(cb>0)
                                                cb--;
                xianshi1(cb);
                xianshi2(ca);
void key()
        static uint8 saomiaozhi[] = {1,1,1,1};
        saomiaozhi[0] = (saomiaozhi[0]<<1) | in1;
        saomiaozhi[1] = (saomiaozhi[1]<<1) | in2;
        saomiaozhi[2] = (saomiaozhi[2]<<1) | in3;
        if(saomiaozhi[0] == 0x00)
                d1 = 0;
        if(saomiaozhi[0] == 0xff)
                d1 = 1;
        if(saomiaozhi[1] == 0x00)
                d2 = 0;
        if(saomiaozhi[1] == 0xff)
                d2 = 1;
        if(saomiaozhi[2] == 0x00)
                d3 = 0;
        if(saomiaozhi[2] == 0xff)
                d3 = 1;
/* 配置并启动PWM,fr-频率,dc-占空比 */
    unsigned int  high, low;
    unsigned long tmp;
    tmp  = (11059200/12) / fr;  //计算一个周期所需的计数值
    high = (tmp*dc) / 100;      //计算高电平所需的计数值
    low  = tmp - high;          //计算低电平所需的计数值
    high = 65536 - high + 12;   //计算高电平的重载值并补偿中断延时
    low  = 65536 - low  + 12;   //计算低电平的重载值并补偿中断延时
    HighRH = (unsigned char)(high>>8); //高电平重载值拆分为高低字节
    HighRL = (unsigned char)high;
    LowRH  = (unsigned char)(low>>8);  //低电平重载值拆分为高低字节
    LowRL  = (unsigned char)low;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0为模式1
    TH0 = HighRH;   //加载T0重载值
    TL0 = HighRL;
    ET0 = 1;        //使能T0中断
    TR0 = 1;        //启动T0
    PWMOUT = 1;     //输出高电平
/* T0中断服务函数,产生PWM输出 */
void InterruptTimer0() interrupt 1
    if (PWMOUT == 1)  //当前输出为高电平时,装载低电平值并输出低电平
        TH0 = LowRH;
        TL0 = LowRL;
        PWMOUT = 0;
    else              //当前输出为低电平时,装载高电平值并输出高电平
        TH0 = HighRH;
        TL0 = HighRL;
        PWMOUT = 1;
/* T0中断服务函数,完成数码管、按键扫描与秒表计数 */
void t1() interrupt 3
    TH1 = T1RH;  //重新加载重载值
    TL1 = T1RL;
        ci++;
        ssmg();                 //数码管扫描
        if(ci>=2)
                ci = 0;
                key();
频率及占空比均可调带数码管模块完整程序.rar
198.16 KB, 下载次数: 108, 下载积分: 黑币 -5
频率及占空比均可调带数码管模块DXP资料.rar
931.35 KB, 下载次数: 79, 下载积分: 黑币 -5
ID:385637 发表于 2019-11-6 11:45 | 显示全部楼层
这个占空比与频率都可调,真是好资料,谢谢分享,
ID:225481 发表于 2019-11-6 13:12 | 显示全部楼层
可以用来做LED灯光调节,不错的资料。
ID:403593 发表于 2019-11-6 16:01 | 显示全部楼层
非常好的资料,感谢楼主分享!
ID:73030 发表于 2022-2-8 20:17 | 显示全部楼层
这个程序值得学习,谢谢作者分享。
ID:970519 发表于 2022-2-9 10:18 | 显示全部楼层
程序值得学习,谢谢作者分享
ID:138707 发表于 2022-2-28 16:41 | 显示全部楼层
ID:345506 发表于 2023-7-15 09:59 | 显示全部楼层
不错,不错, 很好学习,参考的资料
ID:298215 发表于 2025-6-4 22:23 | 显示全部楼层
谢谢分享,太好了
ID:145862 发表于 2025-6-6 09:27 | 显示全部楼层
vss是多少
ID:1107340 发表于 2025-9-26 10:35 | 显示全部楼层
请问大佬,pcbdoc文件如何打开?谢谢
ID:584814 发表于 2025-9-26 22:04 | 显示全部楼层
好资料,感谢楼主分享!
ID:1107340 发表于 2026-3-9 09:25 | 显示全部楼层
很好的学习,参考的资料,谢谢
