查看: 3600|回复: 0
DS2438引脚图与pdf数据手册下载
ID:447740 发表于 2020-6-27 10:58 | 显示全部楼层 |阅读模式
DS2438 网上资料特别少,这里上传一个厂家的数据手册,有很大的参考价值
Functional Diagrams
DESCRIPTION
The DS2438 Smart Battery Monitor provides several functions that are desirable to carry in a battery
pack: a means of tagging a battery pack with a unique serial number, a direct-to-digital temperature
sensor which eliminates the need for thermistors in  the battery pack, an A/D converter which measures
the battery voltage and current, an integrated current accumulator which keeps a running total of all
current going into and out of the battery, an elapsed time meter, and 40 bytes of nonvolatile EEPROM
memory for storage of important parameters such  as battery chemistry, battery capacity, charging
methodology and assembly date.  Information is sent to/from the DS2438 over a 1-Wire interface, so that
only one wire (and ground) needs to be connected from a central microprocessor to a DS2438.  This
means that battery packs need only have three output connectors: battery power, ground, and the 1-Wire
interface.
引脚图:
DS2438.pdf
381.66 KB, 下载次数: 4, 下载积分: 黑币 -5
