查看: 2905|回复: 0
1602频率表
ID:71774 发表于 2015-1-27 14:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
   #include<reg52.h>              //1602液晶频率表。这个用T2计时,采用16位自动重装。
#include<stdio.h>
#include<intrins.h>
#define uchar  unsigned char
#define CHECK_BUSY
sbit RS = P1^0;
sbit RW = P1^1;
sbit EN = P1^5;
bit flag;
char  counter,counter2;
void DelayMs(uchar t)
int  x,y;
for (x=t;x>0;x--)
  for(y=110;y>0;y--);
bit LCD_Check_Busy(void)
#ifdef CHECK_BUSY
P0= 0xFF;
RS=0;
RW=1;
EN=0;
_nop_();
EN=1;
return (bit)(P0 & 0x80);
#else
return 0;
#endif
void write_Com(uchar com)
while(LCD_Check_Busy());
RS=0;
RW=0;
EN=1;
P0= com;
_nop_();
EN=0;
void write_dat(uchar dat)
RS=1;
RW=0;
EN=1;
P0= dat;
_nop_();
EN=0;
void LCD_Clear(void)
write_Com(0x01);
DelayMs(5);
void LCD_Write_Char(uchar x,uchar y,uchar dat)
if (y == 0)
  write_Com(0x80 + x);
  write_Com(0xC0 + x);
write_dat( dat);
void LCD_Write_String(uchar x,uchar y,uchar *s)
  while (*s)
   LCD_Write_Char(x,y,*s);
   s ++;
   x++;
void LCD_Init(void)
   write_Com(0x38);
   write_Com(0x06);
   DelayMs(5);
   write_Com(0x0C);
   write_Com(0x01);
void timer2_init()
        T2MOD=0X00;
        TH2=(65536-110592/60)/256;
        TL2=(65536-110592/60)%256;
        RCAP2H=TH2;
        RCAP2L=TL2;
        EA=1;
        ET2=1;
        TR2=1;
void Init_Timer0(void)
TMOD=0x05;
TH0=0x00;
TL0=0x00;
EA=1;
ET0=1;
TR0=1;
main()
unsigned  long int a;
char temp[16];
Init_Timer0();
timer2_init();
LCD_Init();
DelayMs(10);
LCD_Clear();
LCD_Write_String(0,0,"Frequency table");
          if(flag==1)
                     {flag=0;
               a=counter*65536+TH0*256+TL0;
           a*=10;
                   sprintf(temp,"FREQ:%08.0f Hz",(float)a);
           LCD_Write_String(0,1,temp);
                            counter=0;
                TR0=1;TR2=1;
                                TH0=0;
                TL0=0;
void t0(void) interrupt 1 using 1
counter ++;
   TH0=0;
   TL0=0;
void t2(void) interrupt 5 using 2
{ TF2=0;
  counter2++;
  if(counter2==50)
  TR0=0;TR2=0;
  counter2=0;
  flag=1;
admin + 50 共享资料的积分奖励!
收藏收藏1 分享淘帖 顶 踩
