查看: 10473|回复: 4
编译错误:error C141: syntax error near '/'
ID:81086 发表于 2015-5-25 17:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#define  uchar unsigned char
#define uint  unsigned int
#define DAdata  P0   //DA数据端口
sbit DA_S1= P2^0;   // 控制DAC0832的8位输入寄存器,仅当都为0时,可以输入数据(处于直通状态),否则,输入将被锁存
sbit DA_S2= P2^1;   // 控制DAC0832的8位DAC寄存器,仅当都为0时,可以输出数据(处于直通状态),否则,输出将被锁存
sbit key= P3^2;
uchar wavecount;    //'抽点'计数
uchar THtemp,TLtemp;//传递频率的中间变量
uchar judge=1;      //在方波输出函数中用于简单判别作用
uchar waveform;      //当其为0、1、2时,分别代表三种波
uchar code freq_unit[3]={10,50,200}; //三种波的频率单位
uchar idata wavefreq[3]={1,1,1};   //给每种波定义一个数组单元,用于存放单位频率的个数
uchar code lcd_hang1[]={"Sine Wave      " "Triangle Wave  " "Square Wave    " "Select Wave:   " "press No.1 key! "};
uchar idata lcd_hang2[16]={"f=    Hz       "};
uchar code waveTH[]={
   0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
    0xec,0xf6,0xf9,0xfb,0xfc,0xfc,0xfd,0xfd,0xfd,0xfe};
uchar code waveTL[]={
    0x06,0x8a,0x10,0x4e,0x78,0x93,0xa8,0xb3,0xbe,0xc6,
    0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde,
    0x88,0x50,0x90,0x32,0x34,0xbe,0x4a,0xa3,0xe5,0x2c}; //频率调整中间值
uchar code triangle_tab[]={  //每隔数字8,采取一次
   0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58,0x60,0x68,0x70,0x78,
   0x80,0x88,0x90,0x98,0xa0,0xa8,0xb0,0xb8,0xc0,0xc8,0xd0,0xd8,0xe0,0xe8,0xf0,0xf8,0xff,
   0xf8,0xf0,0xe8,0xe0,0xd8,0xd0,0xc8,0xc0,0xb8,0xb0,0xa8,0xa0,0x98,0x90,0x88,0x80,
   0x78,0x70,0x68,0x60,0x58,0x50,0x48,0x40,0x38,0x30,0x28,0x20,0x18,0x10,0x08,0x00};
uchar code sine_tab[256]={
   //输出电压从0到最大值(正弦波1/4部分)
   0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,
   0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,
   0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
   //输出电压从最大值到0(正弦波1/4部分)
   0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,
   0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,
   0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99 ,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
   //输出电压从0到最小值(正弦波1/4部分)
   0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,
   0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16 ,0x15,0x13,
   0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
   //输出电压从最小值到0(正弦波1/4部分)
   0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,
   0x11,0x13,0x15 ,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
   0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
void delay(uchar z)
    uint x,y;
   for(x=z;x>0;x--)
   for(y=110;y>0;y--);
void triangle_out()  //三角波输出
   DAdata=triangle_tab[wavecount++];
   if(wavecount>64)wavecount=0;
   DA_S1=0;  //打开8位输入寄存器
   DA_S1=1;  //关闭8位输入寄存器
void sine_out()   //正弦波输出
   DAdata=sine_tab[wavecount++];
void square_out()  //方波输出
    judge=~judge;
    if(judge==1) DAdata=0xff;
   else  DAdata=0x00;
/************1602液晶的相关函数*************/
#define lcd_ports P1
sbit rs=P2^2;
sbit rw=P2^3;
sbit lcden=P2^4;
void write_com(uchar com)
   rs=0;  //置零,表示写指令
   lcden=0;
   lcd_ports=com;
   delay(5);
   lcden=1;
   delay(5);
   lcden=0;
void write_date(uchar date)
   rs=1;  //置1,表示写数据(在指令所指的地方写数据)
   lcden=0;
   lcd_ports=date;
   delay(5);
   lcden=1;
   delay(5);
   lcden=0;
void disp_lcd(uchar addr,uchar *temp1)
   uchar num;
   write_com(addr);
   delay(1);
   for(num=0;num<16;num++)
       write_date(temp1[num]);
       delay(1);
void init_lcd()
lcden=0;
   rw=0;  //初始化设置为零,表示写数据
   write_com(0x38);  //使液晶显示点阵,为下面做准备
   write_com(0x0c); //初始设置
   write_com(0x06);  //初始设置
   write_com(0x01);  //清零
   write_com(0x80);  //使指针指向第一行第一格
  disp_lcd(0x80,&lcd_hang1[3*16]); //在第一行显示
  disp_lcd(0xc0,&lcd_hang1[4*16]); //在第二行显示
          write_date(table[num]);
           delay(5);
   write_com(0x80+0x40);   //给指针重新赋值,使之指向第二行第一格
          write_date(table1[num]);
          delay(5);
   TMOD=0x01;   //选用定时方式1
   TH0=(65536-50000)/256;  //赋初值
   TL0=(65536-50000)%256;
   EA=1;  //开总中断
   ET0=1;   //开定时器中断
   TR0=1;   //启动定时器*/
   uchar i=0;
   DA_S2=0;    //使DAC寄存器处于直通状态
   DAdata=0;
   init_lcd();
   waveform=0;
   TMOD=0x01;  //设置定时器0为16位工作方式
   IT0=1;      //设置外部中断0为下降沿触发
   ET0=1;      //开定时器中断
   EX0=1;
   EA=1;
void timer0() interrupt 1
   TH0=THtemp;
   TL0=TLtemp;
   if(waveform==0)      sine_out();
   else if(waveform==1)triangle_out();
   else if(waveform==2)square_out();
void key_int0() interrupt 0
    uchar keytemp;
   uint total_freq; //总频率
   EA=0; TR0=0;     //关总中断与定时器
   delay(5);
   if(key==0)       //确实有按键按下而引发中断
       keytemp=P3&0xf0; //获取P3口高四位的值
       switch(keytemp)
           case 0xe0:    //选择波形
               waveform++;
               if(waveform>2) waveform=0;
               break;
           case 0xd0: //频率按规定单位依次增加
               wavefreq[waveform]++;
               if(wavefreq[waveform]>10)wavefreq[waveform]=1;
               break;
           case 0xb0: //频率按规定单位依次衰减
               wavefreq[waveform]--;
               if(wavefreq[waveform]<1)wavefreq[waveform]=10;
               break;
           case 0x70:    //TTL输出
                DA_S2=1; //使DAC寄存器关闭
               break;
THtemp=waveTH[waveform*10+(wavefreq[waveform]-1)]; //方括号中选取第几个数后,并把该值赋给T_temp
TLtemp=waveTL[waveform*10+(wavefreq[waveform]-1)];
total_freq= wavefreq[waveform] * freq_unit[waveform]; //求输出频率(个数*单位)
lcd_hang2[5]=total_freq%10+0x30;             //在液晶中显示个位,(0x30 在液晶显示中表示数字0)
total_freq/=10; lcd_hang2[4]=total_freq%10+0x30; //在液晶中显示时十位
total_freq/=10; lcd_hang2[3]=total_freq%10+0x30; //在液晶中显示时百位
total_freq/=10; lcd_hang2[2]=total_freq%10+0x30; //在液晶中显示时千位
disp_lcd(0x80,&lcd_hang1[waveform*16]);  //在第一行显示
disp_lcd(0xc0,lcd_hang2);  //在第二行显示
   wavecount=0; //'抽点'计数清零
   while(!key);
   EA=1; TR0=1;     //开启总中断与定时器
编译有错误
compiling 123.c...
123.C(131): error C202: 'num': undefined identifier
123.C(133): error C202: 'num': undefined identifier
123.C(137): error C202: 'num': undefined identifier
123.C(139): error C202: 'num': undefined identifier
123.C(141): error C141: syntax error near '/'
123.C(197): error C187: not an lvalue
123.C(202): error C187: not an lvalue
123.c - 7 Error(s), 0 Warning(s).
ID:81086 发表于 2015-5-25 18:43 | 只看该作者
有人吗?帮帮忙
有人吗?帮帮忙
ID:1 发表于 2015-5-25 23:06 | 只看该作者
num 没有定义
ID:79908 发表于 2015-5-26 09:14 | 只看该作者
num 没有定义  141行处语法错误
参与人数 1黑币 +35 收起 理由
admin + 35 回帖助人的奖励!
