查看: 3703|回复: 3
我有一程序,请高手帮我看一下波特率是多少?急急急
ID:52938 发表于 2013-8-11 15:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Q0000:             CLR   P2.6                         ;0000   C2 A6
                   CLR   P2.7                         ;0002   C2 A7
                   AJMP  Q0030                        ;0004   01 30
                   NOP                                ;0006   00
                   NOP                                ;0007   00
                   NOP                                ;0008   00
                   NOP                                ;0009   00
                   NOP                                ;000A   00
                   NOP                                ;000B   00
                   NOP                                ;000C   00
                   NOP                                ;000D   00
                   NOP                                ;000E   00
                   NOP                                ;000F   00
                   NOP                                ;0010   00
                   NOP                                ;0011   00
                   NOP                                ;0012   00
                   NOP                                ;0013   00
                   NOP                                ;0014   00
                   NOP                                ;0015   00
                   NOP                                ;0016   00
                   NOP                                ;0017   00
                   NOP                                ;0018   00
                   NOP                                ;0019   00
                   NOP                                ;001A   00
                   NOP                                ;001B   00
                   NOP                                ;001C   00
                   NOP                                ;001D   00
                   NOP                                ;001E   00
                   NOP                                ;001F   00
                   NOP                                ;0020   00
                   NOP                                ;0021   00
                   NOP                                ;0022   00
                   NOP                                ;0023   00
                   NOP                                ;0024   00
                   NOP                                ;0025   00
                   NOP                                ;0026   00
                   NOP                                ;0027   00
                   NOP                                ;0028   00
                   NOP                                ;0029   00
                   NOP                                ;002A   00
                   NOP                                ;002B   00
                   NOP                                ;002C   00
                   NOP                                ;002D   00
                   NOP                                ;002E   00
                   NOP                                ;002F   00
Q0030:             NOP                                ;0030   00
                   NOP                                ;0031   00
                   NOP                                ;0032   00
                   CLR   C                            ;0033   C3
                   MOV   2FH,#40H                     ;0034   75 2F 40
                   MOV   A,2FH                        ;0037   E5 2F
                   ADD   A,#0AH                       ;0039   24 0A
                   MOV   2FH,A                        ;003B   F5 2F
                   NOP                                ;003D   00
                   MOV   SP,#30H                      ;003E   75 81 30
                   MOV   IE,#00H                      ;0041   75 A8 00
                   MOV   TMOD,#20H                    ;0044   75 89 20
                   MOV   TCON,#00H                    ;0047   75 88 00
                   MOV   SCON,#40H                    ;004A   75 98 40
                   MOV   PCON,#80H                    ;004D   75 87 80
                   MOV   TH1,#0D0H                    ;0050   75 8D D0
                   MOV   TL1,#0D0H                    ;0053   75 8B D0
                   SETB  TR1                          ;0056   D2 8E
                   CLR   P1.2                         ;0058   C2 92
                   CPL   P1.7                         ;005A   B2 97
                   CLR   P0.5                         ;005C   C2 85
                   SETB  P0.4                         ;005E   D2 84
                   SETB  P0.3                         ;0060   D2 83
                   SETB  P0.2                         ;0062   D2 82
                   SETB  P0.1                         ;0064   D2 81
                   SETB  P0.0                         ;0066   D2 80
                   SETB  P0.7                         ;0068   D2 87
                   SETB  P0.6                         ;006A   D2 86
                   CPL   P1.7                         ;006C   B2 97
                   LCALL Q0732                        ;006E   12 07 32
                   LCALL Q0762                        ;0071   12 07 62
                   LCALL Q01A5                        ;0074   12 01 A5
                   LCALL Q01AE                        ;0077   12 01 AE
Q007A:             CPL   P1.7                         ;007A   B2 97
                   MOV   29H,#00H                     ;007C   75 29 00
                   LCALL Q0355                        ;007F   12 03 55
                   SETB  REN                          ;0082   D2 9C
                   SETB  SM2                          ;0084   D2 9D
                   CLR   P1.2                         ;0086   C2 92
                   MOV   7BH,#00H                     ;0088   75 7B 00
                   MOV   7AH,#00H                     ;008B   75 7A 00
                   MOV   79H,#00H                     ;008E   75 79 00
                   MOV   78H,#00H                     ;0091   75 78 00
Q0094:             LCALL Q072A                        ;0094   12 07 2A
                   MOV   A,SBUF                       ;0097   E5 99
                   CJNE  A,#0AAH,Q0094                ;0099   B4 AA F8
                   LCALL Q072A                        ;009C   12 07 2A
                   MOV   A,SBUF                       ;009F   E5 99
                   CJNE  A,2FH,Q0094                  ;00A1   B5 2F F0
                   LCALL Q072A                        ;00A4   12 07 2A
                   MOV   A,SBUF                       ;00A7   E5 99
                   MOV   68H,A                        ;00A9   F5 68
                   CJNE  A,#0A4H,Q00CB                ;00AB   B4 A4 1D
                   CPL   P1.7                         ;00AE   B2 97
                   LCALL Q072A                        ;00B0   12 07 2A
                   MOV   69H,SBUF                     ;00B3   85 99 69
                   LCALL Q072A                        ;00B6   12 07 2A
                   MOV   6AH,SBUF                     ;00B9   85 99 6A
                   LCALL Q072A                        ;00BC   12 07 2A
                   MOV   6BH,SBUF                     ;00BF   85 99 6B
                   LCALL Q072A                        ;00C2   12 07 2A
                   MOV   6CH,SBUF                     ;00C5   85 99 6C
                   LCALL Q0A3E                        ;00C8   12 0A 3E
Q00CB:             CLR   SM2                          ;00CB   C2 9D
                   CPL   P1.7                         ;00CD   B2 97
                   CLR   TB8                          ;00CF   C2 9B
                   CLR   REN                          ;00D1   C2 9C
                   SETB  P1.2                         ;00D3   D2 92
                   MOV   7BH,#00H                     ;00D5   75 7B 00
                   MOV   7AH,#00H                     ;00D8   75 7A 00
                   MOV   79H,#00H                     ;00DB   75 79 00
                   MOV   78H,#00H                     ;00DE   75 78 00
                   MOV   A,68H                        ;00E1   E5 68
                   CJNE  A,#0A3H,Q0103                ;00E3   B4 A3 1D
                   CPL   P1.7                         ;00E6   B2 97
                   LCALL Q015E                        ;00E8   12 01 5E
                   LCALL Q0410                        ;00EB   12 04 10
                   MOV   7DH,5AH                      ;00EE   85 5A 7D
                   LCALL Q0191                        ;00F1   12 01 91
                   LCALL Q04AA                        ;00F4   12 04 AA
                   MOV   7EH,5AH                      ;00F7   85 5A 7E
                   LCALL Q019B                        ;00FA   12 01 9B
                   LCALL Q017D                        ;00FD   12 01 7D
                   LJMP  Q007A                        ;0100   02 00 7A
Q0103:             CJNE  A,#0A0H,Q0129                ;0103   B4 A0 23
                   CPL   P1.7                         ;0106   B2 97
                   LCALL Q015E                        ;0108   12 01 5E
                   LCALL Q017D                        ;010B   12 01 7D
                   MOV   A,7DH                        ;010E   E5 7D
                   JZ    Q0117                        ;0110   60 05
                   LCALL Q0792                        ;0112   12 07 92
                   AJMP  Q011A                        ;0115   21 1A
Q0117:             LCALL Q07E5                        ;0117   12 07 E5
Q011A:             MOV   R0,#50H                      ;011A   78 50
                   MOV   R1,#09H                      ;011C   79 09
Q011E:             MOV   SBUF,@R0                     ;011E   86 99
                   LCALL Q071F                        ;0120   12 07 1F
                   INC   R0                           ;0123   08
                   DJNZ  R1,Q011E                     ;0124   D9 F8
                   LJMP  Q007A                        ;0126   02 00 7A
Q0129:             CJNE  A,#0A1H,Q014C                ;0129   B4 A1 20
                   CPL   P1.7                         ;012C   B2 97
                   LCALL Q015E                        ;012E   12 01 5E
                   LCALL Q017D                        ;0131   12 01 7D
                   MOV   SBUF,#15H                    ;0134   75 99 15
                   LCALL Q071F                        ;0137   12 07 1F
                   LCALL Q0732                        ;013A   12 07 32
                   LCALL Q0762                        ;013D   12 07 62
                   LCALL Q0839                        ;0140   12 08 39
                   LCALL Q08B6                        ;0143   12 08 B6
                   LCALL Q01B7                        ;0146   12 01 B7
                   LJMP  Q007A                        ;0149   02 00 7A
Q014C:             LCALL Q015E                        ;014C   12 01 5E
                   MOV   SBUF,#00H                    ;014F   75 99 00
                   LCALL Q071F                        ;0152   12 07 1F
                   MOV   SBUF,#00H                    ;0155   75 99 00
                   LCALL Q071F                        ;0158   12 07 1F
                   LJMP  Q007A                        ;015B   02 00 7A
Q015E:             MOV   A,#00H                       ;015E   74 00
                   MOV   SBUF,A                       ;0160   F5 99
                   JNB   TI,$                         ;0162   30 99 FD
                   CLR   TI                           ;0165   C2 99
                   MOV   A,#0AAH                      ;0167   74 AA
                   MOV   SBUF,A                       ;0169   F5 99
                   LCALL Q071F                        ;016B   12 07 1F
                   MOV   A,2FH                        ;016E   E5 2F
                   MOV   SBUF,A                       ;0170   F5 99
                   LCALL Q071F                        ;0172   12 07 1F
                   MOV   A,68H                        ;0175   E5 68
                   MOV   SBUF,A                       ;0177   F5 99
                   LCALL Q071F                        ;0179   12 07 1F
                   RET                                ;017C   22
Q017D:             CLR   C                            ;017D   C3
                   MOV   A,7DH                        ;017E   E5 7D
                   ADD   A,7EH                        ;0180   25 7E
                   MOV   SBUF,A                       ;0182   F5 99
                   LCALL Q071F                        ;0184   12 07 1F
                   MOV   A,#00H                       ;0187   74 00
                   ADDC  A,#00H                       ;0189   34 00
                   MOV   SBUF,A                       ;018B   F5 99
                   LCALL Q071F                        ;018D   12 07 1F
                   RET                                ;0190   22
Q0191:             MOV   DPTR,#1000H                  ;0191   90 10 00
                   MOV   B,7DH                        ;0194   85 7D F0
                   LCALL Q038B                        ;0197   12 03 8B
                   RET                                ;019A   22
Q019B:             MOV   DPTR,#1001H                  ;019B   90 10 01
                   MOV   B,7EH                        ;019E   85 7E F0
                   LCALL Q038B                        ;01A1   12 03 8B
                   RET                                ;01A4   22
Q01A5:             MOV   DPTR,#1000H                  ;01A5   90 10 00
                   LCALL Q036A                        ;01A8   12 03 6A
                   MOV   7DH,A                        ;01AB   F5 7D
                   RET                                ;01AD   22
Q01AE:             MOV   DPTR,#1001H                  ;01AE   90 10 01
                   LCALL Q036A                        ;01B1   12 03 6A
                   MOV   7EH,A                        ;01B4   F5 7E
                   RET                                ;01B6   22
Q01B7:             CPL   P1.7                         ;01B7   B2 97
                   MOV   7CH,#07H                     ;01B9   75 7C 07
                   LCALL Q02C4                        ;01BC   12 02 C4
                   MOV   SBUF,A                       ;01BF   F5 99
                   LCALL Q033E                        ;01C1   12 03 3E
                   LCALL Q071F                        ;01C4   12 07 1F
                   MOV   A,B                          ;01C7   E5 F0
                   MOV   SBUF,A                       ;01C9   F5 99
                   LCALL Q033E                        ;01CB   12 03 3E
                   LCALL Q071F                        ;01CE   12 07 1F
                   CPL   P1.7                         ;01D1   B2 97
                   MOV   7CH,#03H                     ;01D3   75 7C 03
                   LCALL Q02C4                        ;01D6   12 02 C4
                   MOV   SBUF,A                       ;01D9   F5 99
                   LCALL Q033E                        ;01DB   12 03 3E
                   LCALL Q071F                        ;01DE   12 07 1F
                   MOV   A,B                          ;01E1   E5 F0
                   MOV   SBUF,A                       ;01E3   F5 99
                   LCALL Q033E                        ;01E5   12 03 3E
                   LCALL Q071F                        ;01E8   12 07 1F
                   CPL   P1.7                         ;01EB   B2 97
                   MOV   7CH,#04H                     ;01ED   75 7C 04
                   LCALL Q02C4                        ;01F0   12 02 C4
                   MOV   SBUF,A                       ;01F3   F5 99
                   LCALL Q033E                        ;01F5   12 03 3E
                   LCALL Q071F                        ;01F8   12 07 1F
                   MOV   A,B                          ;01FB   E5 F0
                   MOV   SBUF,A                       ;01FD   F5 99
                   LCALL Q033E                        ;01FF   12 03 3E
                   LCALL Q071F                        ;0202   12 07 1F
                   MOV   7CH,#02H                     ;0205   75 7C 02
                   LCALL Q02C4                        ;0208   12 02 C4
                   MOV   SBUF,A                       ;020B   F5 99
                   LCALL Q033E                        ;020D   12 03 3E
                   LCALL Q071F                        ;0210   12 07 1F
                   MOV   A,B                          ;0213   E5 F0
                   MOV   SBUF,A                       ;0215   F5 99
                   LCALL Q033E                        ;0217   12 03 3E
                   LCALL Q071F                        ;021A   12 07 1F
                   MOV   7CH,#00H                     ;021D   75 7C 00
                   LCALL Q02C4                        ;0220   12 02 C4
                   MOV   SBUF,A                       ;0223   F5 99
                   LCALL Q033E                        ;0225   12 03 3E
                   LCALL Q071F                        ;0228   12 07 1F
                   MOV   A,B                          ;022B   E5 F0
                   MOV   SBUF,A                       ;022D   F5 99
                   LCALL Q033E                        ;022F   12 03 3E
                   LCALL Q071F                        ;0232   12 07 1F
                   MOV   7CH,#05H                     ;0235   75 7C 05
                   LCALL Q02C4                        ;0238   12 02 C4
                   MOV   SBUF,A                       ;023B   F5 99
                   LCALL Q033E                        ;023D   12 03 3E
                   LCALL Q071F                        ;0240   12 07 1F
                   MOV   A,B                          ;0243   E5 F0
                   MOV   SBUF,A                       ;0245   F5 99
                   LCALL Q033E                        ;0247   12 03 3E
                   LCALL Q071F                        ;024A   12 07 1F
                   MOV   7CH,#06H                     ;024D   75 7C 06
                   LCALL Q02C4                        ;0250   12 02 C4
                   MOV   SBUF,A                       ;0253   F5 99
                   LCALL Q033E                        ;0255   12 03 3E
                   LCALL Q071F                        ;0258   12 07 1F
                   MOV   A,B                          ;025B   E5 F0
                   MOV   SBUF,A                       ;025D   F5 99
                   LCALL Q033E                        ;025F   12 03 3E
                   LCALL Q071F                        ;0262   12 07 1F
                   CPL   P1.7                         ;0265   B2 97
                   MOV   7CH,#01H                     ;0267   75 7C 01
                   LCALL Q02C4                        ;026A   12 02 C4
                   MOV   SBUF,A                       ;026D   F5 99
                   LCALL Q033E                        ;026F   12 03 3E
                   LCALL Q071F                        ;0272   12 07 1F
                   MOV   A,B                          ;0275   E5 F0
                   MOV   SBUF,A                       ;0277   F5 99
                   LCALL Q033E                        ;0279   12 03 3E
                   LCALL Q071F                        ;027C   12 07 1F
                   MOV   A,78H                        ;027F   E5 78
                   MOV   SBUF,A                       ;0281   F5 99
                   LCALL Q071F                        ;0283   12 07 1F
                   MOV   A,79H                        ;0286   E5 79
                   MOV   SBUF,A                       ;0288   F5 99
                   LCALL Q071F                        ;028A   12 07 1F
                   MOV   A,7AH                        ;028D   E5 7A
                   MOV   SBUF,A                       ;028F   F5 99
                   LCALL Q071F                        ;0291   12 07 1F
                   MOV   A,7BH                        ;0294   E5 7B
                   MOV   SBUF,A                       ;0296   F5 99
                   LCALL Q071F                        ;0298   12 07 1F
                   RET                                ;029B   22
Q029C:                 DB  12H, 05H,0EDH, 74H, 55H, 12H, 06H, 0EH        ;...tU...
Q02A4:                 DB  7DH, 08H, 12H, 03H, 6AH, 12H, 06H, 0EH        ;}...j...
Q02AC:                 DB 0A3H,0DDH,0F7H, 22H, 12H, 06H, 6EH, 74H        ;..."..nt
Q02B4:                 DB  55H, 12H, 06H, 8DH, 7DH, 08H, 12H, 03H        ;U...}...
Q02BC:                 DB  6AH, 12H, 06H, 8DH,0A3H,0DDH,0F7H, 22H        ;j......"
Q02C4:             PUSH  PSW                          ;02C4   C0 D0
                   CLR   RS1                          ;02C6   C2 D4
                   SETB  RS0                          ;02C8   D2 D3
                   MOV   P2,#3FH                      ;02CA   75 A0 3F
                   MOV   R3,#00H                      ;02CD   7B 00
                   MOV   R4,#00H                      ;02CF   7C 00
                   MOV   R5,#00H                      ;02D1   7D 00
                   MOV   A,P2                         ;02D3   E5 A0
                   ANL   A,#0F8H                      ;02D5   54 F8
                   ORL   A,7CH                        ;02D7   45 7C
                   MOV   P2,A                         ;02D9   F5 A0
                   LCALL Q06EF                        ;02DB   12 06 EF
                   MOV   R7,#20H                      ;02DE   7F 20
Q02E0:             LCALL Q0306                        ;02E0   12 03 06
                   ADD   A,R5                         ;02E3   2D
                   MOV   R5,A                         ;02E4   FD
                   MOV   A,R4                         ;02E5   EC
                   ADDC  A,B                          ;02E6   35 F0
                   MOV   R4,A                         ;02E8   FC
                   MOV   A,R3                         ;02E9   EB
                   ADDC  A,#00H                       ;02EA   34 00
                   MOV   R3,A                         ;02EC   FB
                   DJNZ  R7,Q02E0                     ;02ED   DF F1
                   MOV   R7,#05H                      ;02EF   7F 05
Q02F1:             CLR   C                            ;02F1   C3
                   MOV   A,R3                         ;02F2   EB
                   RRC   A                            ;02F3   13
                   MOV   R3,A                         ;02F4   FB
                   MOV   A,R4                         ;02F5   EC
                   RRC   A                            ;02F6   13
                   MOV   R4,A                         ;02F7   FC
                   MOV   A,R5                         ;02F8   ED
                   RRC   A                            ;02F9   13
                   MOV   R5,A                         ;02FA   FD
                   DJNZ  R7,Q02F1                     ;02FB   DF F4
                   MOV   A,R4                         ;02FD   EC
                   MOV   B,R5                         ;02FE   8D F0
                   MOV   P2,#3FH                      ;0300   75 A0 3F
                   POP   PSW                          ;0303   D0 D0
                   RET                                ;0305   22
Q0306:             MOV   A,#00H                       ;0306   74 00
                   MOV   B,#00H                       ;0308   75 F0 00
                   CLR   P2.5                         ;030B   C2 A5
                   NOP                                ;030D   00
                   CLR   P2.3                         ;030E   C2 A3
                   NOP                                ;0310   00
                   NOP                                ;0311   00
                   SETB  P2.5                         ;0312   D2 A5
                   NOP                                ;0314   00
                   NOP                                ;0315   00
                   CLR   P2.5                         ;0316   C2 A5
                   NOP                                ;0318   00
                   NOP                                ;0319   00
                   SETB  P2.5                         ;031A   D2 A5
                   NOP                                ;031C   00
                   NOP                                ;031D   00
                   CLR   P2.5                         ;031E   C2 A5
                   NOP                                ;0320   00
                   NOP                                ;0321   00
                   SETB  P2.5                         ;0322   D2 A5
                   NOP                                ;0324   00
                   NOP                                ;0325   00
                   MOV   R6,#0CH                      ;0326   7E 0C
Q0328:             CLR   P2.5                         ;0328   C2 A5
                   NOP                                ;032A   00
                   MOV   C,P2.4                       ;032B   A2 A4
                   RLC   A                            ;032D   33
                   MOV   R2,A                         ;032E   FA
                   SETB  P2.5                         ;032F   D2 A5
                   MOV   A,B                          ;0331   E5 F0
                   RLC   A                            ;0333   33
                   MOV   B,A                          ;0334   F5 F0
                   MOV   A,R2                         ;0336   EA
                   DJNZ  R6,Q0328                     ;0337   DE EF
                   SETB  P2.3                         ;0339   D2 A3
                   CPL   P1.7                         ;033B   B2 97
                   RET                                ;033D   22
Q033E:             ADD   A,78H                        ;033E   25 78
                   MOV   78H,A                        ;0340   F5 78
                   MOV   A,79H                        ;0342   E5 79
                   ADDC  A,#00H                       ;0344   34 00
                   MOV   79H,A                        ;0346   F5 79
                   MOV   A,7AH                        ;0348   E5 7A
                   ADDC  A,#00H                       ;034A   34 00
                   MOV   7AH,A                        ;034C   F5 7A
                   MOV   A,7BH                        ;034E   E5 7B
                   ADDC  A,#00H                       ;0350   34 00
                   MOV   7BH,A                        ;0352   F5 7B
                   RET                                ;0354   22
Q0355:             MOV   TH1,#0D0H                    ;0355   75 8D D0
                   MOV   TL1,#0D0H                    ;0358   75 8B D0
                   SETB  TR1                          ;035B   D2 8E
                   MOV   SCON,#0C0H                   ;035D   75 98 C0
                   MOV   PCON,#80H                    ;0360   75 87 80
                   CLR   P0.5                         ;0363   C2 85
                   CLR   P0.4                         ;0365   C2 84
                   CPL   P1.7                         ;0367   B2 97
                   RET                                ;0369   22
Q036A:             LCALL Q03EE                        ;036A   12 03 EE
                   MOV   A,#0A0H                      ;036D   74 A0
                   LCALL Q03A9                        ;036F   12 03 A9
                   MOV   A,DPH                        ;0372   E5 83
                   LCALL Q03A9                        ;0374   12 03 A9
                   MOV   A,DPL                        ;0377   E5 82
                   LCALL Q03A9                        ;0379   12 03 A9
                   LCALL Q03EE                        ;037C   12 03 EE
                   MOV   A,#0A1H                      ;037F   74 A1
                   LCALL Q03A9                        ;0381   12 03 A9
                   LCALL Q03D5                        ;0384   12 03 D5
                   LCALL Q03FF                        ;0387   12 03 FF
                   RET                                ;038A   22
Q038B:             LCALL Q03EE                        ;038B   12 03 EE
                   MOV   A,#0A0H                      ;038E   74 A0
                   LCALL Q03A9                        ;0390   12 03 A9
                   MOV   A,DPH                        ;0393   E5 83
                   LCALL Q03A9                        ;0395   12 03 A9
                   MOV   A,DPL                        ;0398   E5 82
                   LCALL Q03A9                        ;039A   12 03 A9
                   MOV   A,B                          ;039D   E5 F0
                   LCALL Q03A9                        ;039F   12 03 A9
                   LCALL Q03FF                        ;03A2   12 03 FF
                   LCALL Q06FA                        ;03A5   12 06 FA
                   RET                                ;03A8   22
Q03A9:             CPL   P1.7                         ;03A9   B2 97
                   MOV   R7,#08H                      ;03AB   7F 08
Q03AD:             CLR   P0.2                         ;03AD   C2 82
                   NOP                                ;03AF   00
                   NOP                                ;03B0   00
                   NOP                                ;03B1   00
                   RLC   A                            ;03B2   33
                   MOV   P0.3,C                       ;03B3   92 83
                   NOP                                ;03B5   00
                   NOP                                ;03B6   00
                   NOP                                ;03B7   00
                   SETB  P0.2                         ;03B8   D2 82
                   NOP                                ;03BA   00
                   NOP                                ;03BB   00
                   NOP                                ;03BC   00
                   DJNZ  R7,Q03AD                     ;03BD   DF EE
                   CLR   P0.2                         ;03BF   C2 82
                   NOP                                ;03C1   00
                   NOP                                ;03C2   00
                   NOP                                ;03C3   00
                   NOP                                ;03C4   00
                   NOP                                ;03C5   00
                   NOP                                ;03C6   00
                   SETB  P0.3                         ;03C7   D2 83
                   SETB  P0.2                         ;03C9   D2 82
                   NOP                                ;03CB   00
                   NOP                                ;03CC   00
                   NOP                                ;03CD   00
                   NOP                                ;03CE   00
                   CLR   P0.2                         ;03CF   C2 82
                   NOP                                ;03D1   00
                   NOP                                ;03D2   00
                   NOP                                ;03D3   00
                   RET                                ;03D4   22
Q03D5:             CPL   P1.7                         ;03D5   B2 97
                   SETB  P0.3                         ;03D7   D2 83
                   MOV   R7,#08H                      ;03D9   7F 08
Q03DB:             CLR   P0.2                         ;03DB   C2 82
                   NOP                                ;03DD   00
                   NOP                                ;03DE   00
                   NOP                                ;03DF   00
                   MOV   C,P0.3                       ;03E0   A2 83
                   RLC   A                            ;03E2   33
                   NOP                                ;03E3   00
                   NOP                                ;03E4   00
                   NOP                                ;03E5   00
                   SETB  P0.2                         ;03E6   D2 82
                   NOP                                ;03E8   00
                   NOP                                ;03E9   00
                   NOP                                ;03EA   00
                   DJNZ  R7,Q03DB                     ;03EB   DF EE
                   RET                                ;03ED   22
Q03EE:             SETB  P0.3                         ;03EE   D2 83
                   SETB  P0.2                         ;03F0   D2 82
                   NOP                                ;03F2   00
                   NOP                                ;03F3   00
                   NOP                                ;03F4   00
                   CLR   P0.3                         ;03F5   C2 83
                   NOP                                ;03F7   00
                   NOP                                ;03F8   00
                   NOP                                ;03F9   00
                   CLR   P0.2                         ;03FA   C2 82
                   NOP                                ;03FC   00
                   NOP                                ;03FD   00
                   RET                                ;03FE   22
Q03FF:             CLR   P0.3                         ;03FF   C2 83
                   CLR   P0.2                         ;0401   C2 82
                   NOP                                ;0403   00
                   NOP                                ;0404   00
                   NOP                                ;0405   00
                   SETB  P0.2                         ;0406   D2 82
                   NOP                                ;0408   00
                   NOP                                ;0409   00
                   NOP                                ;040A   00
                   SETB  P0.3                         ;040B   D2 83
                   NOP                                ;040D   00
                   NOP                                ;040E   00
                   RET                                ;040F   22
Q0410:             PUSH  PSW                          ;0410   C0 D0
                   CLR   RS1                          ;0412   C2 D4
                   SETB  RS0                          ;0414   D2 D3
                   CPL   P1.7                         ;0416   B2 97
                   MOV   DPTR,#0000H                  ;0418   90 00 00
                   MOV   R7,#08H                      ;041B   7F 08
                   MOV   A,#00H                       ;041D   74 00
                   MOV   R0,#20H                      ;041F   78 20
Q0421:             MOV   @R0,A                        ;0421   F6
                   INC   R0                           ;0422   08
                   DJNZ  R7,Q0421                     ;0423   DF FC
                   MOV   R4,#08H                      ;0425   7C 08
                   MOV   R1,#60H                      ;0427   79 60
                   MOV   5AH,#00H                     ;0429   75 5A 00
                   MOV   5CH,#00H                     ;042C   75 5C 00
                   MOV   5BH,#00H                     ;042F   75 5B 00
                   MOV   5DH,#00H                     ;0432   75 5D 00
Q0435:             MOV   R5,#08H                      ;0435   7D 08
                   MOV   59H,#00H                     ;0437   75 59 00
                   MOV   5CH,5AH                      ;043A   85 5A 5C
                   LCALL Q05ED                        ;043D   12 05 ED
                   MOV   A,#0F0H                      ;0440   74 F0
                   LCALL Q060E                        ;0442   12 06 0E
Q0445:             LCALL Q063C                        ;0445   12 06 3C
                   RL    A                            ;0448   23
                   PUSH  DPL                          ;0449   C0 82
                   PUSH  DPH                          ;044B   C0 83
                   CPL   P1.7                         ;044D   B2 97
                   MOV   DPTR,#0453H                  ;044F   90 04 53
                   JMP   @A+DPTR                      ;0452   73
                   AJMP  Q045B                        ;0453   81 5B
                   AJMP  Q0475                        ;0455   81 75
                   AJMP  Q048C                        ;0457   81 8C
                   AJMP  Q04A3                        ;0459   81 A3
Q045B:             POP   DPH                          ;045B   D0 83
                   POP   DPL                          ;045D   D0 82
                   INC   59H                          ;045F   05 59
                   LCALL Q0544                        ;0461   12 05 44
                   LCALL Q0617                        ;0464   12 06 17
                   LCALL Q05A0                        ;0467   12 05 A0
                   MOV   A,5BH                        ;046A   E5 5B
                   JNZ   Q04A7                        ;046C   70 39
                   MOV   A,5AH                        ;046E   E5 5A
                   CJNE  A,5CH,Q0435                  ;0470   B5 5C C2
                   AJMP  Q0445                        ;0473   81 45
Q0475:             POP   DPH                          ;0475   D0 83
                   POP   DPL                          ;0477   D0 82
                   CLR   C                            ;0479   C3
                   LCALL Q0617                        ;047A   12 06 17
                   CLR   C                            ;047D   C3
                   LCALL Q05A0                        ;047E   12 05 A0
                   MOV   A,5BH                        ;0481   E5 5B
                   JNZ   Q04A7                        ;0483   70 22
                   MOV   A,5AH                        ;0485   E5 5A
                   CJNE  A,5CH,Q0435                  ;0487   B5 5C AB
                   AJMP  Q0445                        ;048A   81 45
Q048C:             POP   DPH                          ;048C   D0 83
                   POP   DPL                          ;048E   D0 82
                   SETB  C                            ;0490   D3
                   LCALL Q0617                        ;0491   12 06 17
                   SETB  C                            ;0494   D3
                   LCALL Q05A0                        ;0495   12 05 A0
                   MOV   A,5BH                        ;0498   E5 5B
                   JNZ   Q04A7                        ;049A   70 0B
                   MOV   A,5AH                        ;049C   E5 5A
                   CJNE  A,5CH,Q0435                  ;049E   B5 5C 94
                   AJMP  Q0445                        ;04A1   81 45
Q04A3:             POP   DPH                          ;04A3   D0 83
                   POP   DPL                          ;04A5   D0 82
Q04A7:             POP   PSW                          ;04A7   D0 D0
                   RET                                ;04A9   22
Q04AA:             PUSH  PSW                          ;04AA   C0 D0
                   CLR   RS1                          ;04AC   C2 D4
                   SETB  RS0                          ;04AE   D2 D3
                   CPL   P1.7                         ;04B0   B2 97
                   MOV   DPTR,#0800H                  ;04B2   90 08 00
                   MOV   R7,#08H                      ;04B5   7F 08
                   MOV   A,#00H                       ;04B7   74 00
                   MOV   R0,#20H                      ;04B9   78 20
Q04BB:             MOV   @R0,A                        ;04BB   F6
                   INC   R0                           ;04BC   08
                   DJNZ  R7,Q04BB                     ;04BD   DF FC
                   MOV   R4,#08H                      ;04BF   7C 08
                   MOV   R1,#60H                      ;04C1   79 60
                   MOV   5AH,#00H                     ;04C3   75 5A 00
                   MOV   5CH,#00H                     ;04C6   75 5C 00
                   MOV   5BH,#00H                     ;04C9   75 5B 00
                   MOV   5DH,#00H                     ;04CC   75 5D 00
Q04CF:             MOV   R5,#08H                      ;04CF   7D 08
                   MOV   59H,#00H                     ;04D1   75 59 00
                   MOV   5CH,5AH                      ;04D4   85 5A 5C
                   LCALL Q066E                        ;04D7   12 06 6E
                   MOV   A,#0F0H                      ;04DA   74 F0
                   LCALL Q068D                        ;04DC   12 06 8D
Q04DF:             LCALL Q06BD                        ;04DF   12 06 BD
                   RL    A                            ;04E2   23
                   PUSH  DPL                          ;04E3   C0 82
                   PUSH  DPH                          ;04E5   C0 83
                   CPL   P1.7                         ;04E7   B2 97
                   MOV   DPTR,#04EDH                  ;04E9   90 04 ED
                   JMP   @A+DPTR                      ;04EC   73
                   AJMP  Q04F5                        ;04ED   81 F5
                   AJMP  Q050F                        ;04EF   A1 0F
                   AJMP  Q0526                        ;04F1   A1 26
                   AJMP  Q053D                        ;04F3   A1 3D
Q04F5:             POP   DPH                          ;04F5   D0 83
                   POP   DPL                          ;04F7   D0 82
                   INC   59H                          ;04F9   05 59
                   LCALL Q0544                        ;04FB   12 05 44
                   LCALL Q0696                        ;04FE   12 06 96
                   LCALL Q05A0                        ;0501   12 05 A0
                   MOV   A,5BH                        ;0504   E5 5B
                   JNZ   Q0541                        ;0506   70 39
                   MOV   A,5AH                        ;0508   E5 5A
                   CJNE  A,5CH,Q04CF                  ;050A   B5 5C C2
                   AJMP  Q04DF                        ;050D   81 DF
Q050F:             POP   DPH                          ;050F   D0 83
                   POP   DPL                          ;0511   D0 82
                   CLR   C                            ;0513   C3
                   LCALL Q0696                        ;0514   12 06 96
                   CLR   C                            ;0517   C3
                   LCALL Q05A0                        ;0518   12 05 A0
                   MOV   A,5BH                        ;051B   E5 5B
                   JNZ   Q0541                        ;051D   70 22
                   MOV   A,5AH                        ;051F   E5 5A
                   CJNE  A,5CH,Q04CF                  ;0521   B5 5C AB
                   AJMP  Q04DF                        ;0524   81 DF
Q0526:             POP   DPH                          ;0526   D0 83
                   POP   DPL                          ;0528   D0 82
                   SETB  C                            ;052A   D3
                   LCALL Q0696                        ;052B   12 06 96
                   SETB  C                            ;052E   D3
                   LCALL Q05A0                        ;052F   12 05 A0
                   MOV   A,5BH                        ;0532   E5 5B
                   JNZ   Q0541                        ;0534   70 0B
                   MOV   A,5AH                        ;0536   E5 5A
                   CJNE  A,5CH,Q04CF                  ;0538   B5 5C 94
                   AJMP  Q04DF                        ;053B   81 DF
Q053D:             POP   DPH                          ;053D   D0 83
                   POP   DPL                          ;053F   D0 82
Q0541:             POP   PSW                          ;0541   D0 D0
                   RET                                ;0543   22
Q0544:             MOV   R0,#20H                      ;0544   78 20
                   MOV   A,59H                        ;0546   E5 59
                   MOV   R3,59H                       ;0548   AB 59
                   MOV   B,#08H                       ;054A   75 F0 08
                   DIV   AB                           ;054D   84
                   MOV   5EH,A                        ;054E   F5 5E
                   MOV   A,B                          ;0550   E5 F0
                   JZ    Q055F                        ;0552   60 0B
                   MOV   A,B                          ;0554   E5 F0
                   MOV   R7,A                         ;0556   FF
                   MOV   A,5EH                        ;0557   E5 5E
                   ADD   A,#20H                       ;0559   24 20
                   MOV   R0,A                         ;055B   F8
                   MOV   A,@R0                        ;055C   E6
                   AJMP  Q0568                        ;055D   A1 68
Q055F:             MOV   R7,#08H                      ;055F   7F 08
                   MOV   A,5EH                        ;0561   E5 5E
                   DEC   A                            ;0563   14
                   ADD   A,#20H                       ;0564   24 20
                   MOV   R0,A                         ;0566   F8
                   MOV   A,@R0                        ;0567   E6
Q0568:             CLR   C                            ;0568   C3
Q0569:             RRC   A                            ;0569   13
                   DJNZ  R7,Q0569                     ;056A   DF FD
                   RET                                ;056C   22
Q056D:             MOV   28H.3,C                      ;056D   92 43
                   MOV   R0,#20H                      ;056F   78 20
                   MOV   A,59H                        ;0571   E5 59
                   MOV   R3,59H                       ;0573   AB 59
                   MOV   B,#08H                       ;0575   75 F0 08
                   DIV   AB                           ;0578   84
                   MOV   5EH,A                        ;0579   F5 5E
                   MOV   A,B                          ;057B   E5 F0
                   JZ    Q058A                        ;057D   60 0B
                   MOV   A,B                          ;057F   E5 F0
                   MOV   R7,A                         ;0581   FF
                   MOV   A,5EH                        ;0582   E5 5E
                   ADD   A,#20H                       ;0584   24 20
                   MOV   R0,A                         ;0586   F8
                   MOV   A,@R0                        ;0587   E6
                   AJMP  Q0593                        ;0588   A1 93
Q058A:             MOV   R7,#08H                      ;058A   7F 08
                   MOV   A,5EH                        ;058C   E5 5E
                   DEC   A                            ;058E   14
                   ADD   A,#20H                       ;058F   24 20
                   MOV   R0,A                         ;0591   F8
                   MOV   A,@R0                        ;0592   E6
Q0593:             MOV   R6,#00H                      ;0593   7E 00
Q0595:             RRC   A                            ;0595   13
                   INC   R6                           ;0596   0E
                   DJNZ  R7,Q0595                     ;0597   DF FC
                   MOV   C,28H.3                      ;0599   A2 43
Q059B:             RLC   A                            ;059B   33
                   DJNZ  R6,Q059B                     ;059C   DE FD
                   MOV   @R0,A                        ;059E   F6
                   RET                                ;059F   22
Q05A0:             CPL   P1.7                         ;05A0   B2 97
                   MOV   A,5DH                        ;05A2   E5 5D
                   RRC   A                            ;05A4   13
                   MOV   5DH,A                        ;05A5   F5 5D
                   DJNZ  R4,Q05D2                     ;05A7   DC 29
                   MOV   R4,#08H                      ;05A9   7C 08
                   MOV   A,5DH                        ;05AB   E5 5D
                   MOV   @R1,A                        ;05AD   F7
                   INC   R1                           ;05AE   09
                   DJNZ  R5,Q05D2                     ;05AF   DD 21
                   MOV   R5,#08H                      ;05B1   7D 08
                   LCALL Q05D3                        ;05B3   12 05 D3
                   MOV   R0,#60H                      ;05B6   78 60
                   MOV   R6,#07H                      ;05B8   7E 07
                   LCALL Q09A1                        ;05BA   12 09 A1
                   XRL   A,@R0                        ;05BD   66
                   JNZ   Q05D0                        ;05BE   70 10
                   INC   5AH                          ;05C0   05 5A
                   MOV   R1,#60H                      ;05C2   79 60
                   MOV   R3,#08H                      ;05C4   7B 08
Q05C6:             MOV   A,@R1                        ;05C6   E7
                   MOV   B,A                          ;05C7   F5 F0
                   LCALL Q038B                        ;05C9   12 03 8B
                   INC   DPTR                         ;05CC   A3
                   INC   R1                           ;05CD   09
                   DJNZ  R3,Q05C6                     ;05CE   DB F6
Q05D0:             MOV   R1,#60H                      ;05D0   79 60
Q05D2:             RET                                ;05D2   22
Q05D3:             MOV   R3,59H                       ;05D3   AB 59
                   LCALL Q0544                        ;05D5   12 05 44
                   JC    Q05E0                        ;05D8   40 06
                   SETB  C                            ;05DA   D3
                   LCALL Q056D                        ;05DB   12 05 6D
                   AJMP  Q05EC                        ;05DE   A1 EC
Q05E0:             CLR   C                            ;05E0   C3
                   LCALL Q056D                        ;05E1   12 05 6D
                   DJNZ  59H,Q05D3                    ;05E4   D5 59 EC
                   MOV   R3,59H                       ;05E7   AB 59
                   MOV   5BH,#01H                     ;05E9   75 5B 01
Q05EC:             RET                                ;05EC   22
Q05ED:             CPL   P1.7                         ;05ED   B2 97
                   SETB  29H.6                        ;05EF   D2 4E
                   CLR   P0.1                         ;05F1   C2 81
                   MOV   R7,#0FAH                     ;05F3   7F FA
Q05F5:             NOP                                ;05F5   00
                   NOP                                ;05F6   00
                   DJNZ  R7,Q05F5                     ;05F7   DF FC
                   SETB  P0.1                         ;05F9   D2 81
                   MOV   R7,#28H                      ;05FB   7F 28
                   DJNZ  R7,$                         ;05FD   DF FE
                   MOV   R7,#32H                      ;05FF   7F 32
Q0601:             MOV   C,P0.1                       ;0601   A2 81
                   JNC   Q0609                        ;0603   50 04
                   DJNZ  R7,Q0601                     ;0605   DF FA
                   CLR   29H.6                        ;0607   C2 4E
Q0609:             MOV   R7,#0FAH                     ;0609   7F FA
                   DJNZ  R7,$                         ;060B   DF FE
                   RET                                ;060D   22
Q060E:             MOV   R7,#08H                      ;060E   7F 08
Q0610:             RRC   A                            ;0610   13
                   LCALL Q0617                        ;0611   12 06 17
                   DJNZ  R7,Q0610                     ;0614   DF FA
                   RET                                ;0616   22
Q0617:             CPL   P1.7                         ;0617   B2 97
                   CLR   P0.1                         ;0619   C2 81
                   JC    Q0621                        ;061B   40 04
                   MOV   R6,#19H                      ;061D   7E 19
                   DJNZ  R6,$                         ;061F   DE FE
Q0621:             MOV   R6,#04H                      ;0621   7E 04
                   DJNZ  R6,$                         ;0623   DE FE
                   SETB  P0.1                         ;0625   D2 81
                   CLR   P0.0                         ;0627   C2 80
                   NOP                                ;0629   00
                   SETB  P0.0                         ;062A   D2 80
                   MOV   R6,#3CH                      ;062C   7E 3C
                   DJNZ  R6,$                         ;062E   DE FE
                   CPL   P1.7                         ;0630   B2 97
                   RET                                ;0632   22
Q0633:             MOV   R7,#08H                      ;0633   7F 08
Q0635:             LCALL Q0646                        ;0635   12 06 46
                   RRC   A                            ;0638   13
                   DJNZ  R7,Q0635                     ;0639   DF FA
                   RET                                ;063B   22
Q063C:             CLR   A                            ;063C   E4
                   MOV   R7,#02H                      ;063D   7F 02
Q063F:             LCALL Q0646                        ;063F   12 06 46
                   RLC   A                            ;0642   33
                   DJNZ  R7,Q063F                     ;0643   DF FA
                   RET                                ;0645   22
Q0646:             CPL   P1.7                         ;0646   B2 97
                   NOP                                ;0648   00
                   CLR   P0.1                         ;0649   C2 81
                   SETB  P2.6                         ;064B   D2 A6
                   NOP                                ;064D   00
                   CLR   P2.6                         ;064E   C2 A6
                   SETB  P0.1                         ;0650   D2 81
                   CLR   P0.0                         ;0652   C2 80
                   SETB  P0.0                         ;0654   D2 80
                   MOV   R6,#06H                      ;0656   7E 06
                   DJNZ  R6,$                         ;0658   DE FE
                   NOP                                ;065A   00
                   NOP                                ;065B   00
                   NOP                                ;065C   00
                   MOV   C,P0.1                       ;065D   A2 81
                   MOV   R6,#13H                      ;065F   7E 13
                   DJNZ  R6,$                         ;0661   DE FE
                   SETB  P0.1                         ;0663   D2 81
                   CLR   P0.0                         ;0665   C2 80
                   NOP                                ;0667   00
                   NOP                                ;0668   00
                   SETB  P0.0                         ;0669   D2 80
                   CPL   P1.7                         ;066B   B2 97
                   RET                                ;066D   22
Q066E:             SETB  29H.6                        ;066E   D2 4E
                   CLR   P0.7                         ;0670   C2 87
                   MOV   R7,#0FAH                     ;0672   7F FA
Q0674:             NOP                                ;0674   00
                   NOP                                ;0675   00
                   DJNZ  R7,Q0674                     ;0676   DF FC
                   SETB  P0.7                         ;0678   D2 87
                   MOV   R7,#28H                      ;067A   7F 28
                   DJNZ  R7,$                         ;067C   DF FE
                   MOV   R7,#32H                      ;067E   7F 32
Q0680:             MOV   C,P0.7                       ;0680   A2 87
                   JNC   Q0688                        ;0682   50 04
                   DJNZ  R7,Q0680                     ;0684   DF FA
                   CLR   29H.6                        ;0686   C2 4E
Q0688:             MOV   R7,#0FAH                     ;0688   7F FA
                   DJNZ  R7,$                         ;068A   DF FE
                   RET                                ;068C   22
Q068D:             MOV   R7,#08H                      ;068D   7F 08
Q068F:             RRC   A                            ;068F   13
                   LCALL Q0696                        ;0690   12 06 96
                   DJNZ  R7,Q068F                     ;0693   DF FA
                   RET                                ;0695   22
Q0696:             CPL   P1.7                         ;0696   B2 97
                   CLR   P0.7                         ;0698   C2 87
                   JC    Q06A0                        ;069A   40 04
                   MOV   R6,#19H                      ;069C   7E 19
                   DJNZ  R6,$                         ;069E   DE FE
Q06A0:             MOV   R6,#04H                      ;06A0   7E 04
                   DJNZ  R6,$                         ;06A2   DE FE
                   SETB  P0.7                         ;06A4   D2 87
                   CLR   P0.6                         ;06A6   C2 86
                   NOP                                ;06A8   00
                   SETB  P0.6                         ;06A9   D2 86
                   MOV   R6,#3CH                      ;06AB   7E 3C
                   DJNZ  R6,$                         ;06AD   DE FE
                   CPL   P1.7                         ;06AF   B2 97
                   RET                                ;06B1   22
Q06B2:             CPL   P1.7                         ;06B2   B2 97
                   MOV   R7,#08H                      ;06B4   7F 08
Q06B6:             LCALL Q06C7                        ;06B6   12 06 C7
                   RRC   A                            ;06B9   13
                   DJNZ  R7,Q06B6                     ;06BA   DF FA
                   RET                                ;06BC   22
Q06BD:             CLR   A                            ;06BD   E4
                   MOV   R7,#02H                      ;06BE   7F 02
Q06C0:             LCALL Q06C7                        ;06C0   12 06 C7
                   RLC   A                            ;06C3   33
                   DJNZ  R7,Q06C0                     ;06C4   DF FA
                   RET                                ;06C6   22
Q06C7:             CPL   P1.7                         ;06C7   B2 97
                   NOP                                ;06C9   00
                   CLR   P0.7                         ;06CA   C2 87
                   SETB  P2.7                         ;06CC   D2 A7
                   NOP                                ;06CE   00
                   CLR   P2.7                         ;06CF   C2 A7
                   SETB  P0.7                         ;06D1   D2 87
                   CLR   P0.6                         ;06D3   C2 86
                   SETB  P0.6                         ;06D5   D2 86
                   MOV   R6,#06H                      ;06D7   7E 06
                   DJNZ  R6,$                         ;06D9   DE FE
                   NOP                                ;06DB   00
                   NOP                                ;06DC   00
                   NOP                                ;06DD   00
                   MOV   C,P0.7                       ;06DE   A2 87
                   MOV   R6,#13H                      ;06E0   7E 13
                   DJNZ  R6,$                         ;06E2   DE FE
                   SETB  P0.7                         ;06E4   D2 87
                   CLR   P0.6                         ;06E6   C2 86
                   NOP                                ;06E8   00
                   NOP                                ;06E9   00
                   SETB  P0.6                         ;06EA   D2 86
                   CPL   P1.7                         ;06EC   B2 97
                   RET                                ;06EE   22
Q06EF:             MOV   R6,#02H                      ;06EF   7E 02
Q06F1:             MOV   R7,#0FAH                     ;06F1   7F FA
                   DJNZ  R7,$                         ;06F3   DF FE
                   DJNZ  R6,Q06F1                     ;06F5   DE FA
                   CPL   P1.7                         ;06F7   B2 97
                   RET                                ;06F9   22
Q06FA:             MOV   R6,#14H                      ;06FA   7E 14
Q06FC:             MOV   R7,#0FAH                     ;06FC   7F FA
                   DJNZ  R7,$                         ;06FE   DF FE
                   DJNZ  R6,Q06FC                     ;0700   DE FA
                   CPL   P1.7                         ;0702   B2 97
                   RET                                ;0704   22
Q0705:                 DB  7EH,0C8H, 7FH,0FAH,0DFH,0FEH,0DEH,0FAH        ;~......
Q070D:                 DB 0B2H, 97H, 22H        ;.."
Q0710:             MOV   R5,#0AH                      ;0710   7D 0A
Q0712:             MOV   R6,#0C8H                     ;0712   7E C8
Q0714:             MOV   R7,#0FAH                     ;0714   7F FA
                   DJNZ  R7,$                         ;0716   DF FE
                   DJNZ  R6,Q0714                     ;0718   DE FA
                   CPL   P1.7                         ;071A   B2 97
                   DJNZ  R5,Q0712                     ;071C   DD F4
                   RET                                ;071E   22
Q071F:             CPL   P1.7                         ;071F   B2 97
                   JBC   TI,Q0726                     ;0721   10 99 02
                   SJMP  Q071F                        ;0724   80 F9
Q0726:             LCALL Q06EF                        ;0726   12 06 EF
                   RET                                ;0729   22
Q072A:             CPL   P1.7                         ;072A   B2 97
                   JBC   RI,Q0731                     ;072C   10 98 02
                   SJMP  Q072A                        ;072F   80 F9
Q0731:             RET                                ;0731   22
Q0732:             MOV   A,7DH                        ;0732   E5 7D
                   JZ    Q075E                        ;0734   60 28
                   LCALL Q05ED                        ;0736   12 05 ED
                   MOV   A,#0CCH                      ;0739   74 CC
                   LCALL Q060E                        ;073B   12 06 0E
                   NOP                                ;073E   00
                   MOV   A,#44H                       ;073F   74 44
                   LCALL Q060E                        ;0741   12 06 0E
                   CLR   P0.0                         ;0744   C2 80
                   NOP                                ;0746   00
                   NOP                                ;0747   00
                   NOP                                ;0748   00
                   NOP                                ;0749   00
                   NOP                                ;074A   00
                   NOP                                ;074B   00
                   NOP                                ;074C   00
                   NOP                                ;074D   00
                   NOP                                ;074E   00
                   NOP                                ;074F   00
                   SETB  P0.0                         ;0750   D2 80
                   CPL   P1.7                         ;0752   B2 97
                   LCALL Q0710                        ;0754   12 07 10
                   CPL   P1.7                         ;0757   B2 97
                   LCALL Q0710                        ;0759   12 07 10
                   CPL   P1.7                         ;075C   B2 97
Q075E:             LCALL Q05ED                        ;075E   12 05 ED
                   RET                                ;0761   22
Q0762:             MOV   A,7EH                        ;0762   E5 7E
                   JZ    Q078E                        ;0764   60 28
                   LCALL Q066E                        ;0766   12 06 6E
                   MOV   A,#0CCH                      ;0769   74 CC
                   LCALL Q068D                        ;076B   12 06 8D
                   NOP                                ;076E   00
                   MOV   A,#44H                       ;076F   74 44
                   LCALL Q068D                        ;0771   12 06 8D
                   CLR   P0.6                         ;0774   C2 86
                   NOP                                ;0776   00
                   NOP                                ;0777   00
                   NOP                                ;0778   00
                   NOP                                ;0779   00
                   NOP                                ;077A   00
                   NOP                                ;077B   00
                   NOP                                ;077C   00
                   NOP                                ;077D   00
                   NOP                                ;077E   00
                   NOP                                ;077F   00
                   SETB  P0.6                         ;0780   D2 86
                   CPL   P1.7                         ;0782   B2 97
                   LCALL Q0710                        ;0784   12 07 10
                   CPL   P1.7                         ;0787   B2 97
                   LCALL Q0710                        ;0789   12 07 10
                   CPL   P1.7                         ;078C   B2 97
Q078E:             LCALL Q066E                        ;078E   12 06 6E
                   RET                                ;0791   22
Q0792:             CPL   P1.7                         ;0792   B2 97
                   MOV   DPTR,#0000H                  ;0794   90 00 00
                   MOV   R5,#08H                      ;0797   7D 08
                   MOV   R0,#60H                      ;0799   78 60
Q079B:             LCALL Q036A                        ;079B   12 03 6A
                   MOV   @R0,A                        ;079E   F6
                   INC   DPTR                         ;079F   A3
                   INC   R0                           ;07A0   08
                   DJNZ  R5,Q079B                     ;07A1   DD F8
                   SETB  29H.7                        ;07A3   D2 4F
                   MOV   R0,#60H                      ;07A5   78 60
                   MOV   R6,#07H                      ;07A7   7E 07
                   LCALL Q09A1                        ;07A9   12 09 A1
                   XRL   A,@R0                        ;07AC   66
                   JZ    Q07C1                        ;07AD   60 12
                   MOV   50H,#00H                     ;07AF   75 50 00
                   MOV   51H,#00H                     ;07B2   75 51 00
                   MOV   52H,#00H                     ;07B5   75 52 00
                   MOV   53H,#00H                     ;07B8   75 53 00
                   CPL   P1.7                         ;07BB   B2 97
                   AJMP  Q07E4                        ;07BD   E1 E4
                   CPL   P1.7                         ;07BF   B2 97
Q07C1:             LCALL Q05ED                        ;07C1   12 05 ED
                   MOV   A,#55H                       ;07C4   74 55
                   LCALL Q060E                        ;07C6   12 06 0E
                   MOV   R5,#08H                      ;07C9   7D 08
                   MOV   R0,#60H                      ;07CB   78 60
Q07CD:             MOV   A,@R0                        ;07CD   E6
                   LCALL Q060E                        ;07CE   12 06 0E
                   INC   R0                           ;07D1   08
                   DJNZ  R5,Q07CD                     ;07D2   DD F9
                   MOV   A,#0BEH                      ;07D4   74 BE
                   LCALL Q060E                        ;07D6   12 06 0E
                   MOV   R5,#09H                      ;07D9   7D 09
                   MOV   R1,#50H                      ;07DB   79 50
Q07DD:             LCALL Q0633                        ;07DD   12 06 33
                   MOV   @R1,A                        ;07E0   F7
                   INC   R1                           ;07E1   09
                   DJNZ  R5,Q07DD                     ;07E2   DD F9
Q07E4:             RET                                ;07E4   22
Q07E5:             CPL   P1.7                         ;07E5   B2 97
                   MOV   DPTR,#0800H                  ;07E7   90 08 00
                   MOV   R5,#08H                      ;07EA   7D 08
                   MOV   R0,#60H                      ;07EC   78 60
Q07EE:             LCALL Q036A                        ;07EE   12 03 6A
                   MOV   @R0,A                        ;07F1   F6
                   INC   DPTR                         ;07F2   A3
                   INC   R0                           ;07F3   08
                   DJNZ  R5,Q07EE                     ;07F4   DD F8
                   SETB  29H.7                        ;07F6   D2 4F
                   MOV   R0,#60H                      ;07F8   78 60
                   MOV   R6,#07H                      ;07FA   7E 07
                   LCALL Q09A1                        ;07FC   12 09 A1
                   XRL   A,@R0                        ;07FF   66
                   JZ    Q0815                        ;0800   60 13
                   MOV   50H,#00H                     ;0802   75 50 00
                   MOV   51H,#00H                     ;0805   75 51 00
                   MOV   52H,#00H                     ;0808   75 52 00
                   MOV   53H,#00H                     ;080B   75 53 00
                   CPL   P1.7                         ;080E   B2 97
                   LJMP  Q0838                        ;0810   02 08 38
Q0813:                 DB 0B2H, 97H        ;..
Q0815:             LCALL Q066E                        ;0815   12 06 6E
                   MOV   A,#55H                       ;0818   74 55
                   LCALL Q068D                        ;081A   12 06 8D
                   MOV   R5,#08H                      ;081D   7D 08
                   MOV   R0,#60H                      ;081F   78 60
Q0821:             MOV   A,@R0                        ;0821   E6
                   LCALL Q068D                        ;0822   12 06 8D
                   INC   R0                           ;0825   08
                   DJNZ  R5,Q0821                     ;0826   DD F9
                   MOV   A,#0BEH                      ;0828   74 BE
                   LCALL Q068D                        ;082A   12 06 8D
                   MOV   R5,#09H                      ;082D   7D 09
                   MOV   R1,#50H                      ;082F   79 50
Q0831:             LCALL Q06B2                        ;0831   12 06 B2
                   MOV   @R1,A                        ;0834   F7
                   INC   R1                           ;0835   09
                   DJNZ  R5,Q0831                     ;0836   DD F9
Q0838:             RET                                ;0838   22
Q0839:             CPL   P1.7                         ;0839   B2 97
                   MOV   A,7DH                        ;083B   E5 7D
                   JZ    Q08B5                        ;083D   60 76
                   MOV   R4,A                         ;083F   FC
                   MOV   DPTR,#0000H                  ;0840   90 00 00
Q0843:             MOV   R5,#08H                      ;0843   7D 08
                   MOV   R0,#60H                      ;0845   78 60
Q0847:             LCALL Q036A                        ;0847   12 03 6A
                   MOV   @R0,A                        ;084A   F6
                   INC   DPTR                         ;084B   A3
                   INC   R0                           ;084C   08
                   DJNZ  R5,Q0847                     ;084D   DD F8
                   SETB  29H.7                        ;084F   D2 4F
                   MOV   R0,#60H                      ;0851   78 60
                   MOV   R6,#07H                      ;0853   7E 07
                   LCALL Q09A1                        ;0855   12 09 A1
                   XRL   A,@R0                        ;0858   66
                   JZ    Q0870                        ;0859   60 15
                   CLR   29H.7                        ;085B   C2 4F
                   MOV   50H,#00H                     ;085D   75 50 00
                   MOV   51H,#00H                     ;0860   75 51 00
                   MOV   52H,#00H                     ;0863   75 52 00
                   MOV   53H,#00H                     ;0866   75 53 00
                   CPL   P1.7                         ;0869   B2 97
                   LJMP  Q08B1                        ;086B   02 08 B1
Q086E:                 DB 0B2H, 97H        ;..
Q0870:             LCALL Q05ED                        ;0870   12 05 ED
                   MOV   A,#55H                       ;0873   74 55
                   LCALL Q060E                        ;0875   12 06 0E
                   MOV   R5,#08H                      ;0878   7D 08
                   MOV   R0,#60H                      ;087A   78 60
Q087C:             MOV   A,@R0                        ;087C   E6
                   LCALL Q060E                        ;087D   12 06 0E
                   INC   R0                           ;0880   08
                   DJNZ  R5,Q087C                     ;0881   DD F9
                   MOV   A,#0BEH                      ;0883   74 BE
                   LCALL Q060E                        ;0885   12 06 0E
                   MOV   R5,#09H                      ;0888   7D 09
                   MOV   R1,#50H                      ;088A   79 50
Q088C:             LCALL Q0633                        ;088C   12 06 33
                   MOV   @R1,A                        ;088F   F7
                   INC   R1                           ;0890   09
                   DJNZ  R5,Q088C                     ;0891   DD F9
                   SETB  28H.5                        ;0893   D2 45
                   MOV   R0,#50H                      ;0895   78 50
                   MOV   R6,#08H                      ;0897   7E 08
                   LCALL Q09A1                        ;0899   12 09 A1
                   XRL   A,@R0                        ;089C   66
                   JZ    Q08A1                        ;089D   60 02
                   CLR   28H.5                        ;089F   C2 45
Q08A1:             MOV   R5,#04H                      ;08A1   7D 04
                   MOV   R1,#50H                      ;08A3   79 50
Q08A5:             MOV   A,@R1                        ;08A5   E7
                   MOV   SBUF,A                       ;08A6   F5 99
                   INC   R1                           ;08A8   09
                   LCALL Q033E                        ;08A9   12 03 3E
                   LCALL Q071F                        ;08AC   12 07 1F
                   DJNZ  R5,Q08A5                     ;08AF   DD F4
Q08B1:             CPL   P1.7                         ;08B1   B2 97
                   DJNZ  R4,Q0843                     ;08B3   DC 8E
Q08B5:             RET                                ;08B5   22
Q08B6:             CPL   P1.7                         ;08B6   B2 97
                   MOV   A,7EH                        ;08B8   E5 7E
                   JZ    Q0931                        ;08BA   60 75
                   MOV   R4,A                         ;08BC   FC
                   MOV   DPTR,#0800H                  ;08BD   90 08 00
Q08C0:             MOV   R5,#08H                      ;08C0   7D 08
                   MOV   R0,#60H                      ;08C2   78 60
Q08C4:             LCALL Q036A                        ;08C4   12 03 6A
                   MOV   @R0,A                        ;08C7   F6
                   INC   DPTR                         ;08C8   A3
                   INC   R0                           ;08C9   08
                   CPL   P1.7                         ;08CA   B2 97
                   DJNZ  R5,Q08C4                     ;08CC   DD F6
                   SETB  29H.7                        ;08CE   D2 4F
                   MOV   R0,#60H                      ;08D0   78 60
                   MOV   R6,#07H                      ;08D2   7E 07
                   LCALL Q09A1                        ;08D4   12 09 A1
                   XRL   A,@R0                        ;08D7   66
                   JZ    Q08ED                        ;08D8   60 13
                   CLR   29H.7                        ;08DA   C2 4F
                   MOV   50H,#00H                     ;08DC   75 50 00
                   MOV   51H,#00H                     ;08DF   75 51 00
                   MOV   52H,#00H                     ;08E2   75 52 00
                   MOV   53H,#00H                     ;08E5   75 53 00
                   LJMP  Q092D                        ;08E8   02 09 2D
Q08EB:                 DB 0B2H, 97H        ;..
Q08ED:             LCALL Q066E                        ;08ED   12 06 6E
                   MOV   A,#55H                       ;08F0   74 55
                   LCALL Q068D                        ;08F2   12 06 8D
                   MOV   R5,#08H                      ;08F5   7D 08
                   MOV   R0,#60H                      ;08F7   78 60
Q08F9:             MOV   A,@R0                        ;08F9   E6
                   LCALL Q068D                        ;08FA   12 06 8D
                   INC   R0                           ;08FD   08
                   DJNZ  R5,Q08F9                     ;08FE   DD F9
                   MOV   A,#0BEH                      ;0900   74 BE
                   LCALL Q068D                        ;0902   12 06 8D
                   MOV   R5,#09H                      ;0905   7D 09
                   MOV   R1,#50H                      ;0907   79 50
Q0909:             LCALL Q06B2                        ;0909   12 06 B2
                   MOV   @R1,A                        ;090C   F7
                   INC   R1                           ;090D   09
                   DJNZ  R5,Q0909                     ;090E   DD F9
                   SETB  28H.5                        ;0910   D2 45
                   MOV   R0,#50H                      ;0912   78 50
                   MOV   R6,#08H                      ;0914   7E 08
                   LCALL Q09A1                        ;0916   12 09 A1
                   XRL   A,@R0                        ;0919   66
                   JZ    Q091E                        ;091A   60 02
                   CLR   28H.5                        ;091C   C2 45
Q091E:             MOV   R5,#04H                      ;091E   7D 04
                   MOV   R1,#50H                      ;0920   79 50
Q0922:             MOV   SBUF,@R1                     ;0922   87 99
                   INC   R1                           ;0924   09
                   LCALL Q033E                        ;0925   12 03 3E
                   LCALL Q071F                        ;0928   12 07 1F
                   DJNZ  R5,Q0922                     ;092B   DD F5
Q092D:             CPL   P1.7                         ;092D   B2 97
                   DJNZ  R4,Q08C0                     ;092F   DC 8F
Q0931:             RET                                ;0931   22
Q0932:                 DB 0B2H, 97H,0E5H, 54H, 23H, 23H, 54H, 18H        ;...T##T.
Q093A:                 DB 0F5H, 54H,0E5H, 28H, 54H, 20H, 45H, 54H        ;.T.(T.ET
Q0942:                 DB 0F5H,0F0H,0E5H, 51H, 54H, 87H, 45H,0F0H        ;...QT.E.
Q094A:                 DB 0F5H, 51H, 22H,0E5H, 52H, 60H, 4FH,0E5H        ;.Q".R`O.
Q0952:                 DB  53H, 60H, 4BH,0C3H, 94H, 0AH, 50H, 46H        ;S`K...PF
Q095A:                 DB 0C0H, 82H,0C0H, 83H, 15H, 52H,0E5H, 52H        ;.....R.R
Q0962:                 DB  75H,0F0H, 04H,0A4H,0C3H, 35H, 53H,0F5H        ;u....5S.
Q096A:                 DB  82H,0E5H,0F0H, 34H, 00H,0F5H, 83H,0B2H        ;...4....
Q0972:                 DB  97H,0E5H, 82H,0C3H, 94H, 01H,0F5H, 82H        ;........
Q097A:                 DB 0E5H, 83H, 94H, 00H,0F5H, 83H,0C3H,0E5H        ;........
Q0982:                 DB  82H, 33H,0F5H, 82H,0E5H, 83H, 33H, 24H        ;.3....3$
Q098A:                 DB  10H,0F5H, 83H,0E5H, 50H,0F5H,0F0H, 12H        ;....P...
Q0992:                 DB  03H, 8BH,0A3H,0E5H, 51H,0F5H,0F0H, 12H        ;....Q...
Q099A:                 DB  03H, 8BH,0D0H, 83H,0D0H, 82H, 22H        ;......"
Q09A1:             CPL   P1.7                         ;09A1   B2 97
                   MOV   B,#00H                       ;09A3   75 F0 00
Q09A6:             MOV   A,@R0                        ;09A6   E6
                   INC   R0                           ;09A7   08
                   MOV   R7,#08H                      ;09A8   7F 08
Q09AA:             CLR   C                            ;09AA   C3
                   RRC   A                            ;09AB   13
                   PUSH  ACC                          ;09AC   C0 E0
                   MOV   A,B                          ;09AE   E5 F0
                   MOV   28H.7,C                      ;09B0   92 47
                   MOV   C,ACC.0                      ;09B2   A2 E0
                   MOV   28H.4,C                      ;09B4   92 44
                   LCALL Q09DB                        ;09B6   12 09 DB
                   MOV   28H.7,C                      ;09B9   92 47
                   MOV   C,ACC.3                      ;09BB   A2 E3
                   MOV   28H.4,C                      ;09BD   92 44
                   LCALL Q09DB                        ;09BF   12 09 DB
                   MOV   ACC.3,C                      ;09C2   92 E3
                   MOV   C,ACC.4                      ;09C4   A2 E4
                   MOV   28H.4,C                      ;09C6   92 44
                   LCALL Q09DB                        ;09C8   12 09 DB
                   MOV   ACC.4,C                      ;09CB   92 E4
                   MOV   C,28H.7                      ;09CD   A2 47
                   RRC   A                            ;09CF   13
                   MOV   B,A                          ;09D0   F5 F0
                   POP   ACC                          ;09D2   D0 E0
                   DJNZ  R7,Q09AA                     ;09D4   DF D4
                   DJNZ  R6,Q09A6                     ;09D6   DE CE
                   MOV   A,B                          ;09D8   E5 F0
                   RET                                ;09DA   22
Q09DB:             MOV   C,28H.4                      ;09DB   A2 44
                   ANL   C,/28H.7                     ;09DD   B0 47
                   MOV   F0,C                         ;09DF   92 D5
                   CPL   28H.4                        ;09E1   B2 44
                   MOV   C,28H.4                      ;09E3   A2 44
                   ANL   C,28H.7                      ;09E5   82 47
                   ORL   C,F0                         ;09E7   72 D5
                   RET                                ;09E9   22
Q09EA:                 DB 0B2H, 97H, 12H, 03H, 55H,0E5H, 7DH, 60H        ;....U.}`
Q09F2:                 DB  4AH,0F5H, 99H, 30H, 99H,0FDH,0C2H, 99H        ;J..0....
Q09FA:                 DB 0FCH, 90H, 00H, 00H, 7DH, 08H, 78H, 60H        ;....}.x`
Q0A02:                 DB  12H, 03H, 6AH,0F6H,0F5H, 99H, 30H, 99H        ;..j...0.
Q0A0A:                 DB 0FDH,0C2H, 99H,0A3H, 08H,0DDH,0F1H, 12H        ;........
Q0A12:                 DB  05H,0EDH, 74H, 55H, 12H, 06H, 0EH, 7DH        ;..tU...}
Q0A1A:                 DB  08H, 78H, 60H,0E6H, 12H, 06H, 0EH, 08H        ;.x`.....
Q0A22:                 DB 0DDH,0F9H, 74H,0BEH, 12H, 06H, 0EH, 7DH        ;..t....}
Q0A2A:                 DB  09H, 79H, 50H, 12H, 06H, 33H,0F7H,0F5H        ;.yP..3..
Q0A32:                 DB  99H, 30H, 99H,0FDH,0C2H, 99H, 09H,0DDH        ;.0......
Q0A3A:                 DB 0F2H,0DCH,0C1H, 22H        ;..."
Q0A3E:             CPL   P1.7                         ;0A3E   B2 97
                   MOV   DPTR,#0000H                  ;0A40   90 00 00
                   MOV   A,69H                        ;0A43   E5 69
                   DEC   A                            ;0A45   14
                   MOV   B,#08H                       ;0A46   75 F0 08
                   MUL   AB                           ;0A49   A4
                   MOV   DPH,#00H                     ;0A4A   75 83 00
                   MOV   DPL,A                        ;0A4D   F5 82
                   MOV   R5,#08H                      ;0A4F   7D 08
                   MOV   R0,#60H                      ;0A51   78 60
Q0A53:             LCALL Q036A                        ;0A53   12 03 6A
                   MOV   @R0,A                        ;0A56   F6
                   INC   DPTR                         ;0A57   A3
                   INC   R0                           ;0A58   08
                   DJNZ  R5,Q0A53                     ;0A59   DD F8
                   LCALL Q05ED                        ;0A5B   12 05 ED
                   MOV   A,#55H                       ;0A5E   74 55
                   LCALL Q060E                        ;0A60   12 06 0E
                   MOV   R5,#08H                      ;0A63   7D 08
                   MOV   R0,#60H                      ;0A65   78 60
Q0A67:             MOV   A,@R0                        ;0A67   E6
                   LCALL Q060E                        ;0A68   12 06 0E
                   INC   R0                           ;0A6B   08
                   DJNZ  R5,Q0A67                     ;0A6C   DD F9
                   CPL   P1.7                         ;0A6E   B2 97
                   MOV   A,#4EH                       ;0A70   74 4E
                   LCALL Q060E                        ;0A72   12 06 0E
                   MOV   A,6BH                        ;0A75   E5 6B
                   LCALL Q060E                        ;0A77   12 06 0E
                   MOV   A,6CH                        ;0A7A   E5 6C
                   LCALL Q060E                        ;0A7C   12 06 0E
                   MOV   A,#7FH                       ;0A7F   74 7F
                   LCALL Q060E                        ;0A81   12 06 0E
                   LCALL Q05ED                        ;0A84   12 05 ED
                   MOV   A,#48H                       ;0A87   74 48
                   LCALL Q060E                        ;0A89   12 06 0E
                   CPL   P1.7                         ;0A8C   B2 97
                   LCALL Q05ED                        ;0A8E   12 05 ED
                   MOV   A,#55H                       ;0A91   74 55
                   LCALL Q060E                        ;0A93   12 06 0E
                   MOV   R5,#08H                      ;0A96   7D 08
                   MOV   R0,#60H                      ;0A98   78 60
Q0A9A:             MOV   A,@R0                        ;0A9A   E6
                   LCALL Q060E                        ;0A9B   12 06 0E
                   INC   R0                           ;0A9E   08
                   DJNZ  R5,Q0A9A                     ;0A9F   DD F9
                   MOV   A,#48H                       ;0AA1   74 48
                   LCALL Q060E                        ;0AA3   12 06 0E
                   MOV   R7,#0FFH                     ;0AA6   7F FF
                   DJNZ  R7,$                         ;0AA8   DF FE
                   MOV   R7,#0FFH                     ;0AAA   7F FF
                   DJNZ  R7,$                         ;0AAC   DF FE
                   LCALL Q05ED                        ;0AAE   12 05 ED
                   RET                                ;0AB1   22
ID:1 发表于 2013-8-11 22:29 | 只看该作者
这个是用什么软件反汇编的?
ID:7485 发表于 2013-8-12 08:07 | 只看该作者
读出的芯片中的机器码反汇编的吧?
不知道硬件系统的晶振频率,就不好确定波特率。
如果晶振是11.0592M,单片机是标准的51,那么波特率就是9600。
