查看: 3504|回复: 1
数码管动态显示
ID:82008 发表于 2015-6-5 00:32 | 显示全部楼层 |阅读模式
电路图详见:http://www.51hei.com/f/51hei-5.pdf
#include <reg52.h>
sbit wexu=P2^7;
sbit duxu=P2^6;
uchar numdu,numwe,a,b,c;
uchar code tabledu[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code tablewe[]={
0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
        EA=1;
        ET0=1;
        TMOD=0X01;
        TH0=(65536-500)/256;
        TL0=(65536-500)%256;
        TR0=1;
        numdu=1;
        numwe=0;
                if(a==1)
                        a=0;
                        wexu=1;
                        P0=tablewe[numwe];
                        wexu=0;
                        numwe++;
                        if(numwe==6)
                                numwe=0;
                        duxu=1;
                        P0=tabledu[numdu];
                        duxu=0;
                        numdu++;
                        if(numdu==7)
                                numdu=1;
void timer0() interrupt 1
        TH0=(65536-1)/256;
        TL0=(65536-1)%256;
        a++;
ID:45963 发表于 2015-6-21 16:49 | 显示全部楼层
51学习版的数码管动态有些麻烦,干其它工作时间长了,就闪烁了。
