查看: 1808|回复: 1
帮忙看下这个流水灯怎么没用???
ID:111421 发表于 2016-4-8 22:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"stm32f10x_lib.h"
void NVIC_Configuration(void);
void TIM2_Configuration(void);
int j;
int main(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO,ENABLE);
        GPIO_InitStructure.GPIO_Pin= GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8;   //PB的5678接LED2345
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE);
        NVIC_Configuration();//初始化中断嵌套
        TIM2_Configuration();//初始化定时器
         if(j>=100) j=0;
         else if(j%4==0)
          GPIO_SetBits(GPIOB,GPIO_Pin_5);
          GPIO_ResetBits(GPIOB,GPIO_Pin_6);
          GPIO_ResetBits(GPIOB,GPIO_Pin_7);
          GPIO_ResetBits(GPIOB,GPIO_Pin_8);
         else if(j%4==1)
          GPIO_SetBits(GPIOB,GPIO_Pin_6);
          GPIO_ResetBits(GPIOB,GPIO_Pin_5);
         else if(j%4==2)
          GPIO_SetBits(GPIOB,GPIO_Pin_7);
         else if(j%4==3)
          GPIO_SetBits(GPIOB,GPIO_Pin_8);
    }                                                          //在这写灯程序
   NVIC_InitTypeDef NVIC_InitStructure;
   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);        //配置优先级组
   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;  //设置TIM2通道输入中断
   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; /* Configure the NVIC Preemption Priority Bits[配置优先级组] */
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;   /* Enable the TIM2 gloabal Interrupt [允许TIM2全局中断]*/
   NVIC_Init(&NVIC_InitStructure);
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //在开启时钟里一定要打开TIM2的时钟
  TIM_DeInit(TIM2) ;
  TIM_TimeBaseStructure.TIM_Period = 19;
  TIM_TimeBaseStructure.TIM_Prescaler = 35999;     //分频35999
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;     // 时钟分割
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //计数方向向上计数
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_ClearFlag(TIM2, TIM_FLAG_Update);        /*清除更新标志位*/
  TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE); //使能TIM2的更新
  TIM_Cmd(TIM2, ENABLE);          //TIM2 enable counter
void TIM2_IRQHandler(void)
{        int i=0;
    if (TIM_GetITStatus(TIM2, TIM_IT_Update) == SET)
                TIM_ClearITPendingBit(TIM2,TIM_IT_Update);
                i++;
                if(i>=100)
                        j++;
                        i=0;
ID:113133 发表于 2016-4-9 16:49 | 只看该作者
不知道
