查看: 2119|回复: 0
51单片机IO直接驱动LCD6402显示实时温度源程序
IO直接驱动
void data_display()
   lcd_segbuf[0]=lcd_data_buf[3]&0x0f;
   lcd_segbuf[1]=(lcd_data_buf[4]&0xf0)>>4;
void main(void)
          IO_INT();                 //IO口初始化                main.c
      CLK_INT();         //时钟设置初始化        main.c
          clr_wtd();
          lcd_int();
            init_global_value();  //初始化全局变量         key.c
          Init_Open_T0();
                         data_display();
                          clr_wtd();
  unsigned char seg_cnt=0;
void  timer0(void) interrupt  INTERRUPT_TIMER0
          static unsigned char lcd_buf=0;
          static unsigned char lcd_cnt=0;
          TL0 = (65536-200)%256;           //重装初始值
          TH0 = (65536-200)/256;
          if(++lcd_cnt==10)
                    lcd_cnt=0;
                  switch(seg_cnt)
                          case 0:          P1DIR=0xfe;
                                          P1=0x00;
                                          lcd_buf=0;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[0]]&0x03)<<0;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[1]]&0x03)<<2;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[2]]&0x03)<<4;
                                          if(model_flag==1)
                                                  lcd_buf|=(lcd_seg[lcd_segbuf[3]]&0x03)<<6;
                                                  lcd_buf|=(lcd_seg[lcd_segbuf[3]]&0x02)<<6;
                                          P0=lcd_buf;
                                          break;
                        case 1:          P1DIR=0xfe;
                                          P1=0x01;
                                          lcd_buf=0;
                                          if(model_flag==1)
                                          P0=lcd_buf^0xff;
                                          break;
                        case 2:          P1DIR=0xfd;
                                          P1=0x00;
                                          lcd_buf=0;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[0]]&0x0c)>>2;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[1]]&0x0c)<<0;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[2]]&0x0c)<<2;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[3]]&0x0c)<<4;
                                          P0=lcd_buf;
                                          break;
                        case 3:          P1DIR=0xfd;
                                          P1=0x02;
                                          lcd_buf=0;
                                          P0=lcd_buf^0xff;
                                          break;
                case 4:          P1DIR=0xfb;
                                          P1=0x00;
                                          lcd_buf=0;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[0]]&0x30)>>4;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[1]]&0x30)>>2;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[2]]&0x30)<<0;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[3]]&0x30)<<2;
                                          P0=lcd_buf;
                                          break;
                        case 5:          P1DIR=0xfb;
                                          P1=0x04;
                                          lcd_buf=0;
                                          P0=lcd_buf^0xff;
                                          break;
                        case 6:          P1DIR=0xf7;
                                          P1=0x00;
                                          lcd_buf=0;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[0]]&0xc0)>>6;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[1]]&0xc0)>>4;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[2]]&0xc0)>>2;
                                          lcd_buf|=(lcd_seg[lcd_segbuf[3]]&0xc0)<<0;
                                          P0=lcd_buf;
                                          break;
                        case 7:          P1DIR=0xf7;
                                          P1=0x08;
                                          lcd_buf=0;
                                          P0=lcd_buf^0xff;
                                          break;
                        default: break;
                  seg_cnt++;
                  if(seg_cnt>7)
                  seg_cnt=0;
