查看: 6212|回复: 2
74HC595驱动8位led数码管的51单片机程序及电路图
ID:90014 发表于 2015-9-15 23:40 | 显示全部楼层 |阅读模式
电路图如下:
程序如下:
#include <AT89X51.H>
unsigned char code fseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
unsigned char  disbuf[8]={0,0,0,0,0,0,0,0};
// 函数原形定义
void main (void);                                        // 主函数
void LED4_Display (void);                        // LED显示
void LED_OUT(uchar X);                                // LED单字节串行移位函数
unsigned char code LED_0F[];                // LED字模表
sbit DIO = P1^0;                                //串行数据输入
sbit RCLK  = P1^1;                                //时钟脉冲信号——上升沿有效
sbit SCLK = P1^2;                                //打入信号————上升沿有效
// 全局变量
uchar LED[8];        //用于LED的8位显示缓存
// 主程序
void main (void)
        LED[0]=1;
        LED[1]=2;
        LED[2]=3;
        LED[3]=4;
        LED[4]=5;
        LED[5]=6;
        LED[6]=7;
        LED[7]=8;
                LED4_Display ();
        unsigned char code *led_table;          // 查表指针
        uchar i;
        //显示第1位
        led_table = LED_0F + LED[0];
        i = *led_table;
        LED_OUT(i);
        LED_OUT(0x01);
        RCLK = 0;
        RCLK = 1;
        //显示第2位
        led_table = LED_0F + LED[1];
        i = *led_table;
        LED_OUT(i);
        LED_OUT(0x02);
        RCLK = 0;
        RCLK = 1;
        //显示第3位
        led_table = LED_0F + LED[2];
        i = *led_table;
        LED_OUT(i);
        LED_OUT(0x04);
        RCLK = 0;
        RCLK = 1;
        //显示第4位
        led_table = LED_0F + LED[3];
        i = *led_table;
        LED_OUT(i);
        LED_OUT(0x08);
        RCLK = 0;
        RCLK = 1;
        //显示第5位
        led_table = LED_0F + LED[4];
        i = *led_table;
        LED_OUT(i);
        LED_OUT(0x10);
        RCLK = 0;
        RCLK = 1;
        //显示第6位
        led_table = LED_0F + LED[5];
        i = *led_table;
        LED_OUT(i);
        LED_OUT(0x20);
        RCLK = 0;
        RCLK = 1;
        //显示第7位
        led_table = LED_0F + LED[6];
        i = *led_table;
        LED_OUT(i);
        LED_OUT(0x40);
        RCLK = 0;
        RCLK = 1;
        //显示第8位
        led_table = LED_0F + LED[7];
        i = *led_table;
        LED_OUT(i);
        LED_OUT(0x80);
        RCLK = 0;
        RCLK = 1;
        uchar i;
        for(i=8;i>=1;i--)
                if (X&0x80) DIO=1; else DIO=0;
                X<<=1;
                SCLK = 0;
                SCLK = 1;
unsigned char code LED_0F[] =
{// 0         1          2           3        4         5          6           7        8         9          A           b        C    d          E    F    -
        0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x8C,0xBF,0xC6,0xA1,0x86,0xFF,0xbf
ID:1 发表于 2015-12-28 16:58 | 显示全部楼层
图中没有HO啊?
