查看: 6697|回复: 3
c#写的串口设置LoRa模组的上位机源码
ID:319065 发表于 2018-6-14 20:53 | 显示全部楼层 |阅读模式
程序的运行界面:
全部资料51hei下载地址:
5、COM_LoRa模块设置.zip (3.62 MB, 下载次数: 98)
部分源码预览:
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9. using System.IO.Ports;
  10. using System.Threading;
  11. using System.Collections;
  12. using System.IO;
  13. namespace COM_A
  14. {
  15.     public partial class Form1 : Form
  16.     {
  17.         public byte[] myBy;//传递串口接收到的数据
  18.         public int myByLenth = 0;//串口接收到的数据长度
  19.         public string myStr;//串口接收的字符串
  20.         public bool receiveDtatFlag = false;
  21.         public int send_count = 0;
  22.         public Form1()
  23.         {
  24.             InitializeComponent();
  25.             //this.ControlBox = false;//最小化最大化关闭按钮处理
  26.         }
  27.         private void Form1_Load(object sender, EventArgs e)//页面加载
  28.         {
  29.             #region 串口设置初始化加载
  30.             try
  31.             {
  32.                 foreach (string com in System.IO.Ports.SerialPort.GetPortNames())//串口检测
  33.                     comboBox1.Items.Add(com);
  34.                 //comboBox1.Text = (string)comboBox1.Items[0];//初始化选择串口
  35.                 comboBox1.Text = myConfing.ConfingGetValue("COM");//使用配置文件加载
  36.                 if (comboBox1.Text == "")
  37.                 {
  38.                     comboBox1.Text = (string)comboBox1.Items[0];//初始化选择串口
  39.                 }
  40.             }
  41.             catch (Exception er)
  42.             {
  43.                 MessageBox.Show("端口加载失败!" + er.Message, "提示");
  44.             }
  45.             //列出常用的波特率
  46.             string[] ss = new string[] { "1200", "2400", "4800", "9600", "19200", "38400", "43000", "56000", "57600", "115200" };
  47.             comboBox2.DataSource = ss;
  48.             /*for (int temp = 0; temp < 10; temp++)
  49.             {
  50.                 comboBox2.Items.Add(ss[temp]);
  51.             }*/
  52.             comboBox2.Text = myConfing.ConfingGetValue("buadRate");
  53.             if (comboBox2.Text == "")
  54.             {
  55.                 comboBox2.SelectedIndex = 3;
  56.             }
  57.             //comboBox2.SelectedIndex = 3;
  58.             //列出奇偶校验位
  59.             comboBox3.DataSource = Enum.GetNames(typeof(Parity));
  60.             //comboBox3.Items.Add("无校验");
  61.             //comboBox3.Items.Add("奇校验");
  62.             //comboBox3.Items.Add("偶校验");
  63.             //comboBox3.SelectedIndex = 0;
  64.             comboBox3.Text = myConfing.ConfingGetValue("Parity");
  65.             if (comboBox3.Text == "")
  66.             {
  67.                 comboBox3.Text = "None";
  68.             }
  69.             //列出数据位
  70.             ss = new string[] { "5", "6", "7", "8", "9", "10" };
  71.             comboBox4.DataSource = ss;
  72.             //comboBox4.Text = "8";
  73.             comboBox4.Text = myConfing.ConfingGetValue("dataBits");
  74.             if (comboBox4.Text == "")
  75.             {
  76.                 comboBox4.SelectedIndex = 3;
  77.             }
  78.             //列出停止位
  79.             comboBox5.DataSource = Enum.GetNames(typeof(StopBits));
  80.             //comboBox5.Text = Enum.Format(typeof(StopBits), StopBits.One, "G");
  81.             comboBox5.Text = myConfing.ConfingGetValue("stopBits");
  82.             if (comboBox5.Text == "")
  83.             {
  84.                 comboBox5.SelectedIndex = 1;
  85.             }
  86.             button1.Text = "打开串口";
  87.             //开始执行后台操作
  88.             //backgroundWorker1.RunWorkerAsync();
  89.             checkBox1.Checked = true;
  90.             checkBox2.Checked = true;
  91.             checkBox3.Checked = true;
  92.             checkBox4.Checked = true;
  93.             #endregion
  94.             //this.button3.Visible = false;
  95.             #region 加载开选择的模块
  96.             cmbSetParaLoRaDataRate.Items.Clear();
  97.             cmbSetParaWakeUpTime.Items.Clear();
  98.             if (cmbSelectLoRaMode.Text == "杭州塔石")//
  99.             {
  100.                 //LoRa的空中速率
  101.                 cmbSetParaLoRaDataRate.Items.Add("000_0.3K");
  102.                 cmbSetParaLoRaDataRate.Items.Add("001_0.6K");
  103.                 cmbSetParaLoRaDataRate.Items.Add("010_1.2K");
  104.                 cmbSetParaLoRaDataRate.Items.Add("011_2.5K");
  105.                 cmbSetParaLoRaDataRate.Items.Add("100_4.5K");
  106.                 cmbSetParaLoRaDataRate.Items.Add("101_9.1K");
  107.                 cmbSetParaLoRaDataRate.Items.Add("110_18.2K");
  108.                 cmbSetParaLoRaDataRate.Items.Add("111_21.8K");//(默认)
  109.                 //cmbSetParaLoRaDataRate.Text = "111_21.8K";//(默认)
  110.                 cmbSetParaLoRaDataRate.Text = cmbSetParaLoRaDataRate.Items[7].ToString();
  111.                 //唤醒时间
  112.                 cmbSetParaWakeUpTime.Items.Add("000_500");//(默认)
  113.                 cmbSetParaWakeUpTime.Items.Add("001_1000");
  114.                 cmbSetParaWakeUpTime.Items.Add("010_1500");
  115.                 cmbSetParaWakeUpTime.Items.Add("011_2000");
  116.                 cmbSetParaWakeUpTime.Items.Add("100_2500");
  117.                 cmbSetParaWakeUpTime.Items.Add("101_3000");
  118.                 cmbSetParaWakeUpTime.Items.Add("110_3500");
  119.                 cmbSetParaWakeUpTime.Items.Add("111_4000");
  120.                 //cmbSetParaWakeUpTime.Text = "000_500";//(默认)
  121.                 cmbSetParaWakeUpTime.Text = cmbSetParaWakeUpTime.Items[0].ToString();
  122.             }
  123.             else
  124.             {
  125.                 //LoRa的空中速率
  126.                 cmbSetParaLoRaDataRate.Items.Add("000_0.3K");
  127.                 cmbSetParaLoRaDataRate.Items.Add("001_0.6K");
  128.                 cmbSetParaLoRaDataRate.Items.Add("010_1.2K");
  129.                 cmbSetParaLoRaDataRate.Items.Add("011_2.4K");//(默认)
  130.                 cmbSetParaLoRaDataRate.Items.Add("100_4.8K");
  131.                 cmbSetParaLoRaDataRate.Items.Add("101_9.6K");
  132.                 cmbSetParaLoRaDataRate.Items.Add("110_19.2K");
  133.                 cmbSetParaLoRaDataRate.Items.Add("111_19.2K");
  134.                 //cmbSetParaLoRaDataRate.Text = "011_2.4K";//(默认)
  135.                 cmbSetParaLoRaDataRate.Text = cmbSetParaLoRaDataRate.Items[3].ToString();
  136.                 //唤醒时间
  137.                 cmbSetParaWakeUpTime.Items.Add("000_250");//(默认)
  138.                 cmbSetParaWakeUpTime.Items.Add("001_500");
  139.                 cmbSetParaWakeUpTime.Items.Add("010_750");
  140.                 cmbSetParaWakeUpTime.Items.Add("011_1000");
  141.                 cmbSetParaWakeUpTime.Items.Add("100_1250");
  142.                 cmbSetParaWakeUpTime.Items.Add("101_1500");
  143.                 cmbSetParaWakeUpTime.Items.Add("110_1750");
  144.                 cmbSetParaWakeUpTime.Items.Add("111_2000");
  145.                 //cmbSetParaWakeUpTime.Text = "000_250";//(默认)
  146.                 cmbSetParaWakeUpTime.Text = cmbSetParaWakeUpTime.Items[0].ToString();
  147.             }
  148.             #endregion
  149.         }
  150.         private void comboBox1_DropDown_1(object sender, EventArgs e)//串口下拉框更新COM口
  151.         {
  152.             try
  153.             {
  154.                 comboBox1.Items.Clear();
  155.                 foreach (string com in System.IO.Ports.SerialPort.GetPortNames())//串口检测
  156.                     comboBox1.Items.Add(com);
  157.             }
  158.             catch (Exception er)
  159.             {
  160.                 MessageBox.Show("端口加载失败!" + er.Message, "提示");
  161.             }
  162.         }
  163.         #region 打开串口按钮处理
  164.         public void RefrespictureBox1()//刷新打开串口按键显示以及颜色
  165.         {
  166.             if (serialPort1.IsOpen)
  167.             {
  168.                 button1.BackColor = SystemColors.GradientActiveCaption;
  169.                 button1.Text = "关闭串口";
  170.             }
  171.             else
  172.             {
  173.                 button1.BackColor = SystemColors.Control;
  174.                 button1.Text = "打开串口";
  175.             }
  176.             myConfing.SetValue("COM", comboBox1.Text);
  177.             myConfing.SetValue("buadRate", comboBox2.Text);
  178.             myConfing.SetValue("Parity", comboBox3.Text);
  179.             myConfing.SetValue("dataBits", comboBox4.Text);
  180.             myConfing.SetValue("stopBits", comboBox5.Text);
  181.         }
  182.         private void button1_Click(object sender, EventArgs e)//打开串口
  183.         {
  184.             try
  185.             {
  186.                 if (serialPort1.IsOpen)//如果串口是开的则关闭
  187.                 {
  188.                     serialPort1.Close();
  189.                     comboBox1.Enabled = true;
  190.                     comboBox2.Enabled = true;
  191.                     comboBox3.Enabled = true;
  192.                     comboBox4.Enabled = true;
  193.                     comboBox5.Enabled = true;
  194.                     #region
  195.                     //button1.Text = "打开串口";
  196.                     /*//关闭串口后,串口设置选项便可以继续使用
  197.                     comboBox1.Enabled = true;
  198.                     comboBox2.Enabled = true;
  199.                     comboBox3.Enabled = true;
  200.                     comboBox4.Enabled = true;
  201.                     comboBox5.Enabled = true;*/
  202.                     #endregion
  203.                 }
  204.                 else//否则打开串口
  205.                 {
  206.                     //button1.Text = "关闭串口";
  207.                     serialPort1.PortName = comboBox1.Text;
  208.                     serialPort1.BaudRate = Convert.ToInt32(comboBox2.Text);
  209.                     serialPort1.Parity = (Parity)Enum.Parse(typeof(Parity), comboBox3.Text);
  210.                     serialPort1.DataBits = Int32.Parse(comboBox4.Text);
  211.                     serialPort1.StopBits = (StopBits)Enum.Parse(typeof(StopBits), comboBox5.Text);
  212.                     serialPort1.Encoding = Encoding.GetEncoding("Gb2312");//返回与指定代码页名称关联的编码Gb2312
  213.                     serialPort1.Open();
  214.                     comboBox1.Enabled = false;
  215.                     comboBox2.Enabled = false;
  216.                     comboBox3.Enabled = false;
  217.                     comboBox4.Enabled = false;
  218.                     comboBox5.Enabled = false;
  219.                 }
  220.                 RefrespictureBox1();//刷新打开串口按键显示以及颜色
  221.             }
  222.             catch (Exception)
  223.             {
  224.                 //打开串口失败后,相应标志位取消
  225.                 MessageBox.Show("串口无效或已被占用!", "错误提示");
  226.             }
  227.         }
  228.         #endregion
  229.         #region 发送区形式处理、串口按键发送、定时自动发送以及其他外部调用发送相关接口
  230.         private bool CheckSendData()//检查串口发送区域
  231.         {
  232.             if (textBox2.Text.Trim() == "") return false;
  233.             return true;
  234.         }
  235.         private void checkBox4_CheckedChanged(object sender, EventArgs e)//发送区HEX处理
  236.         {
  237.             string s = "";
  238.             if (checkBox4.CheckState == CheckState.Checked)//发送HEX显示
  239.             {
  240.                 byte[] by = Encoding.GetEncoding("Gb2312").GetBytes(textBox2.Text);
  241.                 textBox2.Text = "";
  242.                 foreach (byte btmp in by)
  243.                 {
  244.                     s = "00" + string.Format("{0:X}", btmp);
  245.                     textBox2.Text += s.Substring(s.Length - 2, 2);
  246.                     textBox2.Text += " ";
  247.                 }
  248.             }
  249.             else//发送ASCII显示
  250.             {
  251.                 ArrayList al = myClass.Str16ToArrayList(textBox2.Text);
  252.                 byte[] by = new byte[al.Count];
  253.                 int i = 0;
  254.                 foreach (string stmp in al)
  255.                 {
  256.                     by[i] += Convert.ToByte(stmp, 16);
  257.                     i++;
  258.                 }
  259.                 textBox2.Text = Encoding.GetEncoding("Gb2312").GetString(by);
  260.             }
  261.         }
  262.         private void textBox2_KeyPress(object sender, KeyPressEventArgs e)//发送区有按键键入,
  263.         {
  264.             if (checkBox1.CheckState == CheckState.Checked)//HEX发送时
  265.             {
  266.                 if (!Uri.IsHexDigit(e.KeyChar) && e.KeyChar != ' ')//不符合HEX的键入清除
  267.                 {
  268.                     e.KeyChar = (char)0;
  269.                 }
  270.             }
  271.         }
  272.         private void button2_Click(object sender, EventArgs e)//按键发送
  273.         {
  274.             try
  275.             {
  276.                 if (serialPort1.IsOpen)
  277.                 {
  278.                     /*if (!CheckSendData())//检测要发送的数据
  279.                     {
  280.                         MessageBox.Show("请输入要发送的数据!", "错误提示");
  281.                         return;
  282.                     }*/
  283.                     string s = "";
  284.                     //MessageBox.Show(checkBox4.Checked.ToString());
  285.                     if (checkBox4.Checked)//十六进制发送
  286.                     {
  287.                         ArrayList al = myClass.Str16ToArrayList(textBox2.Text);
  288.                         byte[] by = new byte[al.Count];
  289.                         int i = 0;
  290.                         foreach (string stmp in al)
  291.                         {
  292.                             by[i] += Convert.ToByte(stmp, 16);//将指定基的数字的字符串表示形式转换为等效的 8 位无符号整数。
  293.                             i++;
  294.                         }
  295.                         serialPort1.Write(by, 0, i);//发送字节
  296.                         //s = Encoding.GetEncoding("Gb2312").GetString(by);//在派生类中重写时,将指定字节数组中的所有字节解码为一个字符串。。
  297.                     }
  298.                     else//ASCII发送
  299.                     {
  300.                         s = textBox2.Text;
  301.                         serialPort1.Write(s);//串口发送字符串
  302.                     }
  303.                     //MessageBox.Show(s);
  304.                 }
  305.                 else
  306.                 {
  307.                     MessageBox.Show("串口未打开!", "错误提示");
  308.                 }
  309.             }
  310.             catch (Exception)
  311.             {
  312.                 MessageBox.Show("发送数据时发生错误!", "错误提示");
  313.             }
  314.         }
  315.         public void sendData(string dataIn)//调用的发送函数
  316.         {
  317.             try
  318.             {
  319.                 if (serialPort1.IsOpen)
  320.                 {
  321.                     /*if (!CheckSendData())//检测要发送的数据
  322.                     {
  323.                         MessageBox.Show("请输入要发送的数据!", "错误提示");
  324.                         return;
  325.                     }*/
  326.                     string s = "";
  327.                     textBox2.Text = dataIn;
  328.                     //MessageBox.Show(checkBox4.Checked.ToString());
  329.                     if (checkBox4.Checked)//十六进制发送
  330.                     {
  331.                         ArrayList al = myClass.Str16ToArrayList(textBox2.Text);
  332.                         byte[] by = new byte[al.Count];
  333.                         int i = 0;
  334.                         foreach (string stmp in al)
  335.                         {
  336.                             by[i] += Convert.ToByte(stmp, 16);//将指定基的数字的字符串表示形式转换为等效的 8 位无符号整数。
  337.                             i++;
  338.                         }
  339.                         serialPort1.Write(by, 0, i);//发送字节
  340.                         //s = Encoding.GetEncoding("Gb2312").GetString(by);//在派生类中重写时,将指定字节数组中的所有字节解码为一个字符串。。
  341.                     }
  342.                     else//ASCII发送
  343.                     {
  344.                         s = textBox2.Text;
  345.                         serialPort1.Write(s);//串口发送字符串
  346.                     }
  347.                     //MessageBox.Show(s);
  348.                 }
  349.                 else
  350.                 {
  351.                     MessageBox.Show("串口未打开!", "错误提示");
  352.                 }
  353.             }
  354.             catch (Exception)
  355.             {
  356.                 MessageBox.Show("发送数据时发生错误!", "错误提示");
  357.             }
  358.         }
  359.         public void sendData_NoDispaly(string dataIn)//调用的发送函数并且不显示在发送区域
  360.         {
  361.             try
  362.             {
  363.                 if (serialPort1.IsOpen)
  364.                 {
  365.                     /*if (!CheckSendData())//检测要发送的数据
  366.                     {
  367.                         MessageBox.Show("请输入要发送的数据!", "错误提示");
  368.                         return;
  369.                     }*/
  370.                     string s = "";
  371.                     //textBox2.Text = dataIn;//不显示在发送区域
  372.                     //MessageBox.Show(checkBox4.Checked.ToString());
  373.                     if (checkBox4.Checked)//十六进制发送
  374.                     {
  375.                         ArrayList al = myClass.Str16ToArrayList(textBox2.Text);
  376.                         byte[] by = new byte[al.Count];
  377.                         int i = 0;
  378.                         foreach (string stmp in al)
  379.                         {
  380.                             by[i] += Convert.ToByte(stmp, 16);//将指定基的数字的字符串表示形式转换为等效的 8 位无符号整数。
  381.                             i++;
  382.                         }
  383.                         serialPort1.Write(by, 0, i);//发送字节
  384.                         //s = Encoding.GetEncoding("Gb2312").GetString(by);//在派生类中重写时,将指定字节数组中的所有字节解码为一个字符串。。
  385.                     }
  386.                     else//ASCII发送
  387.                     {
  388.                         s = textBox2.Text;
  389.                         serialPort1.Write(s);//串口发送字符串
  390.                     }
  391.                     //MessageBox.Show(s);
  392.                 }
  393.                 else
  394.                 {
  395.                     MessageBox.Show("串口未打开!", "错误提示");
  396.                 }
  397.             }
  398.             catch (Exception)
  399.             {
  400.                 MessageBox.Show("发送数据时发生错误!", "错误提示");
  401.             }
  402.         }
  403.         private void timer1_Tick(object sender, EventArgs e)//定时自动发送
  404.         {
  405.             timer1.Interval = Convert.ToInt32(textBox1.Text);
  406.             try
  407.             {
  408.                 if ((serialPort1.IsOpen) && (checkBox5.Checked == true))
  409.                 {
  410.                     /*if (!CheckSendData())//检测要发送的数据
  411.                     {
  412.                         MessageBox.Show("请输入要发送的数据!", "错误提示");
  413.                         return;
  414.                     }*/
  415.                     string s = "";
  416.                     //textBox2.Text = dataIn;
  417.                     //MessageBox.Show(checkBox4.Checked.ToString());
  418.                     if (checkBox4.Checked)//十六进制发送
  419.                     {
  420.                         ArrayList al = myClass.Str16ToArrayList(textBox2.Text);
  421.                         byte[] by = new byte[al.Count];
  422.                         int i = 0;
  423.                         foreach (string stmp in al)
  424.                         {
  425.                             by[i] += Convert.ToByte(stmp, 16);//将指定基的数字的字符串表示形式转换为等效的 8 位无符号整数。
  426.                             i++;
  427.                         }
  428.                         serialPort1.Write(by, 0, i);//发送字节
  429.                         //s = Encoding.GetEncoding("Gb2312").GetString(by);//在派生类中重写时,将指定字节数组中的所有字节解码为一个字符串。。
  430.                     }
  431.                     else//ASCII发送
  432.                     {
  433.                         s = textBox2.Text;
  434.                         serialPort1.Write(s);//串口发送字符串
  435.                     }
  436.                     send_count++;
  437.                     textBox5.Text = send_count.ToString();
  438.                 }
  439.                 else
  440.                 {
  441.                     //MessageBox.Show("串口未打开!", "错误提示");
  442.                 }
  443.             }
  444.             catch (Exception)
  445.             {
  446.                 //MessageBox.Show("发送数据时发生错误!", "错误提示");
  447.             }
  448.         }
  449.         #endregion
  450.         #region 接收方法一用到的线程处理,不用
  451.         delegate void SetTextCallback(string text);//委托,使用回调函数时考虑使用
  452.         private void SetText(string text)
  453.         {
  454.             try
  455.             {
  456.                 if (this.richTextBox1.InvokeRequired)//获取一个值,该值指示调用方在对控件进行方法调用时是否必须调用 Invoke 方法,因为调用方位于创建控件所在的线程以外的线程中。
  457.                 {
  458.                     SetTextCallback d = new SetTextCallback(SetText);//回调函数
  459.                     this.Invoke(d, new object[] { text });//执行delegate里的搭载函数
  460.                 }
  461.                 else
  462.                 {
  463.                     this.richTextBox1.Text += text;
  464.                 }
  465.                 //this.richTextBox2.Focus();//获取焦点
  466.                 //this.richTextBox2.Select(this.richTextBox2.TextLength, 0);//光标定位到文本最后
  467.                 /* //设定光标所在位置
  468.                  this.richTextBox1.SelectionStart = richTextBox1.TextLength;
  469.                  //滚动到当前光标处
  470.                  this.richTextBox1.ScrollToCaret();*/
  471.             }
  472.             catch (Exception)
  473.             {
  474.             }
  475.         }
  476.         #endregion
  477.         #region 串口接收处理
  478.         //int receive_count_test = 0;
  479.         private void linkLabel1_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)//清除接收
  480.         {
  481.             richTextBox1.Text = "";
  482.             send_count = 0;
  483.             //receive_count_test = 0;
  484.             textBox5.Text = "";
  485.             //textBox5.Text = "";
  486.         }
  487.         private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)//接收事件触发
  488.         {
  489.             #region
  490.             /* char[] c;
  491.             //StringBuilder builder = new StringBuilder();//避免在事件处理方法中反复的创建,定义到外面。
  492.             try
  493.             {
  494.                 if (serialPort1.IsOpen)
  495.                 {
  496.                     c = new char[serialPort1.BytesToRead];
  497.                     serialPort1.Read(c, 0, c.Length);//串口读取
  498.                     if (c.Length > 0)
  499.                     {
  500.                         if (checkBox1.Checked)//接收HEX显示
  501.                         {
  502.                             if (checkBox3.Checked)//接收时间显示
  503.                             {
  504.                                 SetText(DateTime.Now.ToString());
  505.                                 SetText(" ");
  506.                             }
  507.                             byte[] by = Encoding.GetEncoding("Gb2312").GetBytes(c);
  508.                             myBy = by;
  509.                             myByLenth = by.Length;
  510.                             /*if (by[0] == 0x7b)
  511.                             {
  512.                                 MessageBox.Show("正确");
  513.                             }
  514.                             else
  515.                             {
  516.                                 MessageBox.Show(by[0].ToString());
  517.                             }*
  518.                             foreach (byte btmp in by)
  519.                             {
  520.                                 string s = "00" + string.Format("{0:X}", btmp);//将指定字符串中的一个或多个格式项替换为指定对象的字符串表示形式
  521.                                 s = s.Substring(s.Length - 2, 2);
  522.                                 SetText(new string(s.ToCharArray()));
  523.                                 SetText(" ");
  524.                             }
  525.                             if (checkBox2.Checked)//接收换行显示
  526.                             {
  527.                                 SetText("\n");
  528.                             }
  529.                         }
  530.                         else
  531.                         {
  532.                             if (checkBox3.Checked)//接收时间显示
  533.                             {
  534.                                 SetText(DateTime.Now.ToString());
  535.                             }
  536.                             SetText(new string(c));
  537.                             if (checkBox3.Checked)//接收换行显示
  538.                             {
  539.                                 SetText("\n");
  540.                             }
  541.                         }
  542.                         //this.richTextBox2.Text += "\n";
  543.                     }
  544.                 }
  545.             }
  546.             catch (Exception)
  547.             {
  548.             }
  549.             if (checkBox2.Checked)//接收HEX显示
  550.             {
  551.                 Thread.Sleep(500);//延时500ms 等待接收完数据
  552.             }
  553.             else
  554.             {
  555.                 Thread.Sleep(10);//延时100ms 等待接收完数据
  556.             }*/
  557.             /* //设定光标所在位置
  558.              this.richTextBox1.SelectionStart = richTextBox1.TextLength;
  559.              //滚动到当前光标处
  560.              this.richTextBox1.ScrollToCaret();*/
  561.             //追加的形式添加到文本框末端,并滚动到最后。
  562.             //this.richTextBox1.AppendText(builder.ToString());
  563.             #endregion
  564.             #region
  565.             Thread.Sleep(Convert.ToInt32(textBox5.Text.Trim()));//延时100ms 等待接收完数据
  566.             //第二种接收方式
  567.             StringBuilder builder = new StringBuilder();//避免在事件处理方法中反复的创建,定义到外面。
  568.             long received_count = 0;//接收计数
  569.             int n = serialPort1.BytesToRead;//先记录下来,避免某种原因,人为的原因,操作几次之间时间长,缓存不一致
  570.             byte[] buf = new byte[n];//声明一个临时数组存储当前来的串口数据
  571.             received_count += n;//增加接收计数
  572.             serialPort1.Read(buf, 0, n);//读取缓冲数据
  573.             builder.Clear();//清除字符串构造器的内容
  574.             myBy = buf;
  575.             myByLenth = buf.Length;
  576.             //因为要访问ui资源,所以需要使用invoke方式同步ui。
  577.             this.Invoke((EventHandler)(delegate
  578.             {
  579.                 if (checkBox3.Checked)//接收时间显示
  580.                 {
  581.                     this.richTextBox1.AppendText(DateTime.Now.ToString(@"yyyy\:MM\:dd") + " ");
  582.                     this.richTextBox1.AppendText(DateTime.Now.ToString(@"HH\:mm\:ss\:fff") + "  ");
  583.                 }
  584.                 //判断是否是显示为16禁止
  585.                 if (checkBox1.Checked)
  586.                 {
  587.                     //依次的拼接出16进制字符串
  588.                     foreach (byte b in buf)
  589.                     {
  590.                         builder.Append(b.ToString("X2") + " ");//在此实例的结尾追加指定字符串的副本
  591.                     }
  592.                 }
  593.                 else
  594.                 {
  595.                     //直接按ASCII规则转换成字符串
  596.                     builder.Append(Encoding.ASCII.GetString(buf));
  597.                 }
  598.                 //追加的形式添加到文本框末端,并滚动到最后。
  599.                 this.richTextBox1.AppendText(builder.ToString());
  600.                 myStr = builder.ToString();//字符串输出
  601.                 if (checkBox2.Checked)//接收换行显示
  602.                 {
  603.                     this.richTextBox1.AppendText("\n");
  604.                 }
  605.                 //修改接收计数
  606.                 //labelGetCount.Text = "Get:" + received_count.ToString();
  607.                 try
  608.                 {
  609.                     if (receiveDtatFlag == true)//保存数据
  610.                     {
  611.                         string fName = saveFileDialog1.FileName;
  612.                         FileStream fs = File.Open(fName, FileMode.Append);
  613.                         StreamWriter sw = new StreamWriter(fs);
  614.                         if (checkBox3.Checked)//接收时间显示
  615.                         {
  616.                             //this.richTextBox1.AppendText(DateTime.Now.ToString() + " ");
  617.                             sw.Write(DateTime.Now.ToString(@"hh\:mm\:ss\:fff") + " ");
  618.                         }
  619.                         sw.Write(builder.ToString());
  620.                         if (checkBox2.Checked)//接收换行显示
  621.                         {
  622.                             sw.WriteLine("\n");
  623.                         }
  624.                         //sw.WriteLine(richTextBox1.Text);
  625.                         //textBox3.Text = fName;
  626.                         sw.Close();
  627.                         fs.Close();
  628.                     }
  629.                 }
  630.                 catch
  631.                 {
  632.                 }
  633.                 myReceDataAnalysis(myStr);//数据解析处理
  634.                 //analysis myans = new analysis();
  635.                 //myans.analysisData(myStr);
  636.             }));//*/
  637.             #endregion
  638.         }
  639.         private void richTextBox1_TextChanged(object sender, EventArgs e)//接收窗处理
  640.         {
  641.             if (richTextBox1.Lines.Length > 8000)//大于8000行时清楚前面的
  642.             {
  643.                 int n = 500;
  644.                 int start = richTextBox1.GetFirstCharIndexFromLine(0);//第一行第一个字符索引
  645.                 int end = richTextBox1.GetFirstCharIndexFromLine(n);//第n行第一个字符索引
  646.                 richTextBox1.Select(start, end);//选中n行
  647.                 richTextBox1.SelectedText = "";//设置前n行为空
  648.             }
  649.             richTextBox1.Focus();
  650.             richTextBox1.Select(richTextBox1.TextLength, 0);
  651.         }
  652.         #endregion
  653.         #region 窗体处理
  654.         private void Form1_FormClosing(object sender, FormClosingEventArgs e)//关闭提醒
  655.         {
  656.             Properties.Settings.Default.Save();
  657.             myConfing.SetValue("COM", comboBox1.Text);
  658.             myConfing.SetValue("buadRate", comboBox2.Text);
  659.             myConfing.SetValue("Parity", comboBox3.Text);
  660.             myConfing.SetValue("dataBits", comboBox4.Text);
  661.             myConfing.SetValue("stopBits", comboBox5.Text);
  662.             if (DialogResult.Yes == MessageBox.Show("程序正在使用中,确认退出?", "确认退出", MessageBoxButtons.YesNo))
  663.             {
  664.                 //MessageBox.Show("立即退出!");
  665.                 serialPort1.Close();
  666.                 this.Dispose();
  667.                 e.Cancel = false;
  668.             }
  669.             else
  670.             {
  671.                 e.Cancel = true;
  672.             }
  673.         }
  674.        /*private void Form1_FormClosed(object sender, FormClosedEventArgs e)//关闭整个窗口
  675.         {
  676.             Properties.Settings.Default.Save();
  677.             myConfing.SetValue("COM", comboBox1.Text);
  678.             myConfing.SetValue("buadRate", comboBox2.Text);
  679.             myConfing.SetValue("Parity", comboBox3.Text);
  680.             myConfing.SetValue("dataBits", comboBox4.Text);
  681.             myConfing.SetValue("stopBits", comboBox5.Text);
  682.         }*/
  683.         /*private void button3_Click(object sender, EventArgs e)//窗口隐藏
  684.         {
  685.             //this.Hide();//隐藏窗体
  686.         }*/
  687.         #endregion
  688.         #region  数据文件保存处理
  689.         private void button4_Click(object sender, EventArgs e)//保存路径选择
  690.         {
  691.             //saveFileDialog1.InitialDirectory = @"G:\自制软件\C#练习\20.19 文件保存SaveFileDialog控件\51zxw";
  692.             saveFileDialog1.Filter = "文本文件(*.txt)|*.txt";
  693.             saveFileDialog1.FilterIndex = 1;
  694.             saveFileDialog1.FileName = "ReceiveData";
  695.             if (saveFileDialog1.ShowDialog() == DialogResult.OK)
  696.             {
  697.                 string fName = saveFileDialog1.FileName;
  698.                 FileStream fs = File.Open(fName, FileMode.Append);
  699.                 StreamWriter sw = new StreamWriter(fs);
  700.                 //sw.WriteLine(richTextBox1.Text);
  701.                 textBox3.Text = fName;
  702.                 sw.Close();
  703.                 fs.Close();
  704.             }
  705.         }
  706.         private void checkBox6_CheckedChanged(object sender, EventArgs e)//保存数据勾选处理
  707.         {
  708.             if (checkBox6.CheckState == CheckState.Checked)//选中
  709.             {
  710.                 receiveDtatFlag = true;
  711.             }
  712.             else
  713.             {
  714.                 receiveDtatFlag = false;
  715.             }
  716.         }
  717.         #endregion
  718.         #region 数据处理过程
  719.         private void btnSetPara_Click(object sender, EventArgs e)//设置参数
  720.         {
  721.             string mySendDataTemp = "";
  722.             //帧头
  723.             string mySendHead_0 = "";
  724.             if (chbSetParaSave.Checked == true)//掉电保存
  725.             {
  726.                 mySendHead_0 = "C0" + " ";
  727.             }
  728.             else
  729.             {
  730.                 mySendHead_0 = "C2" + " ";
  731.             }
  732.             //地址
  733.             if (txbSetParaAddr.Text.Trim().Length != 4)
  734.             {
  735.                 MessageBox.Show("地址长度不为4!", "错误提示");
  736.                 return;
  737.             }
  738.             string mySendAddr_1_2 = txbSetParaAddr.Text.Trim() + " ";
  739.             //字节3
  740.             string mySendChar_3 = "";
  741.             byte mySendByte_3 = 0;
  742.             //串口校验位,mySendByte_3的7、6位
  743.             switch (cmbSetParaDataBit.Text.Trim().Substring(0, 2))
  744.             {
  745.                 case "00"://8N1(默认)
  746.                     mySendByte_3 &= 0x3F;
  747.                     break;
  748.                 case "01"://8O1
  749.                     mySendByte_3 |= (1<<6);
  750.                     break;
  751.                 case "10"://8E1
  752.                     mySendByte_3 |= (2 << 6);
  753.                     break;
  754.                 case "11"://8N1(默认)
  755.                     mySendByte_3 &= 0x3F;
  756.                     break;
  757.                 default:
  758.                     mySendByte_3 &= 0x3F;//8N1(默认)
  759.                     break;
  760.             }
  761.             //TTL 串口速率(bps),mySendByte_3的5、4、3位
  762.             switch (cmbSetParaBuadRate.Text.Trim().Substring(0, 3))
  763.             {
  764.                 case "000"://1200
  765.                     mySendByte_3 &= 0xC7;
  766.                     break;
  767.                 case "001"://2400
  768.                     mySendByte_3 |= (1 << 3);
  769.                     break;
  770.                 case "010"://4800
  771.                     mySendByte_3 |= (2 << 3);
  772.                     break;
  773.                 case "011"://9600(默认)
  774.                     mySendByte_3 |= (3 << 3);
  775.                     break;
  776.                 case "100"://19200
  777.                     mySendByte_3 |= (4 << 3);
  778.                     break;
  779.                 case "101"://38400
  780.                     mySendByte_3 |= (5 << 3);
  781.                     break;
  782.                 case "110"://57600
  783.                     mySendByte_3 |= (6 << 3);
  784.                     break;
  785.                 case "111"://115200
  786.                     mySendByte_3 |= (7 << 3);
  787.                     break;
  788.                 default:
  789.                     mySendByte_3 |= (3 << 3);//9600(默认)
  790.                     break;
  791.             }
  792.             //无线空中速率(bps)
  793.             switch (cmbSetParaLoRaDataRate.Text.Trim().Substring(0, 3))
  794.             {
  795.                 case "000"://0.3K
  796.                     mySendByte_3 &= 0xF8;
  797.                     break;
  798.                 case "001"://0.6K
  799.                     mySendByte_3 |= 1 ;
  800.                     break;
  801.                 case "010"://1.2K
  802.                     mySendByte_3 |= 2 ;
  803.                     break;
  804.                 case "011"://2.5K/2.4k(默认)
  805.                     mySendByte_3 |= 3 ;
  806.                     break;
  807.                 case "100"://4.5K/4.8k
  808.                     mySendByte_3 |= 4 ;
  809.                     break;
  810.                 case "101"://9.1K/9.6k
  811.                     mySendByte_3 |= 5 ;
  812.                     break;
  813.                 case "110"://18.2K/19.2k
  814.                     mySendByte_3 |= 6 ;
  815.                     break;
  816.                 case "111"://21.8K(默认)/19.2k
  817.                     mySendByte_3 |= 7 ;
  818.                     break;
  819.                 default:
  820.                     if (cmbSelectLoRaMode.Text == "杭州塔石")
  821.                     {
  822.                         mySendByte_3 |= 7 ;//21.8K(默认)
  823.                     }
  824.                     else
  825.                     {
  826.                         mySendByte_3 |= 3;//2.4K(默认)
  827.                     }
  828.                     break;
  829.             }
  830.             mySendChar_3 = mySendByte_3.ToString("X2") + " ";
  831.             //信道
  832.             string mySendChannel_4 = "";//txbSetParaLoRaChannel.Text.Trim().Substring(0, 2) + " ";
  833.             Int16 mySendChannelTempInt = Convert.ToInt16(txbSetParaLoRaChannel.Text.Trim());
  834.             //byte mySendChannelTempByte = Convert.ToByte((mySendChannelTempInt - 398).ToString("X2"));
  835.             if (cmbSelectLoRaMode.Text == "杭州塔石")
  836.             {
  837.                 mySendChannel_4 = (mySendChannelTempInt - 398).ToString("X2");
  838.             }
  839.             else
  840.             {
  841.                 mySendChannel_4 = (mySendChannelTempInt - 410).ToString("X2");
  842.             }
  843.             //字节5
  844.             string mySendChar_5 = "";
  845.             byte mySendByte_5 = 0;
  846.             //发送模式,mySendByte_5的1位
  847.             if (cmbSetParaSendMode.Text.Trim().Substring(0, 1) == "1")
  848.             {
  849.                 mySendByte_5 |= (1 << 7);
  850.             }
  851.             else
  852.             {
  853.                 mySendByte_5 &= 0x7F;//默认
  854.             }
  855.             //IO 驱动方式(默认1),mySendByte_5的6位
  856.             if (cmbSetParaIOMode.Text.Trim().Substring(0, 1) == "1")
  857.             {
  858.                 mySendByte_5 |= (1 << 6);
  859.             }
  860.             else
  861.             {
  862.                 mySendByte_5 &= 0xBF;//默认
  863.             }
  864.             //无线唤醒时间,mySendByte_5的5、4、3位
  865.             switch (cmbSetParaWakeUpTime.Text.Trim().Substring(0, 3))
  866.             {
  867.                 case "000"://500ms(默认)/250ms(默认)
  868.                     mySendByte_5 &= 0xC7;
  869.                     break;
  870.                 case "001"://1000ms/500ms
  871.                     mySendByte_5 |= (1 << 3);
  872.                     break;
  873.                 case "010"://1500ms/750ms
  874.                     mySendByte_5 |= (2 << 3);
  875.                     break;
  876.                 case "011"://2000ms/1000ms
  877.                     mySendByte_5 |= (3 << 3);
  878.                     break;
  879.                 case "100"://2500ms/1250ms
  880.                     mySendByte_5 |= (4 << 3);
  881.                     break;
  882.                 case "101"://3000ms/1500ms
  883.                     mySendByte_5 |= (5 << 3);
  884.                     break;
  885.                 case "110"://3500ms/1750ms
  886.                     mySendByte_5 |= (6 << 3);
  887.                     break;
  888.                 case "111"://4000ms/2000ms
  889.                     mySendByte_5 |= (7 << 3);
  890.                     break;
  891.                 default:
  892.                     mySendByte_5 &= 0xC7;//500ms(默认)/250ms(默认)
  893.                     break;
  894.             }
  895.             //FEC 开关,mySendByte_5的2位
  896.             if (chbSetParaOpenFec.Checked == true)//定点传输
  897.             {
  898.                 mySendByte_5 |= (1 << 2);
  899.             }
  900.             else//透明传输
  901.             {
  902.                 mySendByte_5 &= 0xFB;
  903.             }
  904.             //发射功率,mySendByte_5的1、0位
  905.             switch (cmbSetParaLoRaDataRate.Text.Trim().Substring(0, 3))
  906.             {
  907.                 case "00":////20dBm(默认)
  908.                     mySendByte_5 &= 0xFC;
  909.                     break;
  910.                 case "01"://17dBm
  911.                     mySendByte_5 |= 1;
  912.                     break;
  913.                 case "10"://14dBm
  914.                     mySendByte_5 |= 2;
  915.                     break;
  916.                 case "11"://10dBm
  917.                     mySendByte_5 |= 3;
  918.                     break;
  919.                 default:
  920.                     mySendByte_5 &= 0xFC;//20dBm(默认)
  921.                     break;
  922.             }
  923.             mySendChar_5 = mySendByte_5.ToString("X2");
  924.             //综合
  925.             mySendDataTemp = mySendHead_0 + mySendAddr_1_2 + mySendChar_3 + mySendChannel_4 + mySendChar_5;
  926.             sendData(myClass.strAddSpace(mySendDataTemp));
  927.             this.pictureBox1.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  928.             this.pictureBox2.Image = Image.FromFile(Application.StartupPath + "\\green.png");//bin文件中
  929.             this.pictureBox3.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  930.             this.pictureBox4.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  931.         }
  932.         private void btnReadPara_Click(object sender, EventArgs e)//读取参数
  933.         {
  934.             sendData("C1 C1 C1");
  935.             this.pictureBox1.Image = Image.FromFile(Application.StartupPath + "\\green.png");//bin文件中
  936.             this.pictureBox2.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  937.             this.pictureBox3.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  938.             this.pictureBox4.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  939.         }
  940.         private void btnReadVersion_Click(object sender, EventArgs e)//读取版本号
  941.         {
  942.             sendData("C3 C3 C3");
  943.             this.pictureBox1.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  944.             this.pictureBox2.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  945.             this.pictureBox3.Image = Image.FromFile(Application.StartupPath + "\\green.png");//bin文件中
  946.             this.pictureBox4.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  947.         }
  948.         private void btnReset_Click(object sender, EventArgs e)//复位
  949.         {
  950.             sendData("C4 C4 C4");
  951.             this.pictureBox1.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  952.             this.pictureBox2.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  953.             this.pictureBox3.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
  954.             this.pictureBox4.Image = Image.FromFile(Application.StartupPath + "\\green.png");//bin文件中
  955.         }
  956.         //数据解析过程
  957.         public void myReceDataAnalysis(string str)
  958.         {
  959.             byte[] myReceByte = myClass.strAsciiToHexBy(str);
  960.             if (myReceByte.Length >= 4)
  961.             {
  962.                 try
  963.                 {
  964.                     switch (myReceByte[0])
  965.                     {
  966.                         case 0xC0:
  967.                         case 0xC2://读取工作参数
  968.                             #region //工作参数显示
  969.                             //字节0掉电是否保存
  970.                             if (myReceByte[0] == 0xC0)//要掉电保存的参数
  971.                             {
  972.                                 chbSetParaSave.Checked = true;
  973.                             }
  974.                             else
  975.                             {
  976.                                 chbSetParaSave.Checked = false;
  977.                             }
  978.                             //字节1、2 地址
  979.                             txbSetParaAddr.Text = myReceByte[1].ToString("X2") + myReceByte[2].ToString("X2");
  980.                             //字节3
  981.                             //串口校验位,字节3的7、6位
  982.                             cmbSetParaDataBit.Text = cmbSetParaDataBit.Items[(myReceByte[3] >> 6) & 0x03].ToString();
  983.                             #region
  984.                             /*switch ((myReceByte[3] >> 6) & 0x03)
  985.                             {
  986.                                 case 0://8N1(默认)
  987.                                     cmbSetParaDataBit.Text = "00_8N1";
  988.                                     break;
  989.                                 case 1://8O1
  990.                                     cmbSetParaDataBit.Text = "01_8O1";
  991.                                     break;
  992.                                 case 2://8E1
  993.                                     cmbSetParaDataBit.Text = "01_8E1";
  994.                                     break;
  995.                                 case 3://8N1(默认)
  996.                                     cmbSetParaDataBit.Text = "00_8N1";
  997.                                     break;
  998.                                 default:
  999.                                     cmbSetParaDataBit.Text = "error";
  1000.                                     break;
  1001.                             }*/
  1002.                             #endregion
  1003.                             //TTL 串口速率(bps),字节3的5、4、3位
  1004.                             cmbSetParaBuadRate.Text = cmbSetParaBuadRate.Items[(myReceByte[3] >> 3) & 0x07].ToString();
  1005.                             #region
  1006.                             /*switch ((myReceByte[3] >> 3) & 0x07)
  1007.                             {
  1008.                                 case 0://1200
  1009.                                     cmbSetParaBuadRate.Text = "000_1200";
  1010.                                     break;
  1011.                                 case 1://2400
  1012.                                     cmbSetParaBuadRate.Text = "001_2400";
  1013.                                     break;
  1014.                                 case 2://4800
  1015.                                     cmbSetParaBuadRate.Text = "010_4800";
  1016.                                     break;
  1017.                                 case 3://9600(默认)
  1018.                                     cmbSetParaBuadRate.Text = "011_9600";
  1019.                                     break;
  1020.                                 case 4://19200
  1021.                                     cmbSetParaBuadRate.Text = "100_19200";
  1022.                                     break;
  1023.                                 case 5://38400
  1024.                                     cmbSetParaBuadRate.Text = "101_38400";
  1025.                                     break;
  1026.                                 case 6://57600
  1027.                                     cmbSetParaBuadRate.Text = "110_57600";
  1028.                                     break;
  1029.                                 case 7://115200
  1030.                                     cmbSetParaBuadRate.Text = "111_115200";
  1031.                                     break;
  1032.                                 default:
  1033.                                     cmbSetParaBuadRate.Text = "error";
  1034.                                     break;
  1035.                             }*/
  1036.                             #endregion
  1037.                             //无线空中速率(bps),字节3的2、1、0位
  1038.                             cmbSetParaLoRaDataRate.Text = cmbSetParaLoRaDataRate.Items[(myReceByte[3] >> 0) & 0x07].ToString();
  1039.                             #region
  1040.                             /*switch ((myReceByte[3] >> 0) & 0x07)
  1041.                             {
  1042.                                 case 0://0.3K
  1043.                                     cmbSetParaLoRaDataRate.Text = "000_0.3K";
  1044.                                     break;
  1045.                                 case 1://0.6K
  1046.                                     cmbSetParaLoRaDataRate.Text = "001_0.6K";
  1047.                                     break;
  1048.                                 case 2://1.2K
  1049.                                     cmbSetParaLoRaDataRate.Text = "010_1.2K";
  1050.                                     break;
  1051.                                 case 3://2.5K/2.4k
  1052.                                     if (cmbSelectLoRaMode.Text == "杭州塔石")
  1053.                                     {
  1054.                                         cmbSetParaLoRaDataRate.Text = "011_2.5K";
  1055.                                     }
  1056.                                     else
  1057.                                     {
  1058.                                         cmbSetParaLoRaDataRate.Text = "011_2.4K";
  1059.                                     }
  1060.                                     break;
  1061.                                 case 4://4.5K/4.8k
  1062.                                     if (cmbSelectLoRaMode.Text == "杭州塔石")
  1063.                                     {
  1064.                                         cmbSetParaLoRaDataRate.Text = "100_4.5K";
  1065.                                     }
  1066.                                     else
  1067.                                     {
  1068.                                         cmbSetParaLoRaDataRate.Text = "100_4.8K";
  1069.                                     }
  1070.                                     break;
  1071.                                 case 5://9.1K/9.6K
  1072.                                     if (cmbSelectLoRaMode.Text == "杭州塔石")
  1073.                                     {
  1074.                                         cmbSetParaLoRaDataRate.Text = "101_9.1K";
  1075.                                     }
  1076.                                     else
  1077.                                     {
  1078.                                         cmbSetParaLoRaDataRate.Text = "101_9.6K";
  1079.                                     }
  1080.                                     break;
  1081.                                 case 6://18.2K/19.2K
  1082.                                     if (cmbSelectLoRaMode.Text == "杭州塔石")
  1083.                                     {
  1084.                                         cmbSetParaLoRaDataRate.Text = "110_18.2K";
  1085.                                     }
  1086.                                     else
  1087.                                     {
  1088.                                         cmbSetParaLoRaDataRate.Text = "110_19.2K";
  1089.                                     }
  1090.                                     break;
  1091.                                 case 7://21.8K(默认)
  1092.                                     if (cmbSelectLoRaMode.Text == "杭州塔石")
  1093.                                     {
  1094.                                         cmbSetParaLoRaDataRate.Text = "111_21.8K";
  1095.                                     }
  1096.                                     else
  1097.                                     {
  1098.                                         cmbSetParaLoRaDataRate.Text = "111_19.2K";
  1099.                                     }
  1100.                                     break;
  1101.                                 default:
  1102.                                     cmbSetParaLoRaDataRate.Text = "error";
  1103.                                     break;
  1104.                             }*/
  1105.                             #endregion
  1106.                             //字节4信道号
  1107.                             txbSetParaLoRaChannel.Text = (myReceByte[4] + 398).ToString();
  1108.                             //字节5
  1109.                             //发送模式,字节5的第7位
  1110.                             cmbSetParaSendMode.Text = cmbSetParaSendMode.Items[(myReceByte[5] >> 7) & 0x01].ToString();
  1111.                             #region
  1112.                             /*if (((myReceByte[5] >> 7) & 0x01) == 1)//定点
  1113.                             {
  1114.                                 cmbSetParaSendMode.Text = "1_定点传输";
  1115.                             }
  1116.                             else//透明
  1117.                             {
  1118.                                 cmbSetParaSendMode.Text = "0_透明传输";
  1119.                             }*/
  1120.                             #endregion
  1121.                             //IO 驱动方式(默认1),字节5的第6位
  1122.                             cmbSetParaIOMode.Text = cmbSetParaIOMode.Items[(myReceByte[5] >> 6) & 0x01].ToString();
  1123.                             #region
  1124.                             /*if (((myReceByte[5] >> 6) & 0x01) == 1)//
  1125.                             {
  1126.                                 cmbSetParaIOMode.Text = "1_推挽上拉";
  1127.                             }
  1128.                             else//
  1129.                             {
  1130.                                 cmbSetParaIOMode.Text = "0_开漏浮空";
  1131.                             }*/
  1132.                             #endregion
  1133.                             //无线唤醒时间,字节5的第5、4、3位
  1134.                             cmbSetParaWakeUpTime.Text = cmbSetParaWakeUpTime.Items[(myReceByte[5] >> 3) & 0x07].ToString();
  1135.                             #region
  1136.                             /*switch ((myReceByte[5] >> 3) & 0x07)
  1137.                             {
  1138.                                 case 0://500ms(默认)
  1139.                                     cmbSetParaWakeUpTime.Text = "000_500";
  1140.                                     break;
  1141.                                 case 1://1000ms
  1142.                                     cmbSetParaWakeUpTime.Text = "001_1000";
  1143.                                     break;
  1144.                                 case 2://1500ms
  1145.                                     cmbSetParaWakeUpTime.Text = "010_1500";
  1146.                                     break;
  1147.                                 case 3://2000ms
  1148.                                     cmbSetParaWakeUpTime.Text = "011_2000";
  1149.                                     break;
  1150.                                 case 4://2500ms
  1151.                                     cmbSetParaWakeUpTime.Text = "100_2500";
  1152.                                     break;
  1153.                                 case 5://3000ms
  1154.                                     cmbSetParaWakeUpTime.Text = "101_3000";
  1155.                                     break;
  1156.                                 case 6://3500ms
  1157.                                     cmbSetParaWakeUpTime.Text = "110_3500";
  1158.                                     break;
  1159.                                 case 7://4000ms
  1160.                                     cmbSetParaWakeUpTime.Text = "111_4000";
  1161.                                     break;
  1162.                                 default:
  1163.                                     cmbSetParaWakeUpTime.Text = "error";
  1164.                                     break;
  1165.                             }*/
  1166.                             #endregion
  1167.                             //FEC 开关(默认1),字节5的第3位
  1168.                             if (((myReceByte[5] >> 2) & 0x01) == 1)//
  1169.                             {
  1170.                                 chbSetParaOpenFec.Checked = true;
  1171.                             }
  1172.                             else//
  1173.                             {
  1174.                                 chbSetParaOpenFec.Checked = false;
  1175.                             }
  1176.                             //发射功率,字节5的第1、0位
  1177.                             cmbSetParaSendPower.Text = cmbSetParaSendPower.Items[(myReceByte[5] >> 0) & 0x03].ToString();
  1178.                             #region
  1179.                             /*switch ((myReceByte[5] >> 0) & 0x03)
  1180.                             {
  1181.                                 case 0://20dBm(默认)
  1182.                                     cmbSetParaSendPower.Text = "00_20";
  1183.                                     break;
  1184.                                 case 1://17dBm
  1185.                                     cmbSetParaSendPower.Text = "01_17";
  1186.                                     break;
  1187.                                 case 2://14dBm
  1188.                                     cmbSetParaSendPower.Text = "10_14";
  1189.                                     break;
  1190.                                 case 3://10dBm
  1191.                                     cmbSetParaSendPower.Text = "11_10";
  1192.                                     break;
  1193.                                 default:
  1194.                                     cmbSetParaSendPower.Text = "error";
  1195.                                     break;
  1196.                             }*/
  1197.                             #endregion
  1198.                         #endregion
  1199.                             break;
  1200.                         case 0xC3://读取版本号
  1201.                             txbReadVersionOut.Text = str;
  1202.                             if (myReceByte[1] == 0x28)//杭州塔石
  1203.                             {
  1204.                                 cmbSelectLoRaMode.Text = cmbSelectLoRaMode.Items[0].ToString();
  1205.                             }
  1206.                             else//成都亿佰特
  1207.                             {
  1208.                                 cmbSelectLoRaMode.Text = cmbSelectLoRaMode.Items[1].ToString();
  1209.                             }
  1210.                             break;
  1211.                         default:
  1212.                             break;
  1213.                     }
  1214.                 }
  1215.                 catch (Exception)
  1216.                 {
  1217.                 }
  1218.             }
  1219.         }
  1220.         #endregion//*/
  1221.         #region 没有使用
  1222.         public void portIDGet()//串口自动获取
  1223.         {
  1224.             try
  1225.             {
  1226.                 comboBox1.Items.Clear();
  1227.                 foreach (string com in System.IO.Ports.SerialPort.GetPortNames())//串口检测
  1228.                 {
  1229.                     comboBox1.Items.Add(com);
  1230.                 }
  1231.                 //comboBox1.Text = myConfing.ConfingGetValue("COM");//使用配置文件加载
  1232.             }
  1233.             catch (Exception er)
  1234.             {
  1235.                 MessageBox.Show("端口加载失败!" + er.Message, "提示");
  1236.             }
  1237.         }
  1238.         private void comboBox1_DragDrop(object sender, DragEventArgs e)
  1239.         {
  1240.             portIDGet();
  1241.         }
  1242.         private void comboBox1_DropDown(object sender, EventArgs e)
  1243.         {
  1244.             portIDGet();
  1245.         }
  1246.         #endregion
  1247.         #region 模块选择
  1248.         private void cmbSelectLoRaMode_TextChanged(object sender, EventArgs e)//选择模块
  1249.         {
  1250.             cmbSetParaLoRaDataRate.Items.Clear();
  1251.             cmbSetParaWakeUpTime.Items.Clear();
  1252.             if (cmbSelectLoRaMode.Text == "杭州塔石")//
  1253.             {
  1254.                 //LoRa的空中速率
  1255.                 cmbSetParaLoRaDataRate.Items.Add("000_0.3K");
  1256.                 cmbSetParaLoRaDataRate.Items.Add("001_0.6K");
  1257.                 cmbSetParaLoRaDataRate.Items.Add("010_1.2K");
  1258.                 cmbSetParaLoRaDataRate.Items.Add("011_2.5K");
  1259.                 cmbSetParaLoRaDataRate.Items.Add("100_4.5K");
  1260.                 cmbSetParaLoRaDataRate.Items.Add("101_9.1K");
  1261.                 cmbSetParaLoRaDataRate.Items.Add("110_18.2K");
  1262.                 cmbSetParaLoRaDataRate.Items.Add("111_21.8K");//(默认)
  1263.                 //cmbSetParaLoRaDataRate.Text = "111_21.8K";//(默认)
  1264.                 cmbSetParaLoRaDataRate.Text = cmbSetParaLoRaDataRate.Items[7].ToString();
  1265.                 //唤醒时间
  1266.                 cmbSetParaWakeUpTime.Items.Add("000_500");//(默认)
  1267.                 cmbSetParaWakeUpTime.Items.Add("001_1000");
  1268.                 cmbSetParaWakeUpTime.Items.Add("010_1500");
  1269.                 cmbSetParaWakeUpTime.Items.Add("011_2000");
  1270.                 cmbSetParaWakeUpTime.Items.Add("100_2500");
  1271.                 cmbSetParaWakeUpTime.Items.Add("101_3000");
  1272.                 cmbSetParaWakeUpTime.Items.Add("110_3500");
  1273.                 cmbSetParaWakeUpTime.Items.Add("111_4000");
  1274.                 //cmbSetParaWakeUpTime.Text = "000_500";//(默认)
  1275.                 cmbSetParaWakeUpTime.Text = cmbSetParaWakeUpTime.Items[0].ToString();
  1276.             }
  1277.             else
  1278.             {
  1279.                 //LoRa的空中速率
  1280.                 cmbSetParaLoRaDataRate.Items.Add("000_0.3K");
  1281.                 cmbSetParaLoRaDataRate.Items.Add("001_0.6K");
  1282.                 cmbSetParaLoRaDataRate.Items.Add("010_1.2K");
  1283.                 cmbSetParaLoRaDataRate.Items.Add("011_2.4K");//(默认)
  1284.                 cmbSetParaLoRaDataRate.Items.Add("100_4.8K");
  1285.                 cmbSetParaLoRaDataRate.Items.Add("101_9.6K");
  1286.                 cmbSetParaLoRaDataRate.Items.Add("110_19.2K");
  1287.                 cmbSetParaLoRaDataRate.Items.Add("111_19.2K");
  1288.                 //cmbSetParaLoRaDataRate.Text = "011_2.4K";//(默认)
  1289.                 cmbSetParaLoRaDataRate.Text = cmbSetParaLoRaDataRate.Items[3].ToString();
  1290.                 //唤醒时间
  1291.                 cmbSetParaWakeUpTime.Items.Add("000_250");//(默认)
  1292.                 cmbSetParaWakeUpTime.Items.Add("001_500");
  1293.                 cmbSetParaWakeUpTime.Items.Add("010_750");
  1294.                 cmbSetParaWakeUpTime.Items.Add("011_1000");
  1295.                 cmbSetParaWakeUpTime.Items.Add("100_1250");
  1296.                 cmbSetParaWakeUpTime.Items.Add("101_1500");
  1297.                 cmbSetParaWakeUpTime.Items.Add("110_1750");
  1298.                 cmbSetParaWakeUpTime.Items.Add("111_2000");
  1299.                 //cmbSetParaWakeUpTime.Text = "000_250";//(默认)
  1300.                 cmbSetParaWakeUpTime.Text = cmbSetParaWakeUpTime.Items[0].ToString();
  1301.             }
  1302.         }
  1303.         #endregion
  1304.     }
  1305. }
ID:403192 发表于 2018-9-27 15:31 | 显示全部楼层
下载看看
ID:505211 发表于 2019-4-5 10:25 | 显示全部楼层
不错的学些材料,谢谢
ID:359173 发表于 2019-4-10 17:27 | 显示全部楼层
不错,学习学习,点赞啊
