查看: 3842|回复: 0
MSP430G2553__ADC测试程序
ID:3721 发表于 2016-6-13 14:15 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include "io430.h"
long temp;
long IntDegF;
long IntDegC;
void delay(unsigned int ms)
  while(ms--);
void ADC10init()
  ADC10CTL0 &=~ENC;  //disable ADC10
  ADC10CTL0=ADC10IE + ADC10ON + REFON + ADC10SHT_3 + SREF_1;
  //ADC10IE        ADC10 Interrupt Enalbe
  //ADC10ON        ADC10 On/Enable
  //ADC10SHT_3     64 x ADC10CLKs
  //SREF_1         VR+ = VREF+ and VR- = AVSS
  ADC10CTL1=CONSEQ_0 + ADC10SSEL_0 + ADC10DIV_3 + SHS_0 + INCH_0;
  //CONSEQ_0       Single channel single conversion
  //ADC10SSEL_0    ADC10OSC  ADC_clock choice
  //ADC10DIV_3     ADC10 Clock Divider Select 3
  // SHS_0                   ADC10SC
  // INCH_0        Selects Channel 0
  delay(30000);
  ADC10CTL0 |=ENC;  //enable ADC10
int main( void )
  // Stop watchdog timer to prevent time out reset
  //WDTCTL = WDTPW + WDTHOLD;
  ADC10init();
    ADC10CTL0 |=ENC + ADC10SC;
    __bis_SR_register(CPUOFF + GIE);
    temp=ADC10MEM;
    __no_operation();
#pragma vector=ADC10_VECTOR
   __interrupt void ADC10_ISR_HOOK(void)
    __bis_SR_register_on_exit(LPM4_bits);
