查看: 1631|回复: 0
基于At89c52 的lcd显示(菜鸟)作验证
ID:315810 发表于 2018-4-27 17:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include<intrins.h>
sbit RS = P3 ^ 0;//?? H ?? L
sbit RW = P3 ^ 1;//? H ? L
sbit E  = P3 ^ 2;//??? H ??
#define DATA P2
void delayms(char ms);
char is_busy();
void write_cmd(unsigned char cmd);
void write_data(unsigned char dat);
void pos (unsigned char pos);
    write_cmd(0x38);/
    delayms(1);
    write_cmd(0x0c)
    delayms(1);
    write_cmd(0x06)
    delayms(1);
    write_cmd(0x01)
    delayms(1);
    pos (0);
    write_data('1');
    write_data('2');
    write_data('3');
    write_data('4');
    write_data('5');
    write_data('6');
    write_data('7');
    write_data('8');
    write_data('9');
    write_data('0');
    pos (0x40);
    write_data('1');
    write_data('2');
    write_data('3');
    write_data('4');
    write_data('5');
    while(1);
    write_cmd(pos|0x80);
    while(is_busy());
    RS = 1;
    RW = 0;
    E  = 0;
    //_nop_();
    DATA = dat;
    _nop_();
    E = 1
    E = 0;
    while(is_busy());
    RS = 0;
    RW = 0;
    E  = 0;
    //_nop_();
    DATA = cmd;
    _nop_();
    E = 1
    E = 0;
char is_busy()
    int a=0;
    char result;
    RS = 0
    RW = 1;//?
    //_nop_();
    E  = 1;//??
    _nop_();
    result = (1<<7 & DATA)
    E = 0;//????
    return result;
void delayms(char ms)        //@12.000MHz
    while(ms--)
        unsigned char i, j;
        i = 2;
        j = 239;
        do
            while (--j);
        } while (--i);
