查看: 8529|回复: 1
零知开源分享-使用SGP30模块进行空气质量监测
本篇文章中将使用SGP30模块对空气中的VOC和CO2进行监测,获取空气质量状况。
1、说明
MCU:零知-标准板
模块:SGP30多像素气体传感器模块(盛思锐)
注意:模块的供电标准为1.8V,所以使用时需要接电平转换才可以接到开发板中。
2、测试demo
  1.   #include "Adafruit_SGP30.h"
  2.
  3. Adafruit_SGP30 sgp;
  4.
  5. /* return absolute humidity [mg/m^3] with approximation formula
  6. * @param temperature [°C]
  7. * @param humidity [%RH]
  8. */
  9. uint32_t getAbsoluteHumidity(float temperature, float humidity) {
  10.     // approximation formula from Sensirion SGP30 Driver Integration chapter 3.15
  11.     const float absoluteHumidity = 216.7f * ((humidity / 100.0f) * 6.112f * exp((17.62f * temperature) / (243.12f + temperature)) / (273.15f + temperature)); // [g/m^3]
  12.     const uint32_t absoluteHumidityScaled = static_cast<uint32_t>(1000.0f * absoluteHumidity); // [mg/m^3]
  13.     return absoluteHumidityScaled;
  14. }
  15.
  16. void setup() {
  17.   Serial.begin(9600);
  18.   Serial.println("SGP30 test");
  19.
  20.   if (! sgp.begin()){
  21.     Serial.println("Sensor not found :(");
  22.     while (1);
  23.   }
  24.   Serial.print("Found SGP30 serial #");
  25.   Serial.print(sgp.serialnumber[0], HEX);
  26.   Serial.print(sgp.serialnumber[1], HEX);
  27.   Serial.println(sgp.serialnumber[2], HEX);
  28.
  29.   // If you have a baseline measurement from before you can assign it to start, to 'self-calibrate'
  30.   //sgp.setIAQBaseline(0x8E68, 0x8F41);  // Will vary for each sensor!
  31. }
  32.
  33. int counter = 0;
  34. void loop() {
  35.   // If you have a temperature / humidity sensor, you can set the absolute humidity to enable the humditiy compensation for the air quality signals
  36.   //float temperature = 22.1; // [°C]
  37.   //float humidity = 45.2; // [%RH]
  38.   //sgp.setHumidity(getAbsoluteHumidity(temperature, humidity));
  39.
  40.   if (! sgp.IAQmeasure()) {
  41.     Serial.println("Measurement failed");
  42.     return;
  43.   }
  44.   Serial.print("TVOC "); Serial.print(sgp.TVOC); Serial.print(" ppb\t");
  45.   Serial.print("eCO2 "); Serial.print(sgp.eCO2); Serial.println(" ppm");
  46.   delay(1000);
  47.
  48.   counter++;
  49.   if (counter == 30) {
  50.     counter = 0;
  51.
  52.     uint16_t TVOC_base, eCO2_base;
  53.     if (! sgp.getIAQBaseline(&eCO2_base, &TVOC_base)) {
  54.       Serial.println("Failed to get baseline readings");
  55.       return;
  56.     }
  57.     Serial.print("****Baseline values: eCO2: 0x"); Serial.print(eCO2_base, HEX);
  58.     Serial.print(" & TVOC: 0x"); Serial.println(TVOC_base, HEX);
  59.   }
  60. }
把上述完整工程放进零知开源开发工具的库里即可使用,完整工程可到零知实验室官网免费获取。
工程界面如下:
3、测试结果
如果要使SGP30模块获取更精准的数据,可以加入温湿度传感器进行湿度补偿,然后再进行相关数据的采集。详情可到零知实验室官网免费查询。
ID:268888 发表于 2019-11-5 15:20 | 只看该作者
为什么CO2和甲醛互干扰那么大,吹气的时候,甲醛传感器数值也会增加,甲醛有的时候,CO2也会增加;
