查看: 3433|回复: 0
简易频率计设计
ID:211406 发表于 2017-6-15 10:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
bit int_flag;
unsigned char volatile T0Count;
unsigned char volatile T1Count;
unsigned char code table[] ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char code temp[] = {0xfe,0xfd,0xfb,0xf7};
unsigned long sum;
unsigned char Led[4];
void delay(unsigned int num )
        while(--num);
void init(void)
   TMOD=0x15;//TMOD=0x51; //T1定时,T0计数
   TH1=(65536-50000)/256;//TH0=(65536-50000)/256; //定时50ms
   TL1=(65536-50000)%256;// TL0=(65536-50000)%256;
        TH0=0x00;        //TH1=0x00;
        TL0=0x00;//TL1=0x00;
void disp(void)
        unsigned char i;
        for(i=0;i<4;i++)
                P2=temp[i];//片选
                P0=table[Led[i]];        //取数据显示
                delay(100);        //延时1毫秒
void main(void)
        EA=1;
        init();
        TR0=1;
        TR1=1;
        ET1=1;
        ET0=1;
                  if(int_flag==1)
                          int_flag=0;
                        sum=TL0+TH0*256+T0Count*65536;         //计算脉冲个数
                        Led[3]=sum%10000/1000;//显示千位
                        Led[2]=sum%1000/100;//显示百位
                        Led[1]=sum%100/10;//显示十位
                        Led[0]=sum%10;//显示个位
                        T1Count=0x00;
                        T0Count=0;
                        TH0=0x00;
                        TL0=0x00;
                        TR0=1;
                  disp();
void int_t1(void) interrupt 3
        TH1=(65535-50000)/256;
        T1Count++;
        if(T1Count==20)
                TR0=0;
                int_flag=1;
                T1Count=0x00;
void int_T0(void) interrupt 1
         T0Count++;
2012单片机实验指导书.pdf
1.66 MB, 下载次数: 7, 下载积分: 黑币 -5
