查看: 1450|回复: 0
电子眼
ID:233128 发表于 2017-9-14 15:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#define _US 0x5553
#define _DS 0x4453
#define _LS 0x4C53
#define _RS 0x5253
#define _UL 0x554C
#define _DL 0x444C
#define _UR 0x5552
#define _DR 0x4452
#define _SS 0x5353
#define ENA 10
#define ENB 11
#define IN1 7
#define IN2 8
#define IN3 12
#define IN4 13
#define LOWSPEED 100
#define HIGHSPEED 255
uint16_t value;
uint8_t r_buffer[4];
uint8_t number;
uint8_t command;
void setup(){
        pinMode(ENA,OUTPUT);
        pinMode(ENB,OUTPUT);
        pinMode(IN1,OUTPUT);
        pinMode(IN2,OUTPUT);
        pinMode(IN3,OUTPUT);
        pinMode(IN4,OUTPUT);
        //digitalWrite(ENA, HIGH);
        //digitalWrite(ENB, HIGH);
       run(0);
Serial1.begin(9600);
void loop(){
        if(Serial1.available())
                uint8_t readbuf = Serial1.read();
                r_buffer[number]=readbuf;
                number++;
                if(readbuf==0x3B)
                        if(number==3)
                                value = (r_buffer[0]<<8) | (r_buffer[1]);
                        number=0;
                        command=1;
        if(command)
                command=0;
                switch(value)
                        case _SS:     run(0);break;
                        case _US:     run(1);break;
                        case _DS:     run(2);break;
                        case _LS:     run(3);break;
                        case _RS:     run(4);break;
                        case _UL:     run(5);break;
                        case _UR:     run(6);break;
                        case _DL:     run(7);break;
                        case _DR:     run(8);break;
void forward()
        digitalWrite(IN1, HIGH);
        digitalWrite(IN2, LOW);
        digitalWrite(IN3, HIGH);
        digitalWrite(IN4, LOW);
void backward()
        digitalWrite(IN1, LOW);
        digitalWrite(IN2, HIGH);
        digitalWrite(IN3, LOW);
        digitalWrite(IN4, HIGH);
void turnleft()
void turnright()
void stopcar()
        digitalWrite(ENA, LOW);
        digitalWrite(ENB, LOW);
void run(int direct)
        switch(direct)
                case 0:
                                analogWrite(ENA,0);
                                analogWrite(ENB,0);
                                break;
                case 1:
                                analogWrite(ENA,LOWSPEED);
                                analogWrite(ENB,LOWSPEED);
                                break;
                case 2:
                                break;
                case 3:
                                break;
                case 4:
                                break;
                case 5:
                                analogWrite(ENB,HIGHSPEED);
                                break;
                case 6:
                                analogWrite(ENA,HIGHSPEED);
                                break;
                case 7:
                                break;
                case 8:
                                break;
