查看: 4411|回复: 1
利用键盘和数码管实现的简易计算器(郭天祥51单片机GTX TX-1C开发板
ID:411975 发表于 2019-6-15 22:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
sbit beep=P2^3;
sbit dula=P2^6;
sbit wela=P2^7;
unsigned char i=100;
unsigned char j,k,temp;
int key;
int num1[6],num2[6],result[6],p,plus1,plus2,flat,out;
void delay(unsigned char i)
  for(j=i;j>0;j--)
  for(k=125;k>0;k--);
unsigned char code table[]=
  0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71
display(unsigned char num)
  P0=table[num];
  dula=1;
  dula=0;
  P0=0xc0;
  wela=1;
  wela=0;
void display1(unsigned char a1,unsigned char a2,unsigned char a3,unsigned char a4,unsigned char a5,unsigned char a6)   //????
  static int num_count=0;
//a6++;///////////////
  if(num_count==0)
   dula=0;
   P0=table[a1];  //????
   dula=1;
   dula=0;
   wela=0;
   P0=0x7e;
   wela=1;
   wela=0;
  // delay(1);
  //num_count++;
   if(num_count==1)
   dula=0;
   P0=table[a2];  //????
   dula=1;
   dula=0;
   wela=0;
   P0=0x7d;
   wela=1;
   wela=0;
//   delay(1);
//num_count++;
  if(num_count==2)
   P0=table[a3];  //????
   dula=1;
   dula=0;
   P0=0x7b;
   wela=1;
   wela=0;
   //delay(1);
// num_count++;
  if(num_count==3)
   P0=table[a4];  //????
   dula=1;
   dula=0;
   P0=0x77;
   wela=1;
   wela=0;
   //delay(1);
  // num_count++;
   if(num_count==4)
   P0=table[a5];  //????
   dula=1;
   dula=0;
   P0=0xef;
   wela=1;
   wela=0;
   //delay(1);
  if(num_count==5)
   P0=table[a6];  //????
   dula=1;
   dula=0;
   P0=0xdf;
   wela=1;
   wela=0;
   //delay(1);
   num_count=-1;
  num_count++;
void intit(void)
TMOD=0x21;
//P0 = 0xff;
//P2 = 0xff;
TMOD = 0x21;
TH0 = 0xfc;
TL0 = 0;
TCON = 0x01;
IE = 0x82;
TR0 = 1;
key=-1;
void timer0() interrupt 1
TH0 = 0xfc;
if(flat==0)
display1(num1[0],num1[1],num1[2],num1[3],num1[4],num1[5]);
if(flat==1)
display1(p,p,p,p,p,p);
if(flat==2)
display1(num2[0],num2[1],num2[2],num2[3],num2[4],num2[5]);
if(flat==3)
display1(result[0],result[1],result[2],result[3],result[4],result[5]);
void refresh(int *t)
int i;
for(i=0;i<6;i++)
  t[i]=0;
void run(int *t)
int i,j;
for(i=0;i<5;i++)
  j=t[i+1];
  t[i]=t[i+1];
int plus(int *t)
int i,o=0;
for(i=0;i<6;i++)
  o=o*10;
    o=o+t[i];
  return o;
int i,j;
first:
intit();
  dula=0;
  wela=0;
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
        case 0xee:
        key=0;
        break;
     key=0;
        case 0xde:
     key=1;
        break;
     case 0xbe:
     key=2;
     break;
     case 0x7e:
     key=3;
     break;
      while(temp!=0xf0) //??????????????
        temp=P3;
     temp=temp&0xf0;
        //beep=0;
      beep=1;
      //display(key);
      P1=0xfe;
    P3=0xfd;
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
      delay(10);
    if(temp!=0xf0)
        temp=P3;
     switch(temp)
        case 0xed:
    key=4;
    break;
    case 0xdd:
    key=5;
    break;
    case 0xbd:
    key=6;
    break;
    case 0x7d:
    key=7;
    break;
      while(temp!=0xf0)
        temp=P3;
    temp=temp&0xf0;
     // beep=0;
      beep=1;
   //display(key);
   P1=0xfc;
    P3=0xfb;
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
      delay(10);
   if(temp!=0xf0)
        temp=P3;
    switch(temp)
        case 0xeb:
      key=8;
    break;
    case 0xdb:
     key=9;
    break;
    case 0xbb:
     key=10;
    break;
    case 0x7b:
     key=11;
    break;
      while(temp!=0xf0)
        temp=P3;
    temp=temp&0xf0;
    //beep=0;
      beep=1;
   //display(key);
      P1=0xf8;
    P3=0xf7;
    temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
      delay(10);
   if(temp!=0xf0)
        temp=P3;
      switch(temp)
          case 0xe7:
      key=12;
     break;
     case 0xd7:
      key=13;
     break;
     case 0xb7:
            refresh(num1);
            refresh(num2);
            refresh(result);
       out=0;
       p=0;
       flat=0;
       plus1=plus2=0;
       key=-1;
       goto first;
      key=14;
     break;
     case 0x77:
      key=15;
     break;
        while(temp!=0xf0)
          temp=P3;
     temp=temp&0xf0;
    // beep=0;
        beep=1;
     //display(key);
    P1=0xf0;
  if(key>=0)
   if(flat==0&&key<=9&&key>=0)
    run(num1);
    num1[5]=key;
    key=-1;
    flat=0;
   if(flat==0&&key>=10)
    p=key-9;
    key=-1;
    flat=1;
   if(flat==3&&key>=10)
    p=key-9;
    key=-1;
    flat=1;
   if(flat>=1&&flat<=2&&key<=9&&key>=0)
    run(num2);
    num2[5]=key;
    key=-1;
    flat=2;
   if(flat==2&&key==15)
    plus1=plus(num1);
    plus2=plus(num2);
    if(p==1)
     out=plus1+plus2;
    if(p==2)
     out=plus1-plus2;
    if(p==3)
     out=plus1*plus2;
    if(p==4)
     out=(float)plus1/(float)plus2+0.5;
    j=1000000;
    for(i=0;i<6;i++)
     result[i]=(((out%j)*10)/j);
          j=j/10;
    result[0]=(out%1000000)/100000;
    result[1]=(out%100000)/10000;
    result[2]=(out%10000)/1000;
    result[3]=(out%1000)/100;
    result[4]=(out%100)/10;
    result[5]=out%10;
    num1[0]=result[0];
    num1[1]=result[1];
    num1[2]=result[2];
    num1[3]=result[3];
    num1[4]=result[4];
    num1[5]=result[5];
    refresh(num2);
    flat=3;
        key=-1;
收藏收藏3 分享淘帖 顶顶 踩踩
ID:851674 发表于 2020-12-15 14:21 | 只看该作者
电路图
