查看: 1618|回复: 0
超声波模块测距
ID:251682 发表于 2017-11-20 22:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include<intrins.h>
sbit Tr=P1^0;
sbit Ec=P1^1;
unsigned char data bit_data;
unsigned char code dis_tab[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void mDelay(unsigned int Delay)
        unsigned int i;
        for(;Delay>0;Delay--)
                for(i=0;i<5;i++);
void display(unsigned int num)
        bit_data=0xdf;
        P2=0xff;
        P0=dis_tab[num%100%10];
        P2=bit_data;
        mDelay(100);
        bit_data=_cror_( bit_data, 1 );
        P2=0xff;
        P0=dis_tab[num%100/10];
        P2=bit_data;
        mDelay(100);
        P2=0xff;
        P0=dis_tab[num/100];
        P2=bit_data;
        mDelay(100);
        unsigned int data time;
        float S;
        TMOD=0x01;
        TH0=0;
        TL0=0;
        ET0=1;
        EA=1;
        Tr=1;
                mDelay(2);
                Tr=0;
                while(Ec==0);
                TR0=1;
                while(Ec==1);
                TR0=0;
                time=TH0*256+TL0;
                TH0=0;
                TL0=0;
                S=(time*1.87)/100;
                mDelay(100);
        {        display(S);
