查看: 3333|回复: 2
STM32C8T6怎么用输出两路独立的PWM啊
ID:259424 发表于 2017-12-9 14:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用STM32C8T6怎么用输出两路独立的PWM啊,配置如下,是不是我的配置有问题啊。
void tim2_config(void)
    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
    tim2_nvic_config();
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
    TIM_DeInit(TIM2);
    TIM_TimeBaseInitStruct.TIM_Prescaler = 36-1;
    TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInitStruct.TIM_Period = 10-1;
    TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseInit(TIM2, &TIM_TimeBaseInitStruct);    //初始化TIM2配置
    TIM_ClearFlag(TIM2,TIM_FLAG_Update); //清除溢出中断标志
    TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
    TIM_Cmd(TIM2,ENABLE); //开启时钟
void tim3_config(void)
    tim3_nvic_config();
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
    TIM_DeInit(TIM3);
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseInitStruct);    //初始化TIM2配置
    TIM_ClearFlag(TIM3,TIM_FLAG_Update); //清除溢出中断标志
    TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
    TIM_Cmd(TIM3,ENABLE); //开启时钟
void tim2_nvic_config(void)
    NVIC_InitTypeDef NVIC_Init_Struct;
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    NVIC_Init_Struct.NVIC_IRQChannel = TIM2_IRQn;
    NVIC_Init_Struct.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_Init_Struct.NVIC_IRQChannelSubPriority = 0;
    NVIC_Init_Struct.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_Init_Struct);
//TIM3___PWM2设置
void tim3_nvic_config(void)
    NVIC_Init_Struct.NVIC_IRQChannel = TIM3_IRQn;
    NVIC_Init_Struct.NVIC_IRQChannelPreemptionPriority = 1;
void TIM2_IRQHandler(void)
    if(TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
        pwm1_fq ++;
        if(pwm1_fq < pwm1_high)
           GPIO_SetBits (GPIOA, GPIO_Pin_0);
        else if(pwm1_fq < 100)
            GPIO_ResetBits (GPIOA, GPIO_Pin_0);
            pwm1_fq = 0;
            //led_breath.high_breath_counter ++;
    TIM_ClearITPendingBit(TIM2,TIM_FLAG_Update);
void TIM3_IRQHandler(void)
    if(TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
        pwm2_fq ++;
        if(pwm2_fq < pwm2_high)
           GPIO_SetBits (GPIOA, GPIO_Pin_1);
        else if(pwm2_fq < 100)
            GPIO_ResetBits (GPIOA, GPIO_Pin_1);
            pwm2_fq = 0;
    TIM_ClearITPendingBit(TIM3,TIM_FLAG_Update);
void set_pwm2_high(u8 high_tm)
    pwm2_high = high_tm;
void set_pwm1_high(u8 high_tm)
    pwm1_high = high_tm;
求大神指导
ID:61002 发表于 2017-12-9 18:25 | 只看该作者
用stm32 HAL库  cubmx 图形化配置
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
