查看: 7640|回复: 4
博通B50610引脚图与pdf规格书资料下载
千兆网口芯片B50610规格书,在网上下不了的,无私奉献出来给大家
B50610引脚图:
GENERAL DESCRIPTION
The Broadcom® B50610 is a triple-speed 1000BASE-T/
100BASE-TX/10BASE-T Gigabit Ethernet (GbE)
transceiver integrated into a single monolithic CMOS chip.
The device performs all physical-layer functions for
1000BASE-T, 100BASE-TX, and 10BASE-T Ethernet on
standard category 5 UTP cable. 10BASE-T can also run
on standard category 3, 4, and 5 UTP. The B50610 is a
highly integrated solution combining digital adaptive
equalizers, ADCs, phase-locked loops, line drivers,
encoders, decoders, echo cancellers, crosstalk
cancellers, and all required support circuitry. Based on
Broadcom’s proven Digital Signal Processor technology,
the B50610 is designed to be fully compliant with RGMII,
allowing compatibility with industry-standard Ethernet
MACs and switch controllers.
Designed for reliable operation over worst-case
category 5 cable, the B50610 automatically negotiates
with its link partner to determine the highest possible
operating speed. The device detects and corrects most
common wiring problems. The B50610 features
CableChecker™ diagnostics, which detects common
cable problems including shorts, opens, and cable length.
完整的pdf格式文档51黑下载地址:
B50610-DS07-RDS.pdf (1.89 MB, 下载次数: 56)
收藏收藏3 分享淘帖 顶1 踩
ID:437947 发表于 2018-12-2 21:12 | 只看该作者
谢谢分享
ID:439893 发表于 2018-12-5 11:37 | 只看该作者
谢谢分享~~
ID:617297 发表于 2019-9-27 17:25 | 只看该作者
谢谢拉
ID:669183 发表于 2019-12-20 14:50 | 只看该作者
新到的开发板有B50610PHY芯片,搜了半天终于找到datasheet了,感谢楼主无私奉献
