查看: 5107|回复: 2
Proteus8.9 GCC编译器仿真STM32F401VE_RtThread系列a03_动态线程超声波测距
一,打开文件(可以随文下载放置在文档中打开)。(如下图1所示)
图1
二,调整原理图大小,适合可视,另存工程文件。(如下图2,3,4所示)
图2
图3
图4
三,点击Source Code标签。(如下图5所示)
图5
四,编辑main.c Proteus8.9 VSM Studio GCC编译器仿真STM32F401VE_RtThread系列a03_动态线程超声波测距 (如下图6所示)
五,Main.c 代码:
/* Main.c file generated by New Project wizard
* Author:   Ziegler Yin
* Created:   周四 一月 16 2020
* Processor: STM32F407ZGT6ZGT6
* Compiler:  GCC for ARM
#include "mfuncs.h"
#include "delay.h"
#include "usart.h"
#include "sys.h"
#include "HCSR04.h"
#include "lcd1602.h"
#include <rtthread.h>
#define LED0 PCout(0)
#define LED1 PCout(1)
#define LED2 PCout(2)
#ifndef RT_USING_HEAP
        static struct rt_thread led_thread;
        static char led_thread_stack[256];
#else
        static rt_thread_t led_thread;
#endif
char Leg[15]={"Distance: "};//存超声波数据
//////////////////////////// 获取超声波数据及转换////////////////////////
void HCSR04_data(void)
        int        a = 0;
        a = 5*HCSR04_GetLength() + 3;
    Leg[10]='0'+(a/10);
    Leg[11]='0'+(a%10);
        Leg[12]='.';
        a = a*100;
        Leg[13] = '0'+(a%100)/10;
        Leg[14] = '0';  // '0'+(a%1000) 第四位没获取到,所以只能写入0
/////////////////////////// END ///////////////////////////////////////////
static void MX_GPIO_Init(void)
          GPIO_InitTypeDef  GPIO_InitStructure;
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);//使能GPIOF时钟
          //GPIOF9,F10初始化设置
          GPIO_InitStructure.GPIO_Pin= GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2;//LED对应引脚
          GPIO_InitStructure.GPIO_Mode= GPIO_Mode_OUT;//普通输出模式
          GPIO_InitStructure.GPIO_OType= GPIO_OType_PP;//推挽输出
          GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100MHz
          GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_UP;//上拉
          GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
                LED0= 0;
                LED1= 1;
static void led_thread_entry(void * parameter) {
        while(1) {
                LED0= ~LED0;
                LED1= ~LED1;
                HCSR04_data();
                LClear();
                delay_ms(10);
                ShowStr(1, 0, "Kaillen Work", 12);
                ShowStr(1, 1, Leg, 15);
                uprint(Leg);
                uprint("\r\n控制芯片STM32F401VE_a03_动态线程超声波测距仿真开始了。\r\n");
                delay_ms(1000);
int main(void)
        delay_init(84);  //初始化延时函数
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
        uart_init(9600);//初始化串口波特率为115200
    MX_GPIO_Init();
        GPIOSt_Init();
        lcd_init();
    HCSR04_GPIO();
    HCSR04_TIM2_Config();
    TIM2_IRQHandler();
                        rt_err_t rst;
                        rst= rt_thread_init(&led_thread,
        "ledshine",
        led_thread_entry,
        RT_NULL,
        &led_thread_stack[0],
        sizeof(led_thread_stack),
        RT_THREAD_PRIORITY_MAX - 2,
        20);
                        if(rst== RT_EOK) {
                                rt_thread_startup(&led_thread);
                #else
                        led_thread= rt_thread_create("ledshine",
        led_thread_entry,
        RT_NULL,
        256,
        20);
                        if(led_thread!= RT_NULL) {
                                rt_thread_startup(led_thread);
        #endif
         while(1) {
                 rt_thread_mdelay(100);
六,点击构建工程按钮,编译工程。(如下图6所示)
图6
七,点击窗口左下方仿真按钮,可见虚拟LCD显示。 (如下图7,8,9所示)
图7
图8
图9
八,选择release,点击构建工程按钮,编译工程生成Hex文件。(如下图10所示)
图10
附件Proteus8.9 VSM Studio GCC编译器仿真STM32F401VE_RtThread系列a03_动态线程超声波测距在已安装Proteus8.9的计算机文件夹中打开即可
需要进一步了解,请加入QQ群:976235464
RtThread_GCC_F401VE_a03_动态线程_超声波测距02pt.rar
470.03 KB, 下载次数: 62, 下载积分: 黑币 -5
收藏收藏2 分享淘帖 顶 踩
ID:820019 发表于 2020-9-19 17:03 来自触屏版 | 只看该作者
请问可以做出来实物吗?有原理图和实物图吗?
ID:728202 发表于 2020-10-17 16:21 | 只看该作者
怎么仿真STM32F4?我怎么找不到F'4芯片呢
