查看: 2215|回复: 2
单片机音乐播放控制不了
大神门帮我看看这个程序,仿真时一运行音乐就开始播放了,我想通过一个按键来控制播放,可是我不管怎么加条件还是控制不了,急急急
#include "reg51.h"
unsigned char Count;
sbit _Speak =P1^0 ;
unsigned char code SONG[] ={      //祝你平安
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00};
void Time0_Init()
TMOD = 0x01;
IE   = 0x82;
TH0  = 0xD8;
TL0  = 0xEF;  //12MZ晶振,10ms
void Time0_Int() interrupt 1
TH0 = 0xD8;
TL0 = 0xEF;
Count++;   //长度加1
功能:1MS延时子程序
void Delay_xMs(unsigned int x)
    unsigned int i,j;
    for( i =0;i < x;i++ )
        for( j =0;j<3;j++ );
void Play_Song(unsigned char i)
unsigned char Temp1,Temp2;
unsigned int Addr;
Count = 0;      //中断计数器清0
Addr = i * 217;
  Temp1 = SONG[Addr++];
     if ( Temp1 == 0xFF )          //休止符
      TR0 = 0;
      Delay_xMs(100);
     else if ( Temp1 == 0x00 )   //歌曲结束符
      return;
      Temp2 = SONG[Addr++];
      TR0 = 1;
       _Speak = ~_Speak;
       Delay_xMs(Temp1);
       if ( Temp2 == Count )
        Count = 0;
        break;
功能:主程序
Time0_Init();   //定时器0中断初始化
  Play_Song(0);  //播放
新建压缩(zipped)文件夹.zip
57.61 KB, 下载次数: 4
ID:160834 发表于 2018-4-6 13:07 | 只看该作者
在你 sbit  _Speak =P1^0 ; 下面加一个按钮定义。 sbit   KEY1 =P1^1;
    if (KEY1 == 0)
     //这里可以加个延时作消抖。
      Play_Song(0);  //播放
你的程序已仿真试过。没有问题。程序加上红色部分就可以一个按钮控制播了。
ID:277480 发表于 2018-4-6 20:18 来自触屏版 | 只看该作者
好的谢谢
