查看: 9524|回复: 26
为什么keil编译的时候出现这种错误:error 202 ‘lcden’ :undefine identifier
ID:306995 发表于 2018-4-14 17:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助大神,为什么keil编译的时候出现这种错误:error 202 ‘lcden’ :undefine identifier
我改完P口之后:
下面是完整程序:我要实现的是可以负数运算的简易计算器
#include<reg51.h>
//LCD1602
sbit rs=P2^5
sbit wela=P2^6
sbit lcden=P2^7
uchar code table[]="                ";
long int data_a,data_b
long int data_c
uchar display[10];
void LCD_Delay_us(unsigned int t)
    while(t--);//t=0íË3ö
void LCD_Delay_ms(unsigned int t)
    unsigned int i,j;
        for(i=0;i<t;i++)
        for(j=0;j<113;j++);
void write_com(uchar com)
    rs=0;
        lcden=0;
        P0=com;
        LCD_Delay_ms(1);
        lcden=1;
        LCD_Delay_ms(2);
        lcden=0;
//1602D′êy¾Y
void write_date(uchar date)
    rs=1;
        lcden=0;
        P0=date;
        LCD_Delay_ms(1);
        lcden=1;
        LCD_Delay_ms(2);
        lcden=0;
void W_lcd(unsigned char x,unsigned char y,unsigned char Data)
if (y==0){write_com(0x80+x);}
else{write_com(0xc0+x);}
write_data(Data);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char*s)
while (*s)
{write_data(*s);s++;}
void init_lcd(void)
    wela=0;
        lcden=0;
        write_com(0x38);
        LCD_Delay_us(100);
        write_com(0x0c);
        write_com(0x06);
    write_com(0x01);
    write_com(0x08);
short keycheckdown()
    short temp1,temp2,temp,a=0xff;
        P1=0xf0;
        LCD_Delay_ms(20);
        temp1=P1;
        P1=0xff;
        LCD_Delay_ms(20);
        P1=0x0f;
        LCD_Delay_ms(20);
        temp2=P1;
        P1=0xff;
        temp=(temp1&0xf0)|(temp2&0x0f);
        switch(temp)
        case 0x77:a=0x0d;break;
        case 0x7b:a=0x0e;break;
        case 0x7d:a=0x00;break;
        case 0x7e:a=0x0f;break;
        case 0xb7:a=0x0c;break;//*
        case 0xbb:a=0x9;break;//9
        case 0xbd:a=0x8;break;//8
        case 0xbe:a=0x7;break;//7
        case 0xd7:a=0x0b;break;//-
        case 0xdb:a=0x06;break;//6
        case 0xdd:a=0x05;break;//5
        case 0xde:a=0x04;break;//4
        case 0xe7:a=0x0a;break;//+
        case 0xeb:a=0x03;break;//3
        case 0xed:a=0x02;break;//2
        case 0xee:a=0x01;break;//1
        default:a=0xff;
        return a;
void display_a()
    display[3]=data_a%10000/1000;
        display[2]=data_a%1000/100;
        display[1]=data_a%100/10;
        display[0]=data_a%10;
        write_com(0x80+0);
        if(data_a>999){write_data('0'+display[3]);}
        if(data_a>99){write_data('0'+display[2]);}
        if(data_a>9){write_data('0'+display[1]);}
                          write_data('0'+display[0]);
void display_b()
    write_com(0x80+7);
         display[3]=data_b%10000/1000;
        display[2]=data_b%1000/100;
        display[1]=data_b%100/10;
        display[0]=data_b%10;
    if(data_b>999){write_data('0'+display[3]);}
        if(data_b>99) {write_data('0'+display[2]);}
        if(data_b>9)   {write_data('0'+display[1]);}
void display_c(x)
    if(data_c<100000000&&data_c>-1)
        display[8]=data_c%1000000000/100000000;
        display[7]=data_c%100000000/10000000;
        display[6]=data_c%10000000/1000000;
        display[5]=data_c%1000000/100000;
        display[4]=data_c%100000/10000;
        display[3]=data_c%10000/1000;
        display[2]=data_c%1000/100;
        display[1]=data_c%100/10;
        display[0]=data_c%10;
        write_com(0x80+0x06+0x40);
        if(x==4)
        if(data_c>99999999) {write_data('0'+display[8]);}
        if(data_c>9999999)  {write_data('0'+display[7]);}
        if(data_c>999999)    {write_data('0'+display[6]);}
        if(data_c>99999)     {write_data('0'+display[5]);}
                                     write_data('0'+display[4]);
        write_data('.');
        else{
        if(data_c>99999999)  {write_date('0'+display[8]);}
        if(data_c>9999999)  {write_date('0'+display[7]);}
        if(data_c>999999)  {write_date('0'+display[6]);}
        if(data_c>99999)  {write_date('0'+display[5]);}
        if(data_c>9999)  {write_date('0'+display[4]);}
        if(data_c>999)  {write_date('0'+display[3]);}
        if(data_c>999)  {write_date('0'+display[2]);}
        if(data_c>999)  {write_date('0'+display[1]);}
        write_date('0'+display[0]);
        else {
        write_com(0x80+11+0x40);
        write_date('E');
        write_date('r');
        write_date('r');
        write_date('o');
        write_date('r');
void eql(uchar x)
  switch(x)
  case 1:data_c=data_a+data_b;break;
  case 2:if(data_a>=data_b){data_c=data_a-data_b;}
    else{data_c=data_b-data_a;W_lcd(5,1,'-');} ;
                     break;
        case 3:data_c=(data_a*data_b);break;
        case 4:if(data_b==0){LCD_Write_String(0,1,"Error!";}
    else{data_c=(data_a*10000)/data_b;};break;
  case 0:break;
    uchar key=0xff;
        uchar n=0;
        uchar m=5;
        uchar x=0;
        data_a=0;
        data_b=0;
        data_c=0;
        init_lcd();
        display_a();
key=keycheckdown();
if(0xff!=key)
if(key<10)
if(n<4){data_a=data_a*10+key;m=5;display_a();}n++;
if(m<4){data_b=data_b*10+key;n=5;display_b();}m++;
{switch(key)
case 0x0a:n=5;m=0;x=1;W_lcd(5,0,'+');break;
case 0x0b:n=5;m=0;x=2;W_lcd(5,0,'-');break;
case 0x0c:n=5;m=0;x=3;W_lcd(5,0,'*');break;
case 0x0d:n=5;m=0;x=4;W_lcd(5,0,'/');break;
case 0x0e:n=5;m=5;eql(x);W_lcd(12,0,'=');display_c(x);break;
case 0x0f:n=0;x=0;m=5;data_a=0;data_b=0;data_c=0;LCD_Write_String(0,0,table);LCD_Write_String(0,1,table);W_lcd(0,0,'0');break;
do{P1=0xf0;}while(P1!=0xf0);
1.四则运算,包括负数运算
2.开机显示0,当输入的数值或计算得到的结果大于计算器的表示范围时,计算器会在LCD上提示OV;当除数为0时,计算器会在LCD上提示ERR。
ID:306995 发表于 2018-4-15 16:59 | 只看该作者
有人吗有人吗
ID:164602 发表于 2018-4-16 09:06 | 只看该作者
你的错误很简单!
你的程序: sbit rs=P2^5;//注意:你写的小写p。我写的大写P
都是这个错误。
参与人数 1黑币 +5 收起 理由
Evelynchan + 5
ID:309014 发表于 2018-4-16 10:03 来自触屏版 | 只看该作者
有不明确的定义
ID:309026 发表于 2018-4-16 10:05 | 只看该作者
上面错误是存在未定义,你把p改一下就行。。。
ID:309064 发表于 2018-4-16 10:38 | 只看该作者
你的错误很简单! 你的程序:   sbit rs=P2^5;//注意:你写的小写p。我写的大写P 都是这个错误。
ID:137239 发表于 2018-4-16 10:58 | 只看该作者
‘P’要大写的
ID:309089 发表于 2018-4-16 11:00 | 只看该作者
lcden 没有定义P2的P 要大写
ID:309098 发表于 2018-4-16 11:08 | 只看该作者
端口p要是大写的
ID:309122 发表于 2018-4-16 11:36 | 只看该作者
楼上对的,该大写P
ID:309124 发表于 2018-4-16 11:37 | 只看该作者
p要定义一下
ID:154654 发表于 2018-4-16 13:38 | 只看该作者
检查一下上下文用到的函数是否一致
ID:309251 发表于 2018-4-16 14:49 | 只看该作者
未定义
ID:309242 发表于 2018-4-16 15:02 | 只看该作者
P2^7要大写
ID:306995 发表于 2018-4-16 17:15 | 只看该作者
HC6800-ES-V2.0 发表于 2018-4-16 09:06
你的错误很简单!
你的程序:sbit rs=P2^5;//注意:你写的小写p。我写的大写P
都是这个错误。
我居然犯了低级错误,但是我改过来了还是不行呢怎么办
ID:164602 发表于 2018-4-17 07:22 | 只看该作者
编译的时候还有什么错呢,又发出来啥。
你没有发程序,我就不能在自己的电脑上帮你查,我不可能照着图片打一遍程序吧?!所以,你查了要把结果说出来啥,
ID:155507 发表于 2018-4-17 11:11 来自触屏版 | 只看该作者
你的 #include<reg.51.h> 是 #include<reg51.h> 沒有点
参与人数 1黑币 +5 收起 理由
Evelynchan + 5 很给力!
ID:306995 发表于 2018-4-17 13:31 | 只看该作者
HC6800-ES-V2.0 发表于 2018-4-17 07:22
编译的时候还有什么错呢,又发出来啥。
你没有发程序,我就不能在自己的电脑上帮你查,我不可能照着图片 ...
我已经发了程序了,拜托大佬帮我运行试试
ID:164602 发表于 2018-4-17 16:24 | 只看该作者
陈艺萍 发表于 2018-4-17 13:31
我已经发了程序了,拜托大佬帮我运行试试
我把其它错误点都给你改了,只有这里,我没有时间读程序,不知道你的意思,所以,自己看看,这两个else是怎样的关系(红色位置),错误是:else与if不匹配。#include<reg51.h>
//LCD1602
sbit rs=P2^5;
sbit wela=P2^6;
sbit lcden=P2^7;
long int data_a,data_b;
long int data_c;
uchar display[10];
    while(t--);//t=0í?3?
    unsigned int i,j;
    for(i=0;i<t;i++)
            for(j=0;j<113;j++);
    rs=0;
    lcden=0;
    P0=com;
    LCD_Delay_ms(1);
    lcden=1;
    LCD_Delay_ms(2);
    lcden=0;
//1602D′êy?Y
void write_data(uchar date)
    rs=1;
    lcden=0;
    P0=date;
    LCD_Delay_ms(1);
    lcden=1;
    LCD_Delay_ms(2);
    lcden=0;
        write_data(Data);
        while (*s)
void init_lcd(void)
    wela=0;
    lcden=0;
    write_com(0x38);
    LCD_Delay_us(100);
    write_com(0x0c);
    write_com(0x06);
    write_com(0x01);
    write_com(0x08);
    P1=0xf0;
    LCD_Delay_ms(20);
    temp1=P1;
    P1=0xff;
    LCD_Delay_ms(20);
    P1=0x0f;
    LCD_Delay_ms(20);
    temp2=P1;
    P1=0xff;
    switch(temp)
        default:a=0xff;
    return a;
void display_a()
    write_com(0x80+0);
void display_b()
    write_com(0x80+7);
void display_c(x)
        if(x==4)
            write_data('.');
        else{
            if(data_c>9999)  {write_data('0'+display[4]);}
            if(data_c>999)  {write_data('0'+display[3]);}
            if(data_c>999)  {write_data('0'+display[2]);}
            if(data_c>999)  {write_data('0'+display[1]);}
        else {
            write_date('E');
            write_date('r');
            write_date('r');
            write_date('o');
            write_date('r');
void eql(uchar x)
  switch(x)
                     break;
  case 0:break;
    uchar key=0xff;
        uchar n=0;
        uchar m=5;
        uchar x=0;
        data_a=0;
        data_b=0;
        data_c=0;
        init_lcd();
        display_a();
key=keycheckdown();
if(0xff!=key)
if(key<10)
{switch(key)
ID:306995 发表于 2018-4-17 17:09 | 只看该作者
HC6800-ES-V2.0 发表于 2018-4-17 16:24
我把其它错误点都给你改了,只有这里,我没有时间读程序,不知道你的意思,所以,自己看看,这两个else是 ...
这一段是我最头疼的地方小白真的看不懂
ID:306995 发表于 2018-4-17 17:27 | 只看该作者
void display_c(x)
                { display[8]=data_c%1000000000/100000000;
        if(x==4)
                               write_data('.');
        else{
        else {
            write_date('E');
            write_date('r');
            write_date('r');
            write_date('o');
            write_date('r');
  嵌套后
ID:309896 发表于 2018-4-17 20:39 | 只看该作者
P没有定义吧
ID:306995 发表于 2018-4-17 20:53 | 只看该作者
#include<reg51.h>
//LCD1602
sbit rs=P2^5;
sbit wela=P2^6;
sbit lcden=P2^7;
long int data_c;
uchar display[10];
    while(t--);
    unsigned int i,j;
    for(i=0;i<t;i++)
            for(j=0;j<113;j++);
    rs=0;
    lcden=0;
    P0=com;
    LCD_Delay_ms(1);
    lcden=1;
    LCD_Delay_ms(2);
    lcden=0;
//1602
    rs=1;
    lcden=0;
    P0=date;
    LCD_Delay_ms(1);
    lcden=1;
    LCD_Delay_ms(2);
    lcden=0;
void W_lcd(unsigned char x,unsigned char y,unsigned char date)
        write_date(date);
        while (*s)
        {write_date(*s);s++;}
void init_lcd(void)
    wela=0;
    lcden=0;
    write_com(0x38);
    LCD_Delay_us(100);
    write_com(0x0c);
    write_com(0x06);
    write_com(0x01);
    write_com(0x08);
    P1=0xf0;
    LCD_Delay_ms(20);
    temp1=P1;
    P1=0xff;
    LCD_Delay_ms(20);
    P1=0x0f;
    LCD_Delay_ms(20);
    temp2=P1;
    P1=0xff;
    switch(temp)
        default:a=0xff;
    return a;
void display_a()
    write_com(0x80+0);
    if(data_a>999){write_date('0'+display[3]);}
    if(data_a>99){write_date('0'+display[2]);}
    if(data_a>9){write_date('0'+display[1]);}
void display_b()
    write_com(0x80+7);
    if(data_b>999){write_date('0'+display[3]);}
    if(data_b>99) {write_date('0'+display[2]);}
    if(data_b>9)   {write_date('0'+display[1]);}
void display_c(x)
        if(x==4)
                               write_date('.');
        else{
        else {
            write_date('E');
            write_date('R');
            write_date('R');
                                        write_date('O');
                                        write_date('R');
void eql(uchar x)
  switch(x)
                     break;
  case 4:if(data_b==0){LCD_Write_String(0,1,"ERROR");}
  case 0:break;
    uchar key=0xff;
        uchar n=0;
        uchar m=5;
        uchar x=0;
        data_a=0;
        data_b=0;
        data_c=0;
        init_lcd();
        display_a();
key=keycheckdown();
if(0xff!=key)
if(key<10)
{switch(key)
错误:target not created
ID:291815 发表于 2018-4-17 23:19 | 只看该作者
‘P’要大写的
ID:164602 发表于 2018-4-18 08:30 | 只看该作者
陈艺萍 发表于 2018-4-17 20:53
#include
要我的板子上没有错误啊。
ID:306995 发表于 2018-4-18 13:16 | 只看该作者
HC6800-ES-V2.0 发表于 2018-4-18 08:30
要我的板子上没有错误啊。
那是我的软件问题吗?可是我别的程序都可以编译
ID:306995 发表于 2018-4-18 13:23 | 只看该作者
要我的板子上没有错误啊。
修改代码后.zip (58.11 KB, 下载次数: 4)
