查看: 4152|回复: 4
80C52单片机定时器T2使用问题请教
用T2来控制LED延时1s亮灭,如下图,但烧写进单片机后发现控制不了,
觉得应该是初始化出现问题,但又不清楚是哪里有问题
各位大神,帮帮看一下,谢谢!
ID:155507 发表于 2018-5-23 19:38 | 只看该作者
  1. #include "reg51.h"
  2. typedef unsigned char BYTE;
  3. typedef unsigned int WORD;
  4. //-----------------------------------------------
  5. /* define constants */
  6. #define FOSC 11059200L
  7. #define T1MS (65536-FOSC/12/1000)   //1ms timer calculation method in 12T mode
  8. /* define SFR */
  9. sbit ET2 = IE^5;
  10. sfr T2CON = 0xc8;                   //timer2 control register
  11. sbit TF2  = T2CON^7;
  12. sbit TR2  = T2CON^2;
  13. sfr T2MOD = 0xc9;                   //timer2 mode register
  14. sfr RCAP2L = 0xca;
  15. sfr RCAP2H = 0xcb;
  16. sfr TL2 = 0xcc;
  17. sfr TH2 = 0xcd;
  18. sbit LED = P2^0;               //work LED, flash once per second
  19. /* define variables */
  20. WORD count;                         //1000 times counter
  21. //-----------------------------------------------
  22. /* Timer2 interrupt routine */
  23. void tm2_isr() interrupt 5 using 1
  24. {
  25.     TF2 = 0;
  26.     if (count-- == 0)               //1ms * 1000 -> 1s
  27.     {
  28.         count = 1000;               //reset counter
  29.         LED = ! LED;                              //work LED flash
  30.     }
  31. }
  32. //-----------------------------------------------
  33. /* main program */
  34. void main()
  35. {
  36.     RCAP2L = TL2 = T1MS;            //initial timer2 low byte
  37.     RCAP2H = TH2 = T1MS >> 8;       //initial timer2 high byte
  38.     TR2 = 1;                        //timer2 start running
  39.     ET2 = 1;                        //enable timer2 interrupt
  40.     EA = 1;                         //open global interrupt switch
  41.     count = 0;                      //initial counter
  42.     while (1);                      //loop
  43. }
ID:18297 发表于 2018-5-23 19:30 | 只看该作者
初始化时需要加2条语句(仿真可行):
EA=1;//开总中断允许
ET2=1; //开定时器T2的中断允许
否则你的定时器T2溢出但不产生中断。
ID:269211 发表于 2018-5-23 16:19 | 只看该作者
为何要用定时器2呢?用0与1都可以呀
ID:330198 发表于 2018-5-18 08:55 | 只看该作者
你TH2和TL2初值0xff不对,LED=!LED,这句也错了,应该LED=~LED。
