查看: 2122|回复: 0
OSRAM 车用头灯最新LED OBF系列
ID:323602 发表于 2018-5-6 17:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
OSLON Black Flat S is able to meet a wide range of requirements. The SMT device is very stable, durable and can be used with standard processes. A new solder pad layout allows for high reliability and improved thermal management.The compact chips not only deliver high light output, they are also individually addressable with an ensured chip-to-chip contrast which makes this LED an ideal solution for Adaptive Driving Beam (ADB)
