查看: 1762|回复: 1
基于51单片机制作的电子时钟无法仿真模拟!新人求助
ID:343840 发表于 2018-6-3 10:01 | 显示全部楼层 |阅读模式
源代码:
# include <reg51.h>
# define uchar unsigned char
# define uint unsigned int
uchar code write_address[]={0x80,0x82,0x84,0x86,0x88,0x8a,0x8c};
uchar code read_address[]={0x81,0x83,0x85,0x87,0x89,0x8b,0x8d};
uchar code table[]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6};
uchar date[]={0x01,0x01,0x01,0x09,0x05,0x02,0x12};
uchar date1[]={0x01,0x01,0x01,0x09,0x05,0x02,0x12};
sbit RST=P3^0;
sbit SCL=P3^1;
sbit SDA=P3^2;
sbit ACC7=ACC^7;
uchar temp,byte;
int write_byte(int adderss);
void delay(uint m)
      while(m--);
void wirte_byte(uchar byte)
      uchar m;
      for(m=0;m<8;m++)
  byte>>=1;
  SCL=0;
  SDA=CY;
  SCL=1;
uchar read_byte(void)
  uchar m;
  for(m=0;m,8;m++)
    ACC=ACC>>1;
    ACC7=SDA;
    SCL=1;
    SCL=0;
  return (ACC);
void write_1302(uchar address,uchar date)
      RST=0;
      SCL=0;
      RST=1;
      write_byte(address);
      write_byte(date);
      RST=0;
read_data(uchar address)
      uchar temp;
      RST=0;
      SCL=0;
      RST=1;
      write_byte(address|0x01);
      temp=read_byte();
      SCL=1;
      RST=0;
      return(temp);
void read_time()
      uchar m,temp3,temp1,temp2;
      temp3=0x80;
      for(m=0;m<7;m++)
     temp1=read_data(temp3);
     temp2=temp1;
     date[m]=(temp1>>1)&0x0f;
     date1[m]=(temp2>>5)&0x07;
     temp3=temp3+0x02;
void set_RTC(void)
      uchar m;
      write_1302(0x8E,0x00);
      for(m=0;m<7;m++)
     write_1302(write_address[m],date[m]);
void main(void)
      RST=0;
      set_RTC();
     read_time();
     P2=0xfe;
     P1=table[date[0]%10];
     delay(500);
     P2=0xfd;
     P1=table[date1[0]%10];
     delay(500);
     P2=0xfb;
     P1=0x02;
     delay(500);
     P2=0xf7;
     P1=table[date[1]%10];
     delay(500);
     P2=0xef;
     P1=table[date1[1]%100];
     delay(500);
     P2=0xdf;
     P1=0x02;
     delay(500);
     P2=0xbf;
     P1=table[date[2]%10];
     delay(500);
     P2=0x7f;
     P1=table[date1[2]%10];
     delay(500);
附电路图。
代码检查无错误,电器规则性检查无错误,但是模拟时无任何反应!!!!!!
求问大佬们,这是什么情况,怎么解决?
ID:343840 发表于 2018-6-3 10:03 | 显示全部楼层
刚刚接触单片机,希望大佬帮助问一下,
