查看: 5675|回复: 2
PT6965+STM32数码管显示源码
PT6965驱动数码管电路原理图如下:
stm32单片机源程序如下:
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "key.h"
  6. #include "SMG.h"
  7. #include "timer.h"
  8. #define  Desplay_ms  300
  9. int delay_s=0; int n1=0; int n2=0 ; int n3=0 ; int s=0; int n11=0; int n21=0 ; int n31=0 ;
  10. /*--------------0----1----2----3----4----5----6----7----8----9----A----b----C----d----E----F*/
  11. u8 TAB[10] = {0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00};//数码管显示1-
  12. u16 GR4GR5[2]={0xffff,0x0000};//后面两个数据地址线所存储的数据
  13. void LED_Desplay(void);
  14. int main(void)
  15. {
  16.   SystemInit();               //系统启动时钟函数的初始化时钟时钟为72MHz
  17. //        NVIC_Configuration();//设置强占优先级与响应优先级
  18.         delay_init();               //延时函数初始化
  19.         LED_Init();                             //LED初始初始化
  20.         KEY_Init();          //KEY初始化
  21.   LED_text();
  22.          SMG_Init();
  23.         PT6965_Init();
  24.   TIM3_Int_Init(2499,7199);//10Khz的计数频率,计数到5000为500ms
  25.
  26. //要求上电全部点亮,初次上电全部点亮
  27. ///////////////////
  28.     LED_Desplay();
  29.                 while(1)
  30.                 {
  31.                                  if(delay_s>4)
  32.                                 {
  33.                                         s=s+1;
  34.                                         delay_s=0;
  35.                           }
  36.
  37.                                 if(s>=999)//显示每一秒变动一次
  38.                                 {
  39.                                         s=0;
  40.                           }
  41.
  42.
  43.                                 n1=s%10;
  44.                                 n2=(s%100)/10;
  45.                                 n3=s/100;
  46.                                 if(n1!=n11)
  47.                                 {
  48.                                         if(n1==0){
  49.                                                              DIS_1668(0xc4,0xBF);
  50.                                     DIS_1668(0xc5,0x1f);
  51.                                                       DIS_1668(0xc7,TAB[7]|0x01);//变为1
  52.                                                 }
  53.
  54.                                         if(n1==1){
  55.                                                              DIS_1668(0xc4,0x06);
  56.                                     DIS_1668(0xc5,0x0f);
  57.                                                       DIS_1668(0xc7,TAB[7]&0xfe);//之为0
  58.                                                 }
  59.                                         if(n1==2){
  60.                                                              DIS_1668(0xc4,0xdB);
  61.                                     DIS_1668(0xc5,0x1f);
  62.                                                       DIS_1668(0xc7,TAB[7]|0x01);//变为1
  63.                                                 }
  64.                                         if(n1==3){
  65.                                                              DIS_1668(0xc4,0xcf);
  66.                                     DIS_1668(0xc5,0x1f);
  67.                                                       DIS_1668(0xc7,TAB[7]|0x01);//变为1
  68.                                                 }
  69.                                         if(n1==4){
  70.                                                              DIS_1668(0xc4,0xe6);
  71.                                     DIS_1668(0xc5,0x0f);
  72.                                                       DIS_1668(0xc7,TAB[7]|0x01);//变为1
  73.                                                 }
  74.                                         if(n1==5){
  75.                                                              DIS_1668(0xc4,0xed);
  76.                                     DIS_1668(0xc5,0x1f);
  77.                                                       DIS_1668(0xc7,TAB[7]|0x01);//变为1
  78.                                                 }
  79.                                         if(n1==6){
  80.                                                              DIS_1668(0xc4,0xfd);
  81.                                     DIS_1668(0xc5,0x1f);
  82.                                                       DIS_1668(0xc7,TAB[7]|0x01);//变为1
  83.                                                 }
  84.                                         if(n1==7){
  85.                                                              DIS_1668(0xc4,0x87);
  86.                                     DIS_1668(0xc5,0x0f);
  87.                                                       DIS_1668(0xc7,TAB[7]&0xfe);//之为0
  88.                                                 }
  89.                                         if(n1==8){
  90.                                                              DIS_1668(0xc4,0xff);
  91.                                     DIS_1668(0xc5,0x1f);
  92.                                                       DIS_1668(0xc7,TAB[7]|0x01);//变为1
  93.                                                 }
  94.
  95.                                         if(n1==9){
  96.                                                              DIS_1668(0xc4,0xef);
  97.                                     DIS_1668(0xc5,0x1f);
  98.                                                       DIS_1668(0xc7,TAB[7]|0x01);//变为1
  99.                                                 }
  100.
  101.                                 }
  102.
  103.
  104.                                 if(n2!=n21)
  105.                                 {
  106.                                         if(n2==0){
  107.                                                              DIS_1668(0xc2,0xBF);
  108.                                     DIS_1668(0xc3,0x1f);
  109.                                                       TAB[6]=TAB[6]|0x80;
  110.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  111.                                                 }
  112.
  113.                                         if(n2==1){
  114.                                                              DIS_1668(0xc2,0x06);
  115.                                     DIS_1668(0xc3,0x0f);
  116.                                                       TAB[6]=TAB[6]&0x7f;
  117.                                                       DIS_1668(0xc6,TAB[6]);//之为0
  118.                                                 }
  119.                                         if(n2==2){
  120.                                                              DIS_1668(0xc2,0xdB);
  121.                                     DIS_1668(0xc3,0x1f);
  122.                                                       TAB[6]=TAB[6]|0x80;
  123.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  124.                                                 }
  125.                                         if(n2==3){
  126.                                                              DIS_1668(0xc2,0xcf);
  127.                                     DIS_1668(0xc3,0x1f);
  128.                                                       TAB[6]=TAB[6]|0x80;
  129.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  130.                                                 }
  131.                                         if(n2==4){
  132.                                                              DIS_1668(0xc2,0xe6);
  133.                                     DIS_1668(0xc3,0x0f);
  134.                                                       TAB[6]=TAB[6]|0x80;
  135.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  136.                                                 }
  137.                                         if(n2==5){
  138.                                                              DIS_1668(0xc2,0xed);
  139.                                     DIS_1668(0xc3,0x1f);
  140.                                                       TAB[6]=TAB[6]|0x80;
  141.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  142.                                                 }
  143.                                         if(n2==6){
  144.                                                              DIS_1668(0xc2,0xfd);
  145.                                     DIS_1668(0xc3,0x1f);
  146.                                                       TAB[6]=TAB[6]|0x80;
  147.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  148.                                                 }
  149.                                         if(n2==7){
  150.                                                              DIS_1668(0xc2,0x87);
  151.                                     DIS_1668(0xc3,0x0f);
  152.                                                       TAB[6]=TAB[6]&0x7f;
  153.                                                       DIS_1668(0xc6,TAB[6]);//之为0
  154.                                                 }
  155.                                         if(n2==8){
  156.                                                              DIS_1668(0xc2,0xff);
  157.                                     DIS_1668(0xc3,0x1f);
  158.                                                       TAB[6]=TAB[6]|0x80;
  159.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  160.                                                 }
  161.
  162.                                         if(n2==9){
  163.                                                              DIS_1668(0xc2,0xef);
  164.                                     DIS_1668(0xc3,0x1f);
  165.                                                       TAB[6]=TAB[6]|0x80;
  166.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  167.                                                 }
  168.
  169.                                 }
  170.
  171.
  172.         if(n3!=n31)
  173.                                 {
  174.                                         if(n3==0){
  175.                                                              DIS_1668(0xc0,0xBF);
  176.                                     DIS_1668(0xc1,0x1f);
  177.                                                       TAB[6]=TAB[6]|0x40;
  178.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  179.                                                 }
  180.
  181.                                         if(n3==1){
  182.                                                              DIS_1668(0xc0,0x06);
  183.                                     DIS_1668(0xc1,0x0f);
  184.                                                       TAB[6]=TAB[6]|0xbf;
  185.                                                       DIS_1668(0xc6,TAB[6]);//之为0
  186.                                                 }
  187.                                         if(n3==2){
  188.                                                              DIS_1668(0xc0,0xdB);
  189.                                     DIS_1668(0xc1,0x1f);
  190.                                                       TAB[6]=TAB[6]|0x40;
  191.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  192.                                                 }
  193.                                         if(n3==3){
  194.                                                              DIS_1668(0xc0,0xcf);
  195.                                     DIS_1668(0xc1,0x1f);
  196.                                                       TAB[6]=TAB[6]|0x40;
  197.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  198.                                                 }
  199.                                         if(n3==4){
  200.                                                              DIS_1668(0xc0,0xe6);
  201.                                     DIS_1668(0xc1,0x0f);
  202.                                                       TAB[6]=TAB[6]|0x40;
  203.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  204.                                                 }
  205.                                         if(n3==5){
  206.                                                              DIS_1668(0xc0,0xed);
  207.                                     DIS_1668(0xc1,0x1f);
  208.                                                       TAB[6]=TAB[6]|0x40;
  209.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  210.                                                 }
  211.                                         if(n3==6){
  212.                                                              DIS_1668(0xc0,0xfd);
  213.                                     DIS_1668(0xc1,0x1f);
  214.                                                       TAB[6]=TAB[6]|0x40;
  215.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  216.                                                 }
  217.                                         if(n3==7){
  218.                                                              DIS_1668(0xc0,0x87);
  219.                                     DIS_1668(0xc1,0x0f);
  220.                                                      TAB[6]=TAB[6]&0xbf;
  221.                                                       DIS_1668(0xc6,TAB[6]&0xbf);//之为0
  222.                                                 }
  223.                                         if(n3==8){
  224.                                                              DIS_1668(0xc0,0xff);
  225.                                     DIS_1668(0xc1,0x1f);
  226.                                                       TAB[6]=TAB[6]|0x40;
  227.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  228.                                                 }
  229.
  230.                                         if(n3==9){
  231.                                                              DIS_1668(0xc0,0xef);
  232.                                     DIS_1668(0xc1,0x1f);
  233.                                                       TAB[6]=TAB[6]|0x40;
  234.                                                       DIS_1668(0xc6,TAB[6]);//变为1
  235.                                                 }
  236.
  237.                                 }
  238.
  239.                                         if(delay_s==2) DIS_1668(0xc6,(TAB[6] & 0xfe)); //小数点显示
  240.
  241.                                         if(delay_s==4) DIS_1668(0xc6,(TAB[6] | 0x01)); //小数点显示
  242.
  243.                                 n11=n1; n21=n2; n31=n3;
  244.                 }
  245. }
  246. void LED_Desplay(void)
  247. {
  248.                         DIS_1668(0xc0,0xff);
  249.                         DIS_1668(0xc1,0xff);
  250.                         DIS_1668(0xc2,0xff);
  251.                         DIS_1668(0xc3,0xff);
  252.                         DIS_1668(0xc4,0xff);
  253.                         DIS_1668(0xc5,0xff);
  254.                         DIS_1668(0xc6,0xff);
  255.
  256.                         DIS_1668(0xc7,0xff);
  257.                         DIS_1668(0xc8,0xff);
  258.                         DIS_1668(0xc9,0xff);
  259.       delay_ms(Desplay_ms);
  260.                                                 DIS_1668(0xc0,0x00);
  261.                                                 DIS_1668(0xc1,0x00);
  262.                                                 DIS_1668(0xc2,0x00);
  263.                                                 DIS_1668(0xc3,0x00);
  264.                                                 DIS_1668(0xc4,0x00);
  265.                                                 DIS_1668(0xc5,0x00);
  266.                                                 DIS_1668(0xc6,0x00);
  267.
  268.                                                 DIS_1668(0xc7,0x02);
  269.                                           DIS_1668(0xc8,0x49);
  270.                                           DIS_1668(0xc9,0x1d);
  271.                                     delay_ms(Desplay_ms);
  272.                 /////////////单色
  273.                                                 DIS_1668(0xc0,0x00);
  274.                                                 DIS_1668(0xc1,0x00);
  275.                                                 DIS_1668(0xc2,0x00);
  276.                                                 DIS_1668(0xc3,0x00);
  277.                                                 DIS_1668(0xc4,0x00);
  278.                                                 DIS_1668(0xc5,0x00);
  279.                                                 DIS_1668(0xc6,0x00);
  280.
  281.             DIS_1668(0xc7,0x00);
  282.                                           DIS_1668(0xc8,0x12);
  283.                                           DIS_1668(0xc9,0x00);
  284.                         delay_ms(Desplay_ms);
  285.
  286.
  287.                                                 DIS_1668(0xc0,0x00);
  288.                                                 DIS_1668(0xc1,0x00);
  289.                                                 DIS_1668(0xc2,0x00);
  290.                                                 DIS_1668(0xc3,0x00);
  291.                                                 DIS_1668(0xc4,0x00);
  292.                                                 DIS_1668(0xc5,0x00);
  293.                                                 DIS_1668(0xc6,0x00);
  294.
  295.             DIS_1668(0xc7,0x00);
  296.                                           DIS_1668(0xc8,0xa4);
  297.                                           DIS_1668(0xc9,0x02);
  298.                   delay_ms(Desplay_ms);
  299. ////////////////////////////////////
  300.        DIS_1668(0xc0,0x80);
  301.        DIS_1668(0xc1,0xff);
  302.        DIS_1668(0xc2,0x80);
  303.        DIS_1668(0xc3,0xff);
  304.        DIS_1668(0xc4,0x80);
  305.        DIS_1668(0xc5,0xff);
  306.        DIS_1668(0xc6,0xff);
  307.
  308.        DIS_1668(0xc7,0x01);
  309.        DIS_1668(0xc8,0x00);
  310.        DIS_1668(0xc9,0x00);
  311.                                         delay_ms(Desplay_ms);
  312.
  313.
  314.        DIS_1668(0xc0,0xc9);
  315.        DIS_1668(0xc1,0xff);
  316.        DIS_1668(0xc2,0xc9);
  317.        DIS_1668(0xc3,0xff);
  318.        DIS_1668(0xc4,0xc9);
  319.        DIS_1668(0xc5,0xff);
  320.        DIS_1668(0xc6,0xc0);
  321.
  322.        DIS_1668(0xc7,0x01);
  323.        DIS_1668(0xc8,0x00);
  324.        DIS_1668(0xc9,0x00);
  325.                                   delay_ms(Desplay_ms);
  326.
  327.
  328.        DIS_1668(0xc0,0xb6);
  329.        DIS_1668(0xc1,0xff);
  330.        DIS_1668(0xc2,0xb6);
  331.        DIS_1668(0xc3,0xff);
  332.        DIS_1668(0xc4,0xb6);
  333.        DIS_1668(0xc5,0xff);
  334.        DIS_1668(0xc6,0xc0);
  335.
  336.        DIS_1668(0xc7,0x01);
  337.        DIS_1668(0xc8,0x00);
  338.        DIS_1668(0xc9,0x00);
  339.                       delay_ms(Desplay_ms);
  340. //////////////////////////////////////
  341.             STB_H;
  342.         delay_ms(1);
  343.     STB_L;
  344.     Send_data(0X87); //打开显示
  345.        DIS_1668(0xc0,0xff);
  346.        DIS_1668(0xc1,0xff);
  347.        DIS_1668(0xc2,0x00);
  348.        DIS_1668(0xc3,0x00);
  349.        DIS_1668(0xc4,0x00);
  350.        DIS_1668(0xc5,0x00);
  351.        DIS_1668(0xc6,0x40);
  352.
  353.        DIS_1668(0xc7,0x00);
  354.        DIS_1668(0xc8,0x00);
  355.        DIS_1668(0xc9,0x00);
  356.             STB_H;
  357.         delay_ms(1);
  358.     STB_L;
  359.     Send_data(0X8f); //打开显示
  360. ……………………
  361. …………限于本文篇幅 余下代码请从51黑下载附件…………
PT6965 -数字显示.rar (307.19 KB, 下载次数: 29)
ID:1 发表于 2018-8-23 02:08 | 只看该作者
原理图能分享下吗?
ID:388121 发表于 2018-8-23 10:43 | 只看该作者
admin 发表于 2018-8-23 02:08
原理图能分享下吗?
可以分享数码管内部的原理图,我是用DEMO板用杜邦线驱动的所以与单片机的几条线看程序.H文件中有定义的谢谢!
参与人数 1黑币 +40 收起 理由
admin + 40 回帖助人的奖励!
