查看: 1947|回复: 1
串行DA TLC5615的单片机驱动源程序
ID:773431 发表于 2020-6-8 23:21 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<intrins.h>
#define  uint unsigned int
sbit                 SCL =         P1^1;
sbit                 CS  =         P1^2;
sbit                 SDA =         P1^0;
uchar bdata dat_in_h;
uchar bdata dat_in_l;
sbit h_7 = dat_in_h^7;
sbit l_7 = dat_in_l^7;
void delayms(uint j)
uchar i=250;
for(;j>0;j--)
         {while(--i);
         i=249;
         while(--i);
         i=250;
*** 函 数 名: void Write_12Bits()
*** 功能描述: 一次向TLC中写入12bit数据;
void Write_12Bits(void)
        uchar i;
        SCL = 0;                                //置零SCL,为写bit做准备;
        CS = 0;
        for(i=0;i<2;i++)//循2次,发送高两位;
                if(h_7)                                //高位先发;
                                SDA = 1;        //将数据送出;
                                SCL = 1;        //提升时钟,写操作在时钟上升沿触发;
                                SCL = 0;        //结束该位传送,为下次写作准备;
                                SDA = 0;
                                SCL = 1;
                                SCL = 0;
                dat_in_h <<= 1;
        for(i=0;i<8;i++)//循环八次,发送低八位;
                if(l_7)
                                SDA = 1;        //将数据送出;
                                SDA = 0;
                                SCL = 1;
                                SCL = 0;
                dat_in_l <<= 1;
        for(i=0;i<2;i++)//循环2次,发送两个虚拟位;
                SDA = 0;
                SCL = 1;
                SCL = 0;
        CS = 1;
        SCL = 0;
*** 函 数 名: void TLC5615_Start(uint dat_in)
*** 功能描述: 启动DAC转换;
        dat_in %= 1024;
        dat_in_h = dat_in/256;
        dat_in_l = dat_in%256;
        dat_in_h <<= 6;
        Write_12Bits();
         TLC5615_Start(0xffff);
         delayms(1);
ID:1 发表于 2020-6-9 16:26 | 显示全部楼层
