查看: 7476|回复: 3
w25q16DV引脚图与功能16M spi flash资料手册下载
ID:280089 发表于 2018-1-27 09:45 | 显示全部楼层 |阅读模式
16M spi flash 资料分享给大家
w25q16DV引脚图:
w25q16DV管脚功能描述:
2.  FEATURES
•  Family of SpiFlash Memories
– W25Q16BV: 16M-bit / 2M-byte (2,097,152)
– 256-bytes per programmable page
•  Standard, Dual or Quad SPI
– Standard SPI: CLK, /CS, DI, DO, /WP, /Hold
– Dual SPI: CLK, /CS, IO0, IO1, /WP, /Hold
– Quad SPI: CLK, /CS, IO0, IO1, IO2, IO3
•  Highest Performance Serial Flash
– Up to 8X that of ordinary Serial Flash
– 104MHz clock operation
– 208MHz equivalent Dual SPI
– 416MHz equivalent Quad SPI
– 50MB/S continuous data transfer rate
•  Efficient “Continuous Read Mode”
– Low Instruction overhead
– As few as 8 clocks to address memory
– Allows true XIP (execute in place) operation
– Outperforms X16 Parallel Flash
•  Low Power, Wide Temperature Range
– Single 2.7 to 3.6V supply
– 4mA active current, <1µA Power-down (typ.)
– -40°C to +85°C operating range
•  Flexible Architecture with 4KB sectors
– Uniform Sector Erase (4K-bytes)
– Block Erase (32K and 64K-bytes)
– Program one to 256 bytes
– More than 100,000 erase/write cycles
– More than 20-year data retention
•  Advanced Security Features
– Software and Hardware Write-Protect
– Top or Bottom, Sector or Block selection
– Lock-Down and OTP protection(1)
– 64-Bit Unique ID for each device
•  Space Efficient Packaging
– 8-pin SOIC 150(2)
/208-mil
– 8-pad WSON 6x5-mm
– 8-pin PDIP 300-mil
(2)
– 16-pin SOIC 300-mil
(2)
– Contact Winbond for KGD and other options
Notes  1. Refer to Ordering Information.
2. These package types are Special Order Only, please contact Winbond for more information.
PDF格式的资料手册下载:
w25q16DVSSIG.pdf (2.02 MB, 下载次数: 27)
ID:314367 发表于 2018-4-23 12:26 | 显示全部楼层
用什么软件刷啊
ID:226872 发表于 2018-8-31 11:31 | 显示全部楼层
可以 谢谢了
ID:281465 发表于 2021-3-18 09:41 | 显示全部楼层
ok, perfect
