查看: 3920|回复: 1
stm32单片机裸机调用百度语音识别接口和合成接口的部分代码实现
ID:44609 发表于 2018-11-8 19:52 | 显示全部楼层 |阅读模式
  1. int8_t WebClient(const char *url, const char *post, uint8_t **pageBuf,uint8_t is_upload_wav,uint32_t wav_len1)
  2. {
  3.
  4.          uint32_t i;
  5.
  6.   uint8_t server_addr[200];//这2个放在局部变量里,防止多线程冲突:
  7.      uint8_t web_addr[1200];//有的tts的二次url编码后的请求长度很长,所以这个大点
  8. ip_addr_t server_ip;
  9. uint8_t ishttps;
  10.    uint16_t start_char_i;
  11.     uint16_t start_len1;
  12.   uint32_t ret_lens;
  13.          err_t err ;
  14.
  15.    uint32_t  j, k;
  16.    uint32_t head_and_wav_len1;
  17.     struct netconn *conn = NULL;
  18.     struct netbuf *inBuf = NULL;
  19.     struct pbuf *q;
  20.     char *request = NULL;
  21.     uint32_t recvPos = 0;
  22.     uint8_t *recvBuf;
  23.     err_t err_msg;
  24.     while(wifi_88w8801_sta.ip_addr.addr == 0x00)
  25.     {
  26.         return HTTP_ROUTE_NOT_FOUND;
  27.     }
  28.
  29.
  30.    if(strncasecmp((const char *)url, "http://", 7) == 0||strncasecmp((const char *)url, "https://", 8) == 0)                 /* 只处理http协议 */
  31.     {
  32.
  33.
  34.                  if(strncasecmp((const char *)url, "http://", 7) == 0){
  35.
  36.                          ishttps=0;
  37.                          start_char_i=4;
  38.                          start_len1=7;
  39.                  }
  40.
  41.                  if(strncasecmp((const char *)url, "https://", 8) == 0){
  42.
  43.                          ishttps=1;
  44.                          start_char_i=5;
  45.                          start_len1=8;
  46.                  }
  47.
  48.
  49.                  if(ishttps==0){
  50.                           ////改为全局变量式,可以防止内存泄露:
  51.         //server_addr = pvPortMalloc2 strlen(url) - 7);
  52.
  53.                  }else{
  54.
  55.                           ////改为全局变量式,可以防止内存泄露:
  56.         //server_addr = pvPortMalloc2 strlen(url) - 8);
  57.
  58.                  }
  59.
  60.
  61.                  ////改为全局变量式,可以防止内存泄露:
  62. //        if(server_addr == NULL) {
  63. //
  64. //                          printf("HTTP_OUT_OF_RAM in malloc server_addr");
  65. //
  66. //                          return HTTP_OUT_OF_RAM;
  67. //
  68. //
  69. //                  }
  70.   printf("proceess 1\r\n");
  71.                  /* 1)提取服务器部分 */
  72.         for(i = start_char_i; url[i]; ++i)
  73.         {
  74.             if (url[i] == ':' && url[i + 1] == '/' && url[i + 2] == '/')
  75.             {
  76.                 for (i = i + 3, j = 0; url[i] > 32 && url[i] < 127 && url[i] != '/'; //32-127间的ascII码的字符
  77.                         ++i, ++j)
  78.                 {
  79.                     server_addr[j] = url[i];
  80.                     if (url[i] == '@') /* 服务器基础认证符号,我们做不了,遇到就错误. */
  81.                     {
  82.                         return HTTP_AUTH_NOT_SUPPORT;
  83.                     }
  84.                 }
  85.                 server_addr[j] = '\0';
  86.
  87.                                                   ////改为全局变量式,可以防止内存泄露:
  88.                 //web_addr = pvPortMalloc2 strlen(url) - start_len1 - strlen((const char *)server_addr));
  89.                 //if(web_addr == NULL) return HTTP_OUT_OF_RAM;
  90.                 for (k = start_len1 + j; k < (strlen(url)); k++) /* 后半部分提取 */
  91.                 {
  92.                     web_addr[k - start_len1 - j] = url[k];
  93.                 }
  94.                 web_addr[k - start_len1 - j] = '\0';
  95.                 while (--j)
  96.                 {
  97.                     if (server_addr[j] == ':')//??过滤端口号?
  98.                     {
  99.                         server_addr[j] = '\0';
  100.                     }
  101.                 }
  102.             }
  103.         }
  104.         if(strlen((const char *)server_addr) < 2) /* 最短网址3.cn */
  105.         {
  106.
  107.
  108.                      printf("HTTP_SERVER_ADDR_ERROR\r\n");
  109.
  110.
  111.
  112.                      printf(server_addr);
  113.
  114.                                    ////改为全局变量式,可以防止内存泄露:
  115.                                 //vPortFree2 server_addr);
  116.
  117.                                    ////改为全局变量式,可以防止内存泄露:
  118.           //  if(web_addr == NULL) {vPortFree2 web_addr); }
  119.
  120.                                 /* 这么短,还不一定提取到了这个. */
  121.
  122.
  123.             return HTTP_SERVER_ADDR_ERROR;
  124.         }
  125.
  126.                   printf("\r\nweb host:");
  127.                   printf(server_addr);
  128.
  129.
  130.
  131.         /* 2)查询IP */
  132.          netconn_gethostbyname((const char *)server_addr, &server_ip);
  133.
  134.
  135. //
  136. //                  server_ip.addr=0;
  137. //                  err =  dns_gethostbyname((const char *)server_addr, &server_ip,dns_foundB , NULL);//dns_foundB
  138. //  if (err == ERR_OK)
  139. //  {
  140. //    printf("In cache! IP: %s\n", ipaddr_ntoa(&server_ip));
  141. //  }
  142. //
  143. //
  144. //                  while(server_ip.addr==0){
  145. //
  146. //
  147. //                  }
  148. //
  149.                            printf("get a IP: %s\n", ipaddr_ntoa(&server_ip));
  150.
  151.
  152.                         if(is_upload_wav==1){
  153.         /* 3)构造访问头 */
  154.
  155.
  156.
  157.         request = pvPortMalloc2( strlen(url) + wav_len1+1024); /* 头所需内存大小. */
  158.
  159.
  160.
  161.
  162.                         }else if(is_upload_wav==0){
  163.
  164.                                   request = pvPortMalloc2( strlen(url) + 1024); /* 头所需内存大小. */
  165.
  166.                         }else if(is_upload_wav==2){
  167.
  168.                                   request = pvPortMalloc2( strlen(url) + 1024); /* 头所需内存大小. */
  169.
  170.                         }
  171.
  172.         if(request == NULL)
  173.                           {
  174.
  175.
  176.                   printf("HTTP_OUT_OF_RAM in request Malloc.");
  177.
  178.                   return HTTP_OUT_OF_RAM;
  179.
  180.                           }
  181.
  182.                         if(is_upload_wav==1){
  183.
  184.
  185.
  186.           #if upload_Wav0_or_pcm1 ==0
  187.          sprintf(request, "POST %s HTTP/1.0\r\nHost: %s\r\nUser-Agent:Mozilla/5.0 (Windows; U; Windows NT 6.1; en-us) AppleWebKit/534.50 (KHTML, like Gecko) Version/5.1 Safari/534.50\r\nContent-Length: %d\r\nContent-Type: audio/wav;rate=8000\r\n\r\n", web_addr, server_addr, wav_len1);
  188.           #endif
  189.
  190.
  191.
  192.           #if upload_Wav0_or_pcm1 ==1
  193.          sprintf(request, "POST %s HTTP/1.0\r\nHost: %s\r\nUser-Agent:Mozilla/5.0 (Windows; U; Windows NT 6.1; en-us) AppleWebKit/534.50 (KHTML, like Gecko) Version/5.1 Safari/534.50\r\nContent-Length: %d\r\nContent-Type: audio/pcm;rate=8000\r\n\r\n", web_addr, server_addr, wav_len1);
  194.           #endif
  195.
  196.                                 head_and_wav_len1=strlen(request)+wav_len1;
  197.
  198.                                 memcpy( &request[strlen(request)],post,wav_len1);
  199.
  200.
  201.                         }else if(is_upload_wav==0){
  202.
  203.                                           if(post != NULL){
  204.                                                         sprintf(request, "POST %s HTTP/1.0\r\nHost: %s\r\nUser-Agent:Mozilla/5.0 (Windows; U; Windows NT 6.1; en-us) AppleWebKit/534.50 (KHTML, like Gecko) Version/5.1 Safari/534.50\r\nContent-Length: %d\r\nContent-Type: application/x-www-form-urlencoded\r\n\r\n%s", web_addr, server_addr, strlen(post), post);
  205.
  206.                                                  // printf( "POST %s HTTP/1.0\r\nHost: %s\r\nUser-Agent: Mozilla/5.0 (lwip;STM32) TaterLi\r\nContent-Length: %d\r\nContent-Type: application/x-www-form-urlencoded\r\n\r\n%s", web_addr, server_addr, strlen(post), post);
  207.
  208.
  209.                                           }else{
  210.                                                         sprintf(request, "GET %s HTTP/1.0\r\nHost: %s\r\nUser-Agent:Mozilla/5.0 (Windows; U; Windows NT 6.1; en-us) AppleWebKit/534.50 (KHTML, like Gecko) Version/5.1 Safari/534.50\r\n\r\n", web_addr, server_addr);
  211.
  212.
  213.
  214.                                           }
  215.
  216.             }else if(is_upload_wav==2){
  217.
  218.
  219.                                  sprintf(request, "GET %s HTTP/1.0\r\nHost: %s\r\nUser-Agent:Mozilla/5.0 (Windows; U; Windows NT 6.1; en-us) AppleWebKit/534.50 (KHTML, like Gecko) Version/5.1 Safari/534.50\r\n\r\n", web_addr, server_addr);
  220.                                           MP3_return_data_len=0;
  221.
  222.                  }
  223.
  224.                   //vPortFree2 (server_addr);
  225.         if(web_addr != NULL)
  226.         {
  227.             /* 万一没提取到,就是NULL,如果是NULL,那么也不用继续了. */
  228.                                    ////改为全局变量式,可以防止内存泄露:
  229.             //vPortFree2 web_addr);
  230.         }
  231.         else
  232.         {
  233.             vPortFree2 (request);
  234.
  235.                            printf("HTTP_NOT_VALID_ADDR");
  236.             return HTTP_NOT_VALID_ADDR;
  237.         }
  238.
  239.
  240.         /* 4)开始访问 */
  241.         conn = netconn_new(NETCONN_TCP);
  242.
  243.
  244.         err_msg = netconn_connect(conn, &server_ip, 80); /* 目前也只能支持80端口,比较常用,不考虑特殊情况. */
  245.
  246.
  247.
  248.         if (err_msg == ERR_OK)
  249.         {
  250.                             //  struct netbuf *inBuf_g = NULL;
  251.
  252.
  253.                         if(is_upload_wav==1){
  254.             netconn_write(conn, request, head_and_wav_len1, NETCONN_COPY);
  255.
  256.                         }else if(is_upload_wav==0){
  257.                            netconn_write(conn, request, strlen((char *)request), NETCONN_COPY);
  258.
  259.
  260.                         }else if(is_upload_wav==2){
  261.
  262.                                   netconn_write(conn, request, strlen((char *)request), NETCONN_COPY);
  263.
  264.
  265.                         }
  266.
  267.
  268.             vPortFree2 (request);
  269.             conn->recv_timeout = 15000;//15s
  270.
  271.             recvPos = 0;
  272.                         if(is_upload_wav==2){
  273.
  274.                                 u32 offsetptr;
  275.
  276.
  277.           void *data;
  278.           u16_t len;
  279.
  280.
  281.
  282.                recvPos = 0;
  283.             ret_lens=0;
  284.                                 offsetptr=0;
  285.             while(1)
  286.                                 {
  287.                                         err=netconn_recv(conn, &inBuf);
  288.
  289.                                         if(inBuf==NULL){
  290.
  291.                                                 break;
  292.                                         }
  293.
  294.                                 do
  295.             {
  296.               netbuf_data(inBuf, &data, &len);
  297.
  298.
  299.                                         memcpy(MP3_return_data+ret_lens,data,len);
  300.
  301.                                                  ret_lens+=len;
  302.
  303.
  304.             }
  305.             while (netbuf_next(inBuf) >= 0);
  306.
  307.
  308.                                          printf("ret_lens=%d\r\n",ret_lens);
  309.                                      netbuf_delete(inBuf);
  310.             }
  311.             // printf (MP3_return_data);
  312.             netconn_close(conn);
  313.             netconn_delete(conn);
  314.            // netbuf_delete(inBuf);
  315.
  316.
  317.
  318.
  319.
  320.
  321.             /* 5)分析数据(分析HTTP头,暂时不打算支持301之类的)        */
  322.             for(i = 0; MP3_return_data[i]; ++i)
  323.             {
  324.                 if (MP3_return_data[i] == '2' && MP3_return_data[i + 1] == '0' && MP3_return_data[i + 2] == '0')
  325.                 {
  326.                     /* 证明200 OK */
  327.                     for(; MP3_return_data[i]!='\0'; ++i)
  328.                     {
  329.                         /* 响应头的结束也是两个回车 */
  330.                         if(MP3_return_data[i] == '\r' && MP3_return_data[i + 1] == '\n' && MP3_return_data[i + 2] == '\r' && MP3_return_data[i + 3] == '\n')
  331.                         {
  332.                             /* 6)复制正文内容 */
  333.                             i += 4;
  334.                             k = ret_lens - i;
  335.                             if(k == 0) return HTTP_NO_CONTENT;
  336.
  337.        MP3_return_data_len=k;
  338.
  339.        MP3_return_data_start_offset=i;
  340.
  341.
  342.        printf("MP3_return_data_len=%d\r\n",MP3_return_data_len);
  343.
  344.
  345.
  346.        //printf(MP3_return_data);
  347.                             return HTTP_OK;
  348.                         }
  349.                     }
  350.                 }
  351.             }
  352.
  353.
  354.
  355.
  356.
  357.                         }else{
  358.
  359.
  360.
  361.
  362.           void *data;
  363.           u16_t len;
  364.
  365.
  366.
  367.                            u32 offsetptr;
  368.                 recvBuf = pvPortMalloc2( 1024*1024);
  369.                                             recvPos = 0;
  370.
  371.             ret_lens=0;
  372.                                 offsetptr=0;
  373.             while(1)
  374.                                 {
  375.                                                         netconn_recv(conn, &inBuf);
  376.
  377.                                                         if(inBuf==NULL){
  378.
  379.        break;
  380.                                                         }
  381.
  382.
  383.                                                         do
  384.                                                         {
  385.                                                           netbuf_data(inBuf, &data, &len);
  386.
  387.
  388.        memcpy(recvBuf+ret_lens,data,len);
  389.
  390.        ret_lens+=len;
  391.
  392.
  393.                                                         }
  394.                                                         while (netbuf_next(inBuf) >= 0);
  395.
  396.
  397.                                                         recvBuf[ret_lens]='\0';
  398.
  399.
  400.
  401.        netbuf_delete(inBuf);
  402.
  403.
  404.
  405.             }
  406.             netconn_close(conn);
  407.             netconn_delete(conn);
  408.
  409.
  410.
  411.
  412. //            if(err_msg != ERR_OK) {
  413. //
  414. //                                         printf("HTTP_OUT_OF_RAM in err_msg != ERR_OK");
  415. //
  416. //                                        return HTTP_OUT_OF_RAM;
  417. //
  418. //
  419. //
  420. //                                }
  421.
  422.
  423.
  424.             /* 5)分析数据(分析HTTP头,暂时不打算支持301之类的)        */
  425.             for(i = 0; recvBuf[i]; ++i)
  426.             {
  427.                 if (recvBuf[i] == '2' && recvBuf[i + 1] == '0' && recvBuf[i + 2] == '0')
  428.                 {
  429.                     /* 证明200 OK */
  430.                     for(; recvBuf[i]!='\0'; ++i)
  431.                     {
  432.                         /* 响应头的结束也是两个回车 */
  433.                         if(recvBuf[i] == '\r' && recvBuf[i + 1] == '\n' && recvBuf[i + 2] == '\r' && recvBuf[i + 3] == '\n')
  434.                         {
  435.                             /* 6)复制正文内容 */
  436.                             i += 4;
  437.                             k = ret_lens - i;
  438.                             if(k == 0) return HTTP_NO_CONTENT;
  439.                             *pageBuf = pvPortMalloc2 (k);
  440.                             if(*pageBuf == NULL)
  441.                             {
  442.                                 vPortFree2 (recvBuf);
  443.
  444.
  445.        printf("HTTP_OUT_OF_RAM in malloc pageBuf");
  446.
  447.                                 return HTTP_OUT_OF_RAM;
  448.                             }
  449.
  450.        memset((char *)*pageBuf,0,k);
  451.
  452.                             memcpy((char *)*pageBuf, (const char *)recvBuf + i, k); /* 用HTTP1.0是没http chunked response的.方便处理,否则还要分段接收网页,大的网页反正MCU也接不下. */
  453.                             vPortFree2  (recvBuf);
  454.
  455.
  456.        ((char *)*pageBuf)[k]='\0';
  457.
  458.
  459.
  460.                             return HTTP_OK;
  461.                         }
  462.                     }
  463.                 }
  464.             }
  465.
  466.
  467.
  468.                                 printf("NOY_HTTP_OK:");
  469.
  470.                                 printf(recvBuf);
  471.
  472.             if(recvBuf != NULL)        {vPortFree2 (recvBuf);}
  473.
  474.
  475.                          }
  476.
  477.
  478.
  479.             return HTTP_NOT_200OK;
  480.         }
  481.         else
  482.         {
  483.             vPortFree2 (request);
  484.                            printf("HTTP_SERVER_REFUSE");
  485.             return HTTP_SERVER_REFUSE;
  486.         }
  487.     }
  488.     else
  489.     {
  490.
  491.                  printf("HTTPS_NOT_SUPPORT");
  492.
  493.         return HTTPS_NOT_SUPPORT;
  494.     }
  495. }
上面这个实现了单片机调用网站地址并返回网页内容,下面就用这个函数具体调用百度http://vop.baidu.com/server_api?dev_pid=1536&cuid=%s&token=%s 接口,
哈,只能展示这么多,更详细支持请联系我 qq790861133  ,或进入 我网店 dianzi001购买我的百度语音识别模块
void process_asr(){
        int err = HTTP_OK;
          uint16_t  ret_code1;
                                        // printf("start ASR...");
                                 reflsh_token(0);
                                        memset(urlgg,'\0',urlchar_maxlen);
                                          //dev_pid=1536是普通话,1537        =普通话(纯中文识别),dev_pid=1936是远场普通话
                                         sprintf(urlgg,"http://vop.baidu.com/server_api?dev_pid=1536&cuid=%s&token=%s",cuid,g_access_token);
                                                 err = WebClient(urlgg, reco_temp_ram, &abuf,1,reco_temp_ram_len);
                                                 if(abuf != NULL && err == HTTP_OK)
ID:44609 发表于 2019-5-4 21:59 | 显示全部楼层
可以淘宝搜索 开开语音识别 即可找到我们
