查看: 3101|回复: 3
STC12C5A60S2的AD采集程序 求分享
ID:459513 发表于 2019-1-6 17:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有大佬用过STC12C5A60S2的AD采集吗?分享一下呗!
收藏收藏1 分享淘帖 顶顶 踩踩
ID:430980 发表于 2019-1-28 11:58 | 只看该作者
还要吗?
ID:250700 发表于 2019-1-28 14:13 | 只看该作者
// STC 官网 STC12C5Axx Series MCU A/D 例程
#include "reg51.h"
#include "intrins.h"
#define FOSC    11059200L
#define BAUD    9600
typedef unsigned char BYTE;
typedef unsigned int WORD;
/*Declare SFR associated with the ADC */
sfr ADC_CONTR   =   0xBC;           //ADC control register
sfr ADC_RES     =   0xBD;           //ADC high 8-bit result register
sfr ADC_LOW2    =   0xBE;           //ADC low 2-bit result register
sfr P1ASF       =   0x9D;           //P1 secondary function control register
/*Define ADC operation const for ADC_CONTR*/
#define ADC_POWER   0x80            //ADC power control bit
#define ADC_FLAG    0x10            //ADC complete flag
#define ADC_START   0x08            //ADC start control bit
#define ADC_SPEEDLL 0x00            //420 clocks
#define ADC_SPEEDL  0x20            //280 clocks
#define ADC_SPEEDH  0x40            //140 clocks
#define ADC_SPEEDHH 0x60            //70 clocks
void InitUart();
void InitADC();
void SendData(BYTE dat);
BYTE GetADCResult(BYTE ch);
void Delay(WORD n);
void ShowResult(BYTE ch);
    InitUart();                     //Init UART, use to show ADC result
    InitADC();                      //Init ADC sfr
    while (1)
        ShowResult(0);              //Show Channel0
        ShowResult(1);              //Show Channel1
        ShowResult(2);              //Show Channel2
        ShowResult(3);              //Show Channel3
        ShowResult(4);              //Show Channel4
        ShowResult(5);              //Show Channel5
        ShowResult(6);              //Show Channel6
        ShowResult(7);              //Show Channel7
Send ADC result to UART
    SendData(ch);                   //Show Channel NO.
    SendData(GetADCResult(ch));     //Show ADC high 8-bit result
//if you want show 10-bit result, uncomment next line
//    SendData(ADC_LOW2);             //Show ADC low 2-bit result
Get ADC result
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
    _nop_();                        //Must wait before inquiry
    _nop_();
    _nop_();
    _nop_();
    while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
    ADC_CONTR &= ~ADC_FLAG;         //Close ADC
    return ADC_RES;                 //Return ADC result
Initial UART
void InitUart()
    SCON = 0x5a;                    //8 bit data ,no parity bit
    TMOD = 0x20;                    //T1 as 8-bit auto reload
    TH1 = TL1 = -(FOSC/12/32/BAUD); //Set Uart baudrate
    TR1 = 1;                        //T1 start running
Initial ADC sfr
void InitADC()
    P1ASF = 0xff;                   //Open 8 channels ADC function
    ADC_RES = 0;                    //Clear previous result
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
    Delay(2);                       //ADC power-on and delay
Send one byte data to PC
Input: dat (UART data)
Output:-
    while (!TI);                    //Wait for the previous data is sent
    TI = 0;                         //Clear TI flag
    SBUF = dat;                     //Send current data
Software delay function
void Delay(WORD n)
    WORD x;
    while (n--)
        x = 5000;
        while (x--);
ID:475247 发表于 2019-2-10 16:52 | 只看该作者
好样的,收下了
参与人数 1黑币 +35 收起 理由
shuisheng + 35
