查看: 2435|回复: 2
esp8266控制Arduinol led灯亮灭的程序,想加一个红外感应功能
ID:395068 发表于 2018-10-8 18:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
会编Arduino的请看看
上面是手机通过esp8266控制Arduinol  led灯亮灭的程序,想在这个基础上加一个红外感应的,人靠近,灯亮,人离开,灯灭,请问应该怎么加,试了好几种方法,都不行int LED = 9;int Sensor = 7;
char ch[10];
void setup()
  pinMode(LED,OUTPUT);
  pinMode(Sensor,INPUT);
  Serial.begin(115200);
void loop()
  if(Serial.available())
  for(int i=0;i<9;i++)
    ch[i]=char(Serial.read());
    delay(1);
  if(strncmp(ch,"1",1)==0)
    digitalWrite(LED,HIGH);
  Serial.println("1");
else if(strncmp(ch,"2",1)==0)
  digitalWrite(LED,LOW);
  Serial.println("2");
ID:277550 发表于 2018-10-9 00:14 | 只看该作者
---------------只方便作延时熄灯-------------
#include <TimerOne.h>
#define TIMER_US 100000                // 100mS set timer duration in microseconds
#define TICK_COUNTS 200                // 20S worth of timer ticks
volatile long tick_count = TICK_COUNTS;         // Counter for 20S
void setup(){
        pinMode(13, OUTPUT);
        attachInterrupt(0, blink, FALLING);
        // LOW to trigger the interrupt whenever the pin is low,
        // CHANGE to trigger the interrupt whenever the pin changes value
        // RISING to trigger when the pin goes from low to high,
        // FALLING for when the pin goes from high to low.
        //Board         int.0 int.1
        //Uno, Ethernet 2     3
        Timer1.initialize(TIMER_US);                  // Initialise timer 1
        Timer1.attachInterrupt( timerIsr );           // attach the ISR routine h
void loop(){
        //Add your task
void blink(){
        digitalWrite(13, HIGH);                // Toggle pin 13 HIGH
        tick_count = TICK_COUNTS;        // Reload
        timer1.restart();
// timerIsr() 100 milli second interrupt ISR()
// Called every time the hardware timer 1 times out.
void timerIsr(){
        if (!(--tick_count)){                        // Count to 20S
                timer1.stop();
                digitalWrite(13, LOW);                // Toggle pin 13 LOW
ID:277550 发表于 2018-10-9 00:20 | 只看该作者
Timer1要改成这样的
