查看: 5276|回复: 0
单片机控制数码管进行学号显示的仿真和代码
ID:433438 发表于 2018-11-26 14:45 | 显示全部楼层 |阅读模式
数码管显示学号仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. char code shu[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
  6. char code num[16][8]={0Xff,0Xff,0Xff,0Xff,0Xff,0Xff,0Xff,0Xa4,
  7.                       0Xff,0Xff,0Xff,0Xff,0Xff,0Xff,0Xa4,0xc0,
  8.                       0Xff,0Xff,0Xff,0Xff,0Xff,0xa4,0xc0,0xf9,
  9.                       0Xff,0Xff,0Xff,0Xff,0xa4,0xc0,0xf9,0x92,
  10.                       0Xff,0Xff,0Xff,0xa4,0xc0,0xf9,0x92,0xf9,
  11.                       0Xff,0Xff,0xa4,0xc0,0xf9,0x92,0xf9,0xf9,
  12.                       0Xff,0xa4,0xc0,0xf9,0x92,0xf9,0xf9,0xf9,
  13.                       0xa4,0xc0,0xf9,0x92,0xf9,0xf9,0xf9,0x80,
  14.                                           0xc0,0xf9,0x92,0xf9,0xf9,0xf9,0x80,0xff,
  15.                                           0xf9,0x92,0xf9,0xf9,0xf9,0x80,0xff,0xff,
  16.                                           0x92,0xf9,0xf9,0xf9,0x80,0xff,0xff,0xff,
  17.                                           0xf9,0xf9,0xf9,0x80,0xff,0xff,0xff,0xff,
  18.                                           0xf9,0xf9,0x80,0xff,0xff,0xff,0xff,0xff,
  19.                                           0xf9,0x80,0xff,0xff,0xff,0xff,0xff,0xff,
  20.                                           0x80,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
  21. char code wei1[]={0X80,0X40,0X20,0X10,0X08,0X04,0X02,0X01} ;
  22. char code wei2[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80} ;
  23. uchar t,i,n,m,j,temp;
  24. sbit led1=P3^6;
  25. void delay_AUS(uint z)
  26. {
  27. while(t!=z);
  28. t=0;
  29. }
  30. void delay(uint z)
  31. {
  32.         int x,y;
  33.         for(x=z;x>0;x--)
  34.         {
  35.                  for(y=100;y>0;y--);
  36.         }
  37. }
  38. void main()
  39. {
  40. t=0;
  41. TMOD=0x01;
  42. TH0=(65536-50000)/256;//timer 50ms
  43. TL0=(65536-50000)%256;
  44. EA=1;
  45. ET0=1;
  46. TR0=1;
  47. while(1)
  48.    {  for(n=0;n<3;n++)
  49.      { for(i=0;i<16;i++)
  50.        {
  51.            for(temp=0;temp<31;temp++)
  52.                {
  53.                    for(j=0;j<8;j++)
  54.            {
  55.              P0=num[i][j];
  56.              P2=wei2[j];
  57.              delay(2);
  58.              P0=0xff;
  59.            }
  60.                    }
  61.                 delay_AUS(20);
  62.        }
  63.       }
  64.           for(m=0;m<10000;m++)
  65.          {for(j=0;j<8;j++)
  66.            {
  67.              P0=num[7][j];
  68.              P2=wei2[j];
  69.              delay(2);
  70.              P0=0xff;
  71.            }
  72.    }
  73. }
  74. }
  75. void timer0() interrupt 1
  76. {
  77. TH0=(65536-50000)/256;
  78. TL0=(65536-50000)%256;
  79. t++;
  80. }
学号显示20151126.zip (77.52 KB, 下载次数: 26)
