查看: 4365|回复: 1
[求助]如何控随意调整数码管时间?
ID:21793 发表于 2012-5-18 15:35 | 显示全部楼层 |阅读模式
//程序功能:万年历显示
//晶振大小:6MHZ
#include<reg52.h>
#include<intrins.h>
#define uint unsigned  int
#define uchar unsigned  char
sbit start_test = P3^0;
sbit start_add = P3^1;
sbit w0 = P1^0;
sbit w1 = P1^1;
sbit w2 = P1^2;
sbit w3 = P1^3;
sbit w4 = P1^4;
sbit c0 = P2^0;
sbit c1 = P2^1;
uint year,month,day,hour,min,sec,time,ge,shi,bai,qian,s_year,s_day,s_time,c_time,m_once,m_time;
uchar code tab[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
///////////////////////P1延时函数/////////////////////////////////////////
void delay()
  uint x = 0;
  for(x=0;x<500;x++);
/////////////////////////数据处理/////////////////////////////////////////
void chuli()
   if(sec%12 < 4)
   qian=hour/10;
      bai=hour%10;
     shi=min/10;
   ge=min%10;
 else if(sec%12 < 8)
      qian=year/1000;
      bai=year/100%10;
     shi=year%100/10;
   ge=year%10;
   qian=month/10;
      bai=month%10;
     shi=day/10;
   ge=day%10;
/////////////////////////消影处理/////////////////////////////////////////////
void xiaoyin()
     delay();
/////////////////////////显示函数/////////////////////////////////////////////
void display()
  /////////ge///////////////
  w0 = 1; w1 = 1; w2 = 1;w3 = 1;
  P0=tab[ge];
     w0 = 0; w1 = 1; w2 = 1;w3 = 1;
  xiaoyin();
  /////////shi//////////////
  P0=tab[shi];
     w0 = 1; w1 = 0; w2 = 1;w3 = 1;
  //bit_select = bit_select << 1 + 1;
  xiaoyin();
     /////////bai//////////////
  P0=tab[bai];
     w0 = 1; w1 = 1; w2 = 0;w3 = 1;
  xiaoyin();
  /////////qian/////////////
  P0=tab[qian];
     w0 = 1; w1 = 1; w2 = 1;w3 = 0;
  xiaoyin();
//////////////////////////中断定时////////////////////////////////////////////
void timer0() interrupt 1
 TH0=(65536-50000)>>8;
 TL0=65536-50000;
 time ++;
    s_time++;
 c_time++;
 m_time++;
//////////////////////////判断闰年////////////////////////////////////////////
int leap (int year)
   if(year%4==0&&year%100!=0||year%400==0)
      return 1;
      return 0;
///////////////////////////判断月//////////////////////////////////////////////
void days_month ()
      if(month==1||month==3||month==5||month==7||month==8||month==10||month==12)
          s_day = 31;
      if(month==4||month==6||month==9||month==11)
          s_day = 30;
      if(month==2&&leap(year)==1)
          s_day = 29;
          s_day = 28;
///////////////////////////计算日月年///////////////////////////////////////////
void s_date()
     days_month();
     if (month == 12&&day == s_day)
    month = 0;
    year++;
    if (day == s_day&&hour == 24)
        day = 0;
           month++;
//////////////////////////gai///////////////////////////////////////////////////
void date_display()
   if(c1==0 && c_time <1)
    c_time = 0;
    if(c0 == 0)
        day++;
 if(c1==0 && c_time <4)
    c_time = 0;
    if(c0 == 0)
        month++;
 if(c1==0 && c_time >4)
    c_time = 0;
    if(c0 == 0)
        year++;
//////////////////////////主函数////////////////////////////////////////////////
   m_time = 0;
   m_once = 0;
   ge = 0;
   shi = 0;
   sec = 0;
   min = 0;
   hour = 0;
   time = 0;
   s_time = 0;
   c_time = 0;
   day = 18;
   month = 05;
   year = 2012;
   //////////////中断定时初始化////////////////
   TMOD=0x01;
   TL0=65536-50000;
   EA=1;
   ET0=1;
   TR0=1;
      if(start_test == 0)
       while (m_once < 5)
      if(time==10)
               time = 0;
         m_once++;
       if(start_add == 0)
       m_time = 0;
       if(m_time <10)
         hour++;
   if(c1 == 0)
   date_display();
      display();
      if(s_time ==5)
          s_time = 0;
          w4 = ~w4;
      if(time==10)
         time = 0;
   sec++;
   if (sec == 60)
      sec = 0;
   min++;
   if (min == 60)
      min = 0;
      hour++;
      if (hour == 24)
         hour = 0;
                  day++;
   chuli();
   s_date();
能显示年月日小时,分钟,但调节不了我想用P3.0P3.1口进行时间上的调节控制,怎么搞我现在的不行?
ID:21793 发表于 2012-5-18 15:36 | 显示全部楼层
我的是四位数码管
