查看: 7854|回复: 1
PCF8591 AD采集电位器电压并显示代码值的单片机源码与电路图
51单片的1 AD采集电位器电压并显示代码值
电路原理图如下:
  1. //摘要:
  2. //四位数码管显示采集的电位器AD(代码值)
  3. //Designed by Cache.Lee
  4. #include "STC12C5A60S2.h"
  5. #include <I2C.H>
  6. #define uchar unsigned char
  7. #define uint unsigned int
  8. #define  PCF8591 0x90    //PCF8591 地址
  9. #define THCO   0xf8  //11.0592MHZ晶振
  10. #define TLCO   0xcb         //定时2ms时间常数值
  11. unsigned char Data_Buffer[4]={1,2,3,4};
  12. uchar code Duan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x76};
  13. sbit P24=P2^4;                //四个数码管的位码口定义
  14. sbit P25=P2^5;
  15. sbit P26=P2^6;
  16. sbit P27=P2^7;
  17. bit flag=0;
  18. bit DACconversion(unsigned char sla,unsigned char c,  unsigned char Val);
  19. bit ISendByte(unsigned char sla,unsigned char c);
  20. unsigned char IRcvByte(unsigned char sla);
  21. /******************************/
  22. void main(void) //主程序
  23. {
  24. unsigned int v;
  25. unsigned char AD_CHANNEL=1;
  26. unsigned int  D[5]={0,0,0,0,255};
  27. TMOD=0x11;                          //设置定时器0工作模式,16位计数模式
  28. TH0=THCO;
  29. TL0=TLCO;
  30. TR0=1;                                  //启动定时器
  31. ET0=1;                                //使能定时器中断
  32. EA=1;                                //开总中断
  33.
  34.         while(1)
  35.         {
  36.           if(flag==1)
  37.           {flag=0;
  38.
  39.             ISendByte(PCF8591,0x41);
  40.                 v=IRcvByte(PCF8591);
  41.             Data_Buffer[0]=0;
  42.             Data_Buffer[1]=v/100%10;
  43.             Data_Buffer[2]=v/10%10;
  44.                 Data_Buffer[3]=v%10;
  45.                 }
  46.    }
  47. }
  48. void timer0() interrupt 1         //定时器中断服务子程序
  49. {
  50. static unsigned int count=0;//软计时变量定义
  51. static unsigned char Bit=0;        //静态变量,退出程序后,值保留
  52. TH0=THCO;
  53. TL0=TLCO;
  54. Bit++;
  55. if(Bit>=4)Bit=0;
  56. P2|=0xf0;                                        //先关位码
  57. P0=Duan[Data_Buffer[Bit]];        //开段码
  58. switch(Bit)                                //送位码
  59. {
  60.   case 0: P24=0;break;
  61.   case 1: P25=0;break;
  62.   case 2: P26=0;break;
  63.   case 3: P27=0;break;
  64. }
  65. count++;
  66. if(count>=250)                                //半S时间到
  67. {
  68.     count=0;
  69.     flag=1;
  70. }
  71. }
  72. /*******************************************************************
  73. DAC 变换, 转化函数
  74. *******************************************************************/
  75. bit DACconversion(unsigned char sla,unsigned char c,  unsigned char Val)
  76. {
  77.    Start_I2c();              //启动总线
  78.    SendByte(sla);            //发送器件地址
  79.    if(ack==0)return(0);
  80.    SendByte(c);              //发送控制字节
  81.    if(ack==0)return(0);
  82.    SendByte(Val);            //发送DAC的数值
  83.    if(ack==0)return(0);
  84.    Stop_I2c();               //结束总线
  85.    return(1);
  86. }
  87. /*******************************************************************
  88. ADC发送字节[命令]数据函数
  89. *******************************************************************/
  90. bit ISendByte(unsigned char sla,unsigned char c)
  91. {
  92.    Start_I2c();              //启动总线
  93.    SendByte(sla);            //发送器件地址
  94.    if(ack==0)return(0);
  95.    SendByte(c);              //发送数据
  96.    if(ack==0)return(0);
  97.    Stop_I2c();               //结束总线
  98.    return(1);
  99. }
  100. ……………………
  101. …………限于本文篇幅 余下代码请从51黑下载附件…………
1 AD采集电位器电压并显示代码值.rar (204.52 KB, 下载次数: 101)
收藏收藏1 分享淘帖 顶 踩
ID:399179 发表于 2020-2-25 11:23 来自触屏版 | 只看该作者
正在学习,谢谢!
