查看: 8560|回复: 10
帮我看看这个矩阵按键键盘控制8*8的点阵显示数字程序
ID:370231 发表于 2018-8-18 15:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我是初学的,我是想用矩阵按键键盘控制8*8的点阵显示数字,可是我写的程序按键控制不了数字,不知道哪里出现了问题,帮我改一下,谢谢~~
  1. #include<reg51.h>
  2. typedef unsigned int u16;
  3. typedef unsigned char u8;
  4. //--定义要使用的IO口--//
  5. #define READPORTS                 P1
  6. #define GPIO_KEY        P2
  7. #define COMMONPORTS                P0
  8.
  9. u8 KeyValue;
  10. void delay(u16 i)
  11. {
  12.         while(i--);
  13. }
  14. void KeyDown(void)
  15. {
  16.         char a=0;
  17.         GPIO_KEY=0x0f;
  18.         if(GPIO_KEY!=0x0f)
  19.         {
  20.                 delay(1000);
  21.                 if(GPIO_KEY!=0x0f)
  22.                 {
  23.
  24.                         GPIO_KEY=0X0F;
  25.                         switch(GPIO_KEY)
  26.                         {
  27.                                 case(0X07):        KeyValue=0;break;
  28.                                 case(0X0b):        KeyValue=1;break;
  29.                                 case(0X0d): KeyValue=2;break;
  30.                                 case(0X0e):        KeyValue=3;break;
  31.                         }
  32.
  33.                         GPIO_KEY=0XF0;
  34.                         switch(GPIO_KEY)
  35.                         {
  36.                                 case(0X70):        KeyValue=KeyValue;break;
  37.                                 case(0Xb0):        KeyValue=KeyValue+4;break;
  38.                                 case(0Xd0): KeyValue=KeyValue+8;break;
  39.                                 case(0Xe0):        KeyValue=KeyValue+12;break;
  40.                         }
  41.                         while((a<50)&&(GPIO_KEY!=0xf0))
  42.                         {
  43.                                 delay(1000);
  44.                                 a++;
  45.                         }
  46.                 }
  47.         }
  48. }
  49. //--列选通控制--//
  50. unsigned char code TAB[8]  = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  51. //--点阵字码--//
  52. unsigned char code CHARCODE[16][8]={
  53. {0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
  54. {0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
  55. {0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
  56. {0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
  57. {0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
  58. {0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
  59. {0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
  60. {0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
  61. {0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
  62. {0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
  63. {0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
  64. {0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
  65. {0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
  66. {0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
  67. {0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
  68. {0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
  69. };
  70. void main()
  71. {
  72.         unsigned char tab, j;
  73.         unsigned int  i;   //无符号整数
  74.         while(1)
  75.         {
  76.
  77.
  78.                 for(i= 0; i<5000; i++ )   //两个字之间的扫描间隔时间
  79.                 {
  80.                         KeyDown();
  81.                         COMMONPORTS=CHARCODE[KeyValue];
  82.                         for(tab=0;tab<8;tab++)
  83.                         {
  84.                                 READPORTS=0xFF;                                   //消隐
  85.                                 COMMONPORTS=CHARCODE[j][tab];  //输出字码
  86.                                 READPORTS=TAB[tab];
  87.                         }
  88.                 }
  89.                 j++;
  90.                 if(j == 16)
  91.                 {
  92.                         j = 0;
  93.                 }
  94.         }
  95. }
ID:370231 发表于 2018-8-18 16:45 | 只看该作者
求指点迷津
ID:164602 发表于 2018-8-18 17:35 | 只看该作者
从你的程序上看,按键当然不能控制显示。
第一:你的电路图没有给出来,不好判断程序对不对,只能以我的经验去看程序——思路基本正确。
第二:主循环中这句: COMMONPORTS=CHARCODE[j][tab];  //输出字码
应该改为: COMMONPORTS=CHARCODE[KeyValue][tab];  //输出字码
第三:主循环中这句是多余且错误的,去掉:COMMONPORTS=CHARCODE[KeyValue];
第四:主循环中这些: j++;
                if(j == 16)
                        j = 0;
我不知道你的用途。应该是没用的。
ID:370231 发表于 2018-8-18 23:49 | 只看该作者
HC6800-ES-V2.0 发表于 2018-8-18 17:35
从你的程序上看,按键当然不能控制显示。
第一:你的电路图没有给出来,不好判断程序对不对,只能以我的经 ...
我用的板子是普中科技的HC6800-EM3 V2.2的开发板,根据你说的我试了一下还是不行,不过还是要谢谢你,多谢你的指教
ID:164602 发表于 2018-8-19 07:58 | 只看该作者
a89588038 发表于 2018-8-18 23:49
我用的板子是普中科技的HC6800-EM3 V2.2的开发板,根据你说的我试了一下还是不行,不过还是要谢谢你,多 ...
普中的板子?将板子照片发一个!!!!!
我知道的普中板子,点阵都有595控制哦,你的程序中,没有595的控制内容嘛。
单片机程序一定与相应的硬件是配套的,你不给硬件只发程序,没用的。
ID:370231 发表于 2018-8-19 13:11 | 只看该作者
HC6800-ES-V2.0 发表于 2018-8-19 07:58
普中的板子?将板子照片发一个!!!!!
我知道的普中板子,点阵都有595控制哦,你的程序中,没有595的 ...
ID:370231 发表于 2018-8-19 20:47 | 只看该作者
终于弄出来了,先上程序,从主循环开始,稍微改动一下,就是不明白为什么排线都要反着插才显示出来,不然就是倒着显示。放图片上去给大家看看。多多指教~~~
修改的程序
                        KeyDown();
                    READPORTS=TAB[tab];
                        j++;
                if(j == 16)
                        j = 0;
参与人数 1黑币 +80 收起 理由
admin + 80 回帖助人的奖励!
ID:164602 发表于 2018-8-20 08:42 | 只看该作者
a89588038 发表于 2018-8-19 20:47
终于弄出来了,先上程序,从主循环开始,稍微改动一下,就是不明白为什么排线都要反着插才显示出来, ...
你这款普中板子还真没看到过。
将电路图文件发来看看,谢谢。
至于你说的现象,肯定是和电路有关。
ID:370231 发表于 2018-8-20 14:39 | 只看该作者
HC6800-ES-V2.0 发表于 2018-8-20 08:42
你这款普中板子还真没看到过。
将电路图文件发来看看,谢谢。
至于你说的现象,肯定是和电路有关。
EM3-V22原理图.pdf (196.36 KB, 下载次数: 44)
ID:440947 发表于 2018-12-9 17:49 | 只看该作者
请问楼主有木有原理图,能否看一下?
ID:258260 发表于 2018-12-24 16:09 | 只看该作者
我想问一下,跟着你连线可是按下按键还是没反应
