查看: 3656|回复: 0
SHT11的温湿度显示为什么为0?
20黑币
求助大佬们,小白的SHT11温湿度传感器程序的LCD1602显示屏显示的只有0,没有确切的温湿度,请教是何原因?(ps:自己上网百度说是延时不够,修改哪个延时?还是说SHT11得连到单片机的某个特定IO口?还是说我的连线不对?)
如果不是这个原因,烦请遭遇过得大佬指教!感谢!
并附上程序:
Project:          SHTxx demo program (V2.1)
Filename:         SHTxx_Sample_Code.c
Prozessor:        80C51 family
Compiler:         Keil Version 6.14
Autor:            MST
Copyrigth:        (c) Sensirion AG
#include <AT89s53.h> //Microcontroller specific library, e.g. port definitions
#include <intrins.h> //Keil library (is used for _nop()_ operation)
#include <math.h>    //Keil library
#include <stdio.h>   //Keil library
typedef union
{ unsigned int i;
  float f;
} value;
// modul-var
enum {TEMP,HUMI};
#define        DATA           P1_1
#define        SCK           P1_0
#define noACK 0
#define ACK   1
                            //adr  command  r/w
#define STATUS_REG_W 0x06   //000   0011    0
#define STATUS_REG_R 0x07   //000   0011    1
#define MEASURE_TEMP 0x03   //000   0001    1
#define MEASURE_HUMI 0x05   //000   0010    1
#define RESET        0x1e   //000   1111    0
char s_write_byte(unsigned char value)
// writes a byte on the Sensibus and checks the acknowledge
  unsigned char i,error=0;
  for (i=0x80;i>0;i/=2)             //shift bit for masking
  { if (i & value) DATA=1;          //masking value with i , write to SENSI-BUS
    else DATA=0;
    SCK=1;                          //clk for SENSI-BUS
    _nop_();_nop_();_nop_();        //pulswith approx. 5 us
    SCK=0;
  DATA=1;                           //release DATA-line
  SCK=1;                            //clk #9 for ack
  error=DATA;                       //check ack (DATA will be pulled down by SHT11)
  SCK=0;
  return error;                     //error=1 in case of no acknowledge
char s_read_byte(unsigned char ack)
// reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
  unsigned char i,val=0;
  { SCK=1;                          //clk for SENSI-BUS
    if (DATA) val=(val | i);        //read bit
    SCK=0;
  DATA=!ack;                        //in case of "ack==1" pull down DATA-Line
  SCK=0;
  return val;
void s_transstart(void)
// generates a transmission start
//       _____         ________
// DATA:      |_______|
//           ___     ___
// SCK : ___|   |___|   |______
   DATA=1; SCK=0;                   //Initial state
   _nop_();
   SCK=1;
   _nop_();
   DATA=0;
   _nop_();
   SCK=0;
   SCK=1;
   _nop_();
   DATA=1;
   _nop_();
   SCK=0;
void s_connectionreset(void)
// communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
//       _____________________________________________________         ________
// DATA:                                                      |_______|
//          _    _    _    _    _    _    _    _    _        ___     ___
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______|   |___|   |______
  unsigned char i;
  for(i=0;i<9;i++)                  //9 SCK cycles
  { SCK=1;
    SCK=0;
  s_transstart();                   //transmission start
char s_softreset(void)
// resets the sensor by a softreset
  unsigned char error=0;
  s_connectionreset();              //reset communication
  error+=s_write_byte(RESET);       //send RESET-command to sensor
  return error;                     //error=1 in case of no response form the sensor
char s_read_statusreg(unsigned char *p_value, unsigned char *p_checksum)
// reads the status register with checksum (8-bit)
  error=s_write_byte(STATUS_REG_R); //send command to sensor
  *p_value=s_read_byte(ACK);        //read status register (8-bit)
  *p_checksum=s_read_byte(noACK);   //read checksum (8-bit)
char s_write_statusreg(unsigned char *p_value)
// writes the status register with checksum (8-bit)
  error+=s_write_byte(STATUS_REG_W);//send command to sensor
  error+=s_write_byte(*p_value);    //send value of status register
  return error;                     //error>=1 in case of no response form the sensor
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
// makes a measurement (humidity/temperature) with checksum
  unsigned error=0;
  unsigned int i;
  switch(mode){                     //send command to sensor
    case TEMP        : error+=s_write_byte(MEASURE_TEMP); break;
    case HUMI        : error+=s_write_byte(MEASURE_HUMI); break;
    default     : break;
  for (i=0;i<65535;i++) if(DATA==0) break; //wait until sensor has finished the measurement
  if(DATA) error+=1;                // or timeout (~2 sec.) is reached
  *(p_value)  =s_read_byte(ACK);    //read the first byte (MSB)
  *(p_value+1)=s_read_byte(ACK);    //read the second byte (LSB)
  *p_checksum =s_read_byte(noACK);  //read checksum
  return error;
void init_uart()
//9600 bps @ 11.059 MHz
{SCON  = 0x52;
TMOD  = 0x20;
TCON  = 0x69;
TH1   = 0xfd;
void calc_sth11(float *p_humidity ,float *p_temperature)
// calculates temperature [°C] and humidity [%RH]
// input :  humi [Ticks] (12 bit)
//          temp [Ticks] (14 bit)
// output:  humi [%RH]
//          temp [°C]
{ const float C1=-4.0;              // for 12 Bit
  const float C2=+0.0405;           // for 12 Bit
  const float C3=-0.0000028;        // for 12 Bit
  const float T1=+0.01;             // for 14 Bit @ 5V
  const float T2=+0.00008;           // for 14 Bit @ 5V
  float rh=*p_humidity;             // rh:      Humidity [Ticks] 12 Bit
  float t=*p_temperature;           // t:       Temperature [Ticks] 14 Bit
  float rh_lin;                     // rh_lin:  Humidity linear
  float rh_true;                    // rh_true: Temperature compensated humidity
  float t_C;                        // t_C   :  Temperature [°C]
  t_C=t*0.01 - 40;                  //calc. temperature from ticks to [°C]
  rh_lin=C3*rh*rh + C2*rh + C1;     //calc. humidity from ticks to [%RH]
  rh_true=(t_C-25)*(T1+T2*rh)+rh_lin;   //calc. temperature compensated humidity [%RH]
  if(rh_true>100)rh_true=100;       //cut if the value is outside of
  if(rh_true<0.1)rh_true=0.1;       //the physical possible range
  *p_temperature=t_C;               //return temperature [°C]
  *p_humidity=rh_true;              //return humidity[%RH]
float calc_dewpoint(float h,float t)
// calculates dew point
// input:   humidity [%RH], temperature [°C]
// output:  dew point [°C]
{ float logEx,dew_point;
  logEx=0.66077+7.5*t/(237.3+t)+(log10(h)-2);
  dew_point = (logEx - 0.66077)*237.3/(0.66077+7.5-logEx);
  return dew_point;
// sample program that shows how to use SHT11 functions
// 1. connection reset
// 2. measure humidity [ticks](12 bit) and temperature [ticks](14 bit)
// 3. calculate humidity [%RH] and temperature [°C]
// 4. calculate dew point [°C]
// 5. print temperature, humidity, dew point
{ value humi_val,temp_val;
  float dew_point;
  unsigned char error,checksum;
  unsigned int i;
  init_uart();
  { error=0;
    error+=s_measure((unsigned char*) &humi_val.i,&checksum,HUMI);  //measure humidity
    error+=s_measure((unsigned char*) &temp_val.i,&checksum,TEMP);  //measure temperature
    if(error!=0) s_connectionreset();                 //in case of an error: connection reset
    { humi_val.f=(float)humi_val.i;                   //converts integer to float
      temp_val.f=(float)temp_val.i;                   //converts integer to float
      calc_sth11(&humi_val.f,&temp_val.f);            //calculate humidity, temperature
      dew_point=calc_dewpoint(humi_val.f,temp_val.f); //calculate dew point
      printf("temp:%5.1fC humi:%5.1f%% dew point:%5.1fC\n",temp_val.f,humi_val.f,dew_point);
    //----------wait approx. 0.8s to avoid heating up SHTxx------------------------------
    for (i=0;i<40000;i++);     //(be sure that the compiler doesn't eliminate this line!)
SHT11接线
SHT11接线
LCD1602
LCD1602
